New 2014 Prius C not getting the posted mpg...
Discussion in 'Prius c Fuel Economy' started by NatalieS, Oct 17, 2014.
  1. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    So I just got a Model Two 2014 Prius C and have been driving it for about 2 weeks and I must say I am pretty disappointed. Not sure if I just didn't know what I was signing up for with this car or what I'm doing wrong but I cannot get the posted mpg most of the time.
    Here's how I drive: no hard accelerations or hard stops, I have modified my route to work to be city only, no highway and on the way back from work, I drive about 50/50 city and highway. My morning commute is about 26 km and afternoon is about 37. I do not want to drive my Prius C the "ideal" way to get the most mpg as it is slow and extremely frustrating and I am sick and tired of getting honked at. Not to mention it adds 10-15 min to my already hour long commute.
    When I drive, after the first 10-15 min, my mpg on the display generally settles around 4.3 for highway and 3.6 for city driving. With that in mind, I should be getting an average of at least 50 mpg, however, my last fuel tank was about 700 km and that averages to about 45 mpg.
    When I have calculated my trips from the fractions of the fuel tank gauge (which is divided into 10 fractions, each .95 of a gallon according to Toyota specs), some trips I get only about 58 km per fraction (around 60 kpg) and recently even as low as 55kpg!
    What is going on? I am losing my mind over this and very upset as I am locked into a lease and really disappointed with my choice. I still have to fill up once a week and I had really hoped for more.
    EDIT: I also drive in ECO mode all the time, I never turn it off.
    #1 NatalieS, Oct 17, 2014
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Do not spin the tires, other than that accelerate briskly and get it over with, the prius cruises wonderfully.
    If highway means cruising at 100 km/hour or less and city means stop and go, I would cruise.
    I am going to be curious here, which uses less gas? Even if you get lower MPG, if it is 11 km shorter, you may use less gas. My goal is always to use less gas.
    I doubt the accuracy of the fractions, my gen 2 was laughable, and my v is wildly variable. Perhaps the c is better, but I doubt it. I learned to measure multiple tanks as my MPG.
    Some personal advice, my opinion, not facts.
    The car will train you, and the tires will break in for about 8,000 km, then in 80,000 km when you need to replace the tires, it will dip again for 8,000 km and you will be frustrated again.
    Check the tire pressure. In my opinion, Toyota has optimized their recommended pressure for comfort. Raising it to about 40 PSI front/38 PSI rear, (I do not know my metric tire pressures) will improve MPG, tire life, handling and braking, at some comfort loss.
    robertmaria likes this.
    51,476
    how fast do you drive on the highway?
  4. zeuloa
    zeuloa Member
    30
    26
    Managua, Nicaragua
    2014 Prius c
    Im having the same issue after 3 tanks... Mostly drive in the city (stop and go with ups and downs), but my best mileage has been on the highway on 2 trips I took.
  5. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    i do NOT trust that gas gauge pips. look at it as full, was full, and now not full so fill it asap (anything past halfway). make the odometer and tripmeter your friends; use them well. turn OFF the A/C so the light for it is off. set the heater on something reasonable like 77 degrees. maybe the ICE is running to provide heat more than necessary. my A/C in Hawaii was killing my mileage. but i noticed the heater when i put it above 81 degrees kills it too. i wish we could run the fan manually. somehow on my c the climate control is on AUTO regardless of the Auto light being on. i'm just guessing maybe itz the climate control on yours too. btw the ECO button wastes gas for a LOT of people,,, like lowering the heater fan too much so maybe put the heater hotter than necessary which ends up wasting gas. sames goes for the A/C for me.
    -- ps dont get honked at because guess what the c is,,, we got the hot rod Prius,,, floor it like heck and drive like it too,,, i always get over 50mpg nowadays. good luck (obey traffic laws though, ok).
    #5 robertmaria, Oct 18, 2014
  6. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I find that my fuel mileage as told by the meter is about 1 mpg optimistic as compared to hand figured.
    Miles driven divided by gallons per fill up. Fill your car with the nozzle put to the first stop. End fueling at the auto shut-off. Repeat per fill up.
    There are many ways to get the most mileage out of the C. You can find them on this site. Put your C in ECO mode and leave it. Drive without extremes. Accelerate briskly to speed limit and let off the gas to get in EV mode, then use your experience to keep it there as long as you can or drive with it there as often as you can. Experience is a function of time behind the wheel and paying attention to what works for you and your driving area. Not all of us live in places where we can get fantasic mileage. I get 46 or so on the highway and 50-ish in the city. My best tank has been 61mpg, but my commute is only 4.5 miles now and the car is cold most of the trip.
  7. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    And I find that my displayed figure is 2-4 MPG optimistic.
    This is a very typical first post from a hybrid owner, almost any brand, and even from some owners of small non-hybrid cars too.
    The posted figures are ESTIMATES only. Almost nobody gets the posted numbers consistently.
    The absolute best mileage is on a flat road going about 52 MPH and never stopping.
    Anything that deviates from that makes the number go down.
    And you must use the actual amount put into the tank as measured by the pump.......NOT any gauges in the car.
    45 is more than respectable for "normal" driving.
  8. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    Hi NatalieS
    Like many before you :) you are trying too hard too soon, and spoiling the experience for yourself - relax, forget the forum advice for a few weeks, and just drive the car with the traffic to get thoroughly used to it. In particular, quit using Eco mode; it doesn't improve fuel economy, just makes the gas pedal less sensitive if you have a heavy foot, which means less responsive when you really want to boot it! Take the opportunity to find out how the car can really accelerate when you want it to, such as on on-ramps, and in lane changes. It can get a little noisy briefly, but it won't affect your economy unless you do it all the time. You will find the C is really quite capable, while still getting better economy than anyone other vehicle on the road.
