Neutral
Discussion in 'Newbie Forum' started by slick11, May 22, 2007.
  1. slick11
    slick11 New Member
    california
    What is the best way to put the Prius in neutral?
  2. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(stephanie j @ May 22 2007, 01:48 PM) [snapback]447441[/snapback]</div>
    Unless I'm misunderstanding the question, I'd think the answer would be to push the shifter knob to the "N" position.
    Is there a reason this wouldn't be true?
  3. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    <div class='quotetop'>QUOTE(stephanie j @ May 22 2007, 11:48 AM) [snapback]447441[/snapback]</div>
    Just push the lever over toward the N and hold it there for a second. It will then go into neutral.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Keep in mind that the Prius lacks a true neutral. The gears are always engaged, so even in neutral the engine and motors are connected to each other and the drive train. The N position simulates neutral by allowing the drive train to freely spin, but it only works with the Prius running. If you find yourself with a dead Prius, there is no way to shift into neutral. You will need dollies to move it.
    Tom
