New 2014 Prius MPG Problem- Help me figure out what Im doing wrong!
Discussion in 'Gen 3 Prius Fuel Economy' started by wanderingnwary, Dec 24, 2014.
  1. wanderingnwary
    wanderingnwary New Member
    Savannah GA
    Hello all-
    I am the owner of a new 2014 Prius Two as of three months ago. I have really been enjoying the car, and it is certainly more friendly at the pump than my old Chevy Tahoe. I have a question as to why my mpg has been getting worse of late, and thought that you all may help me.
    I live in the south (Georgia) and while it has been getting chillier, The coldest temps we are getting is in the high 30s and 40s currently. Majority of driving is in the 50s and 60s currently.
    On this particular tank of gas, I have gone about 350 miles, almost entirely on the relatively flat I-95 highway. Average speed of 67 (though I had cruise control set at 75 when possible). My mpg has been around 44.1. I have made this particular road trip before and have gotten close to 50 mpg, in the first month of getting the car.
    I recently took the car to Toyota for my 5000 mile fluids, air, and overall checkup. I have now about 4200 miles on the car. I have noticed that the car consistently is getting low 40s per tank of gas. Some of this I can attribute to short trips to work (around 5 minutes). However, I am just comparing to the mpg that I used to get when I got the car in late september, which were noticeably better, especially on the highway.
    Is this an issue where I need to get my oil changed, hyper inflate the tires, or is there something else I should be concerned about?
    I try to use the hybrid display to keep the car in EV/ECO mode as much as possible where the mpg display shows upwards of 100. I am familiar with the priniciples of coasting and haven't really altered my driving style much from when I was getting better mpg right after purchasing the car.
    Doing a lot of driving over the holidays so any help would be incredibly appreciated!
  2. irrational
    irrational Member
    102
    38
    Tulsa, OK
    That's about the time refineries start switching to winter blend gas, which will get worse MPG.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Welcome to the forum.
    Check tire pressures.
    Drive slower (your comment about doing 75 on the Interstate)
    Don't use premium fuel
    Check the prevailing winds (that is only partly tongue in cheek)
    Get the 12 V battery checked.
    Don't worry about it. If something serious is really wrong, it will get MUCH worse.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You're right in the ballpark for such driving. High speeds, short trips and winter weather are all bad for fuel economy. Mix a couple of those together and it gets worse.
    xpcman likes this.
  5. bwilson4web
    15,524
    F8L likes this.
  6. Dex
    Dex Junior Member
    Warner Robins, GA
    I'm only about two hrs away from you and the weather has changed quite a bit. I don't think anything is wrong with your Prius, look at my fuelly and you will see my MPG history. It's not broken down into percentage of Hwy vs City, but a lot of my fillups are a mix of both or mainly highway. I drive around 75-85 mph on I-95, I-75, and I-20.
  7. bwilson4web
    15,524
    Many years ago, Jason's GreenHybrid mileage database included temperature. So I gathered a bunch of individual records to generate these charts:
    This is my first Prius record showing the correlation between temperature and MPG. The 'trend lines' are a math trick to reduce the samples to something that approximates a smooth function.
    I have never understood the dip at 70F with local peaks on either side. Just to make sure, I also plotted the first standard deviations on each side of the mean:
    The only independent variable is the driver . . . but then I've never understood him as he is me. The 70F dip was not found in other driver/car records:
    Here is another driver and vehicle. Curious dip around 40F which corresponds to an impression I've gained that below 50F, the temperature effects are more pronounced.
    Her we see the significant dip at 50F, a third Prius and driver.
    So I took just my Prius metrics and interpolated the temperatures between samples. In effect, increasing the temperature 'resolution' by doing an approximation. My preferred technique is Gaussian using:
    • 25% prior temperature
    • 50% current temperature
    • 25% following temperature
    This technique eliminated the 70F anomaly and avoids what might have been a sampling error:
    So I'm fairly confident that the MPG drop-off under 50F is accurate. Later, I had occasion to do a 24 hour round trip from Huntsville AL to Columbia SC in the winter.
    This trip was under a stalled, Arctic high pressure dome centered midway near Atlanta. The temperature ranged from 17F at the start; 38F at the Interstate entrance around 3:00 PM on the way back and ended at 19F. No significant wind, the trip was on cruise control the whole way. I found the 2 hour measured, MPG followed the air density that varied by outside air temperature. In effect, the MPG was air density driven below 40F.
    The primary temperature effects I have observed are:
    • cold-start warm-up - this is the primary effect urban, short trips
    • air-density - this is the primary highway experience
    I do not discount winter blend effects nor tire rolling resistance. Rather, I don't have any metrics.
    alekska and Nora like this.