    You say your display settles around 3.6 in the city and 4.3 on the highway - these are good numbers! It would nice to know what number you arrived home with, but your combined city/highway economy (round trip), given about 70% city driving, should/must be close to 3.8 or 62mpg. The C like most cars is a little optimistic - I find it is typically 1-2 decimal points too low, so your 3.8 is probably 3.9-4.0 (59-60mpg).
    I therefore have come to the conclusion that your difficulty is not with your car or your driving, but with your attempts to calculate the economy! There is only one way to do this accurately:
    Using your Odo reading or one of your trip settings, record your kilometres for every tank
    Fill the car at the same gas station / same pump if possible, every time
    Set the nozzle to autofill, and let it run to first shut-off - stop there
    Use a calculator, or sign up with Fuelly or similar, to calculate your tank economy. As you are commuting, this should be a good reflection of how you are using the car
    Do the above for every tank - for hand calculations combine and average your results (Fuelly will do this automatically). Over a few weeks and tanks you will get a clear picture of your consumption for your driving and driving conditions.
    You have to enjoy your driving as a commuter, so decide what is most important - commute time, confidence your car is capable for the job, top fuel economy, or least cost. Usually the shortest route uses the least fuel and is the cheapest, though it may have a worse fuel economy and/or take longer. Your highway travel may be overall quickest both ways, but cost a bit more than now. However, the C is a gas miser, so it may be the best trade off.
    After you have taken some time to become confident in your car's capability, then you can start to experiment. I found the first year's driving gradually taught me how to get excellent economy. In my second year of ownership I kept on getting even better numbers without even trying!
    Much is written here about tire pressures, Eco mode etc - I added +8 psi to the tires for the first year, but I have gone back to +1 psi, and my economy has only dropped back about 0.1-0.2. I haven't used Eco mode since the first month; if you have a light foot it adds nothing.
    When you get your calculating problem sorted you should start to enjoy the choice you have made. All the best!
  9. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Eco mode helps a great deal here, as it manages A/C better. In other climates, it may have less effect. Since I use cruise control 98% of the time, throttle position is not my concern.
  10. Mendel Leisk
    40,918
    If you are getting the posted mileage some of the time, that is doing great. Well, maybe not if it's a momentary thing, say just freewheeling down a steep hill. It's actually a little puzzling that you should concern you. Is this your first car, or first fuel efficient car where you've turned your attention to mpg? It is really one of the ten commandments, or should be:
    Thou shall not get the posted mpg.
    Until you try like the beejesuz, read up a lot and practice driving efficiently, carefully track calculated mileage, have good weather, level roads, no short trips, and and so on.
    Unless you're Wayne Gerde of CleanMPG, that is.
  11. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    JimboPalmer, thank you for the detailed feedback and advice. The reason I changed my morning route from highway to city was mainly because on the highway, I spend the first 15-30 minutes standing in traffic (mostly using battery though cause it's about 5-15 km/h speed) and then I cruise for a bit and slug through traffic again, etc etc. The city route does have more lights but overall I spend more time driving. I don't know how else to gauge it though...
  12. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    For the first 15-30 minutes, about 5-15 km/h, then for a bit around 100-110, then around 20 km/h and then fast again... the last little stretch is 80-70 km/h.
  13. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    haha I like the "ps" advice! I started accelerating faster and it hasn't so far affected my mileage, so you're right. I don't know though, is the L/100km gauge accurate? I feel like that has some variability also. The temp outside just dropped a few degrees and already I am getting worse mileage. Annoying!
  14. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    Thank you, I will definitely gauge it by what I fill up next time! It'll be a bit off probably as I don't go to empty before filling up (usually around the last fraction is when I fill up, before it starts flashing). For this tank so far I am at about 630 km and I still have almost 3 fractions left (my first trip was mostly highway with few stops and that seems to get the best mileage).
  15. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    hieronymous, thank you so much for your detailed reply, this all made me feel a lot better about my driving and you are right, I have a very light foot on the pedal and the ECO mode drives me mad sometimes. I will try to relax and just enjoy driving like I used to before I tried to get too much too quickly. I will continue keeping track of my fuel tanks and mileages and sign up with Fuelly to get some numbers as well. Hopefully some time and breaking in the tires will make a difference, especially now that it's getting colder. Good thing I park underground!
  16. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    haha good advice, I will keep track of my mileage and as for "have good weather" well... I live in Canada soooo.... not sure how often that's gonna happen haha
    Andyprius1 likes this.
  17. Mendel Leisk
    40,918
    Canadian fuel economy ratings are more out-of-touch than US, the testing method is more disconnected from reality.
  18. vskid3
    vskid3 Active Member
    773
    228
    You don't need to empty the tank to calculate your mileage. Just divide the distance since the last fill by the amount of fuel it takes to fill the tank.
    I would try driving it like you would your old car and see what that gets you. Sometimes when you're trying to get good mileage, you're actually doing things that reduce your mileage.
  19. NatalieS
    NatalieS New Member
    Toronto, ON
    2014 Prius c
    That's smart, vskid3, I will calculate this way and drive it as close to my old car as I can. I had pretty good cruising skills in my Matrix XR though it's fuel economy was I kid you not, 20-22 mpg.
  20. vvillovv
    vvillovv Senior Member
    4,320
    1,505
    NY
    This is not the best time of year to be watching mpg and hoping to see good results in a prius or any other car.
    I'm not real good with converting lpk to mpg, but for this time of year and your location the numbers may look a bit low, but not really to bad.
    Across the Lake my range is dropping too as the weather gets colder.
