New 2010 Prius Setup as my work vehicle help needed ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Markee, Apr 18, 2014.
  1. Markee
    Markee Member
    327
    50
    South Florida Broward County
    I just bought a 2010 Prius and I'm in the process of trying to figure out the best ways to set up and protect it as my work vehicle?
    I'm a fire extinguisher guy and going to be checking fire extgs out the back of the Prius.
    I just got the vehicle a few days ago and still haven't settled on exactly how I'm going to accomplish it all?
    The vehicle is definitely going to take a beating and seriously looking for options to protect not only the bumper from getting banged up but also the whole cargo area specially the cargo area sides I"m having trouble coming up with a good solution or product that will cover and protect the sides like maybe some stick on paper or vinyl ?
    Next I need to build some kind of box to carry around like 10 fire extgs . My plan as of now is to pull out the spare tire and jack and create hidden compartment down there with a lid then cover the whole back with some kind of easily cleanable roll out rubber or vinyl maybe diamond like this stuff Diamond Plate Roll Rubber Matting - Google Search if anyone has some different ideas that might look better?
    I have less then 30days before my tag transfers over from my old truck to the Prius and the temp tag will expire on the Prius so I"m under some pressure
    Definitely looking for any ideas and all suggestions ?
    51,155
    i would use a quilted shipping blanket. maybe velcro it up the sides?
  3. JC91006
    16,674
    8,519
    On the outside, you can put a bumper guard on the upper portion of the bumper.
    http://priuschat.com/attachments/rear-bumper-cover-2-jpg.63894/
    If you are using it for "work", there is really no way to "protect" it from getting scratched. The plastic edges will eventually get scratched up. The good thing is, they are replaceable, held together by clips. If they scratched to the point you can't take it anymore, just remove and replace with a new piece. Repeat if necessary.
    On my Prius cars, I use my 2006 as my work vehicle. It's scratched from the inside back hatch area and on the outside. But I don't really care because that's what work vehicles will eventually look like if used for work.
    My family vehicle is the 2010, which is in pristine condition. Not sure you can really mix business with pleasure....I sure can't.
  4. Markee
    Markee Member
    327
    50
    Yeah I saw some descent inexpensive shipping blankets at Harbor Freight they also sell tarps of all sizes and many colors considering both
    The problem i have with the Velcro tape is the glue on it along with the Florida heat tends to damage plastic parts it sticks to ?
  5. bisco
    51,155
    i wonder if you could use those removable 3m picture hooks?
  6. Markee
    Markee Member
    327
    50
    Definitely had and having some second thoughts and was at first considering buying an older cheaper Prius that i could beat up on. But in the end since I only want to own and use one vehicle as my all around
    vehicle i decided to treat myself to something nicer
    I don't buy many vehicle infact the last was a Ford Ranger truck i bought new in 93 and I been driving and using it for work and play for over 21yrs
    I do realize over time it will show a wear and tear working from it but still want to do my very best to protect it so definitely here looking for any ideas and all suggestions?
    Anyone ?
    Good possible idea I've never used them anyone with experience using them want to comment if they think they could possibly work to help hang Velcro that i could use to cover the sides with something to help protect it ?
  7. bisco
    51,155
    they work great on walls, i just don't know about putting them on the plastic trim. you could try suction cups on the bottoms of the windows.
  8. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I had a Canvasback liner in my Subaru Outback and I used that like a truck to haul the dog, yard waste, home project stuff, etc. and it cleaned up well.
    Results for Toyota Liners:prius
  9. Markee
    Markee Member
    327
    50
    Thanks that looks like a descent not to expensive alternative
    Toyota:prius<BR>2010-2014
  10. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    The PriusChat shop bumper guard is the OEM guard. It protects your bumper from (minor) damage from you, e.g. temporarily resting heavy objects on the bumper. It doesn't protect your rear bumper from other bumpers, perhaps from people with poor parallel parking skills.
    For the latter, you might consider something like these:
    Bumper Protection, Bumper Protectors, Bumper Guards Protect Your Car from Bumper Damage
    They also have some stuff for corners. (These do start to look rather garish on ones car, of course, rather like what one might imagine a fearful father padding his teenage daughter's car with when she first learns to drive. On the other hand if your work involves the rear end of your vehicle being frequently subject to really light "nudges" from cars or other things banging into the bumper a lot, such bumper guards might look less silly.) Obviously they won't protect against outright recklessness like someone swinging a fire extinguisher around to wear on their back (I don't really know how those're used in your line of work).
    Got a picture of what 10 fire extinguishers're supposed to look like ideally when arranged the way you'd need them to be in the cargo area? If it's always "10 fire extinguishers of the same type in the same configuration", it almost sounds like you should have some kinda rack that holds them all like the Ghostbusters did..
  11. Markee
    Markee Member
    327
    50
    My plan is to pull out the spare tire and jack and create a box with a hinged cover to open to get to the fire extgs when i need to
    I measured down and there seems to be enough room to fit about 13 fire extgs with room to spare more then enough
  12. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    Wait.. it sounds like I'm thinking of something entirely different when I hear the term "fire extinguisher" than what you are. I'm thinking of something shaped like a scuba tank and sized almost the same or just a little smaller. I can't imagine 13 of those fitting anywhere the spare tire space would hold.
    (I also have a PiP where the spare tire area has been commandeered for the giant battery used during EV mode, so I'm less familiar with how it looks in the spare wheel variants. We don't get a spare tire, but this weird small little box and tool that seem to be emergency patch and inflation systems.) If they will all fit under the "floor" of the cargo area though, then that actually sounds pretty slick!
  13. Markee
    Markee Member
    327
    50
    Yeah its going to be pretty slick when i get done with it
  14. car compulsive
    741
    274
    Michigan
    What I liked about Canvasback was that I could work with them to customize what I wanted. Their normal offering for the Outback was a solid fabric floor. I wanted to retain access to the under-floor storage area of the Outback where I stored the wheelchair leg rests my late wife used. I sent them measurements and they visited a used car lot and confirmed them. For about $20 extra, they made me a custom cover with cutouts for the edges of the floor hatch and the handle.
  15. BluetoothEdsel
    164
    25
    San Diego
    If you're talking about the 3M "Command hooks" that attach with a removable adhesive liner: that adhesive doesn't like heat much either. I have tried using them to attach a flat plastic TV antenna to a window at home - they just dry up and fall off. (In fairness, I think it said on the packaging they wouldn't work in direct sunlight, but I figured I'd try anyway.)
    That Canvasback liner does look good if it's thick enough to protect the floor from your cargo and doesn't slide around when you put heavy stuff in. The price is roughly twice what I paid for the OEM all weather cargo mat, which is thick rubber but only covers the floor - thus leaving me to throw down a moving blanket or tarp when I want to put the seats down. So that actually seems like a good deal for a one-piece solution. (Especially if they'll customize as they did for car compulsive.)
  16. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    In my v, I always leave the rear seats down, I just use a generic rear cargo cover installed backwards over the rear seats, and under the real cargo liner where they overlap
    BluetoothEdsel likes this.