  8. theotherone
    theotherone Junior Member
    67
    24
    Greenville, SC.
    I would check your tire pressure.
    I generally get 52 to 54MPG, but I religiously keep the cold tire pressure set at 42PSI (Front) and 40PSI(Rear). Keeping your tire pressure high will change your overall MPG. I do not trust the dealership mechanics and/or tire shop people to set my tire pressure, there are too many inconsistencies. Get yourself a good tire pressure gauge (not a cheap pencil air pressure gauge) and check cold tire pressure at least once a month, especially when there is a change in temperature and/or barometric change.
  9. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    Good advice above. I would add that it's often detrimental to keep the HSI in the EV half; when accelerating, you want it to be towards the right, and even going a little bit into the PWR bar isn't a terrible thing. Once you're at speed, it's up to you whether you want to be in the "just drive it" camp, or if you want to dip into the hypermiler category. I would recommend just driving it, the car is pretty smart about what it does.
    If you accelerate too slowly, using too much battery power, you end up paying for it later; you get 100 mpg now, but you get much less later when the gas engine has to replace the battery power you've used. In the Prius, all the energy you use eventually can be traced back to running the gas engine. Using battery power means that you ran the engine, recovered some of it in the battery (losing a percentage to inefficiency in energy conversion), then used it from the battery (losing another percentage). So it's best to only use battery power if you'd be using the gas engine very inefficiently - like tooling around a parking lot, or maintaining your speed on a slight downgrade.
  10. bisco
    49,490
    once in a while, a new prius comes with a bad 12 volt. get it checked while you're still under warranty.
  11. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Winter blend gasoline will drop you mpg's on your Prius about 10%. Even when winter temps were for a while were near 60 F , mpg's was still way lower than summer with the same temp, road condition etc. Right now mpg's 46 calculated, summer 52 mpg calculated.
  12. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Leave 5-10 min's early and set cc at 60 mph.... Relax and enjoy the less stressful drive which will also include significantly better mpg compared to 75 mph :)
    And yeah, all the above, tire pressure (I run 44/42 on my persona)...etc.... Cold weather really kills our mpg, it's a fact.
  13. lester williams
    227
    68
    mississippi
    I am off 4-6 mpg since it has gotten cold here, myself. The wonderful news is that gas is below $2.00 now, so less concern for me. I am also driving a little faster, and 46-48 mpg at $1.75 per gallon ain't bad to me. Trust me-- this cold has taken a toll on all of us.
  14. bisco
    49,490
    i hope the o/p survived the new year.:unsure:
  15. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I agree but not so large...I would say winter blend is maybe 2-3% less MPG.
    I am expecting about 10% MPG difference is the biggest fuel delta we might ever see between a high energy E0 and low energy winter E10.
    I definitely agree winter MPG is at least 10 maybe 20% lower, but it's due to many factors including thicker lubes, high tire rolling resistance, cooler engine, as well as winter fuel.
  16. GregP507
    GregP507 Senior Member
    3,002
    480
    I agree, there's a significant dip in mileage with colder weather. I put most of that on the thickening of lubricants. Short trips don't seem to reduce fuel economy in my opinion; I find the opposite in fact. Highway miles, when driving at 70 mph or more are less-efficient than city miles in most cases. I don't think changing tire pressures or changing your oil will have much of an effect, unless you're using a 30 or 40-grade oil.
  17. Mendel Leisk
    38,726
    Longer trips at lowish speeds are where I get best mpg, year 'round. I do think short trips cut into mpg more so in winter: your warm-ups are more protracted. The car looks at the lower ambient temperature and changes warm up behaviour accordingly. Strategies that work for me:
    1. Drive less. No kidding, this is hands-down the best way to save gas, lol.
    2. Consolidate errands. May not be possible, depends on your circumstances.
    3. Choose secondary, lower speed routes. Higher speeds kill mpg in an exponentially increasing manner.
    4. Avoid hills. It is sometimes possible: a little tweaking of your route can avoid climbing and descending a local bump.
  18. GregP507
    3,002
    480
    Or ride a bike. LOL
  19. Mendel Leisk
    38,726
    Well, we walk for local errands, as long we're not gonna be pack horses. Of late, semi-retired, the car get's fired up maybe every other day. Sometimes goes 3~4 days.
  20. jefftb
    jefftb New Member
    Bowling Green, KY
    Just came to the forum for this very question. 2014 Prius 4 and was averaging 48-50 mpg in summer, and now around 42 Mpg. The change with winter fuel makes total sense. I am also going to increase my tire pressures to 42/40. Hopefully that helps.
