Neutral Without Engine Running??
Discussion in 'Gen 3 Prius Main Forum' started by Whiteyprius, Apr 11, 2016.
  1. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    I know this has been spoken to in relation to a dead battery question, but I thought it worthwhile to mention again. I was a bit embarrassed when I told the AutoBell attendant who seemed to be mystified trying to get my 2012 onto the wash conveyor. I told him "You have to keep the engine running to put it into neutral." Then a second attendant, about ΒΌ my age spoke up and said, "No, I know how to do it." And I thought, this I gotta see. Sure enough, after instructing the first guy, the procedure (which I tried as soon as my car was dried) was spot on. I drove back around to the entrance and told the very young Prius savvy attendant that I had driven Prii since '08, and I never knew how to do what he'd just done. And in case you're wondering: With the car off and no foot on the brake, press the start button twice, then place your foot on the brake & shift to neutral. Yes it's in accessory mode, but not running. Jeepers, was I embarrassed.
    Bay Stater and Dave14Prius like this.
  2. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Assuming the engine is warm and the traction battery is not low on charge, why not just go through in "READY" mode in neutral? The engine shouldn't run that way either, and it's less stressful to the 12-V battery than "ON" mode.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    ^^This^^
    Seems to me, when going through a conveyor car wash the trick is to be in neutral and keep the battery charged.
    I'm talking a "ride through" but I always keep the Prius in neutral but in ready mode. I always make sure I'm entering the car wash with the HV battery charged well.
    FuelMiser likes this.
  4. mikee1680
    mikee1680 Junior Member
    Los Angeles, California
    My car battery died at a busy Costco gas station once. There was no way to put the car in neutral. Kinda embarrassing. Weird Toyota didn't think about that.
  5. bisco
    49,478
    how can the battery die at a gas station?
  6. fuzzy1
    10,167
    Probably the same way it can die elsewhere.
  7. bisco
    49,478
    can't that happen to any car?
  8. fuzzy1
    10,167
    Not on any other car in my household. Just press the clutch or push the stick, and it will roll. I can't speak for modern cars without a clutch, we haven't had one.
  9. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I'm going to presume he was listening to the radio @high volume & charging his cell phone/tablet in the accessory position with a nearly dead 12V battery...
  10. bisco
    49,478
  11. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Apparently they "thought" about it but don't have a good solution:
    Page 491 of the 2013 Prius Owners manual:
  12. qdllc
    qdllc Senior Member
    1,370
    399
    Honestly, any FWD or RWD should never be towed on the drive wheels. It puts needless strain on the drive train.
