For Sale New and Used Gen 2 Prius Parts.
Discussion in 'Private Sales' started by WRENCHDOC, Jan 25, 2024.
  1. WRENCHDOC
    WRENCHDOC New Member
    Tempe AZ
    If this thread is not acceptable for this group, please delete.
    We are a shop in Tempe Arizona that specializes in fixing Priuses. We're clearing out our inventory of mechanical and body parts for the Gen2 Priuses.
    IF this thread is of interest, I am happy to share what parts we have available, including fenders, grilles, retainers, radiator, brakes, etc.
    Thank you!
    Tempe Arizona
  2. PriusCamper
    PriusCamper Senior Member
    11,068
    4,506
    Pacific Northwest, USA
    Welcome to PriusChat... We have a "for sale" forum, so if you click the report button on your post and ask the moderator to move this thread over there that'd probably be the easiest fix.
    In the meantime, watcha got?
    WRENCHDOC likes this.
  3. WRENCHDOC
    Tempe AZ
    I have a partial list as I am cataloging the items as I go.
    1 AKEBONO GEN 2 FRONT DISC BRAKE PAD ACT822A
    1 GEN 2 PRIUS RADIATOR 16041-21281
    KOOL-VUE GEN 2 RADIATOR FAN/MOTOR ASSY TO3117100
    1 METRI GEN 2 CONDENSOR ASSY 88450-47020
    2 TOYOTA GEN 2 VALVE ASSY, WATER W/BRACKET 1667021010
    2 FUTABA GEN 2 RADIATOR CAP 16401-72090 R125
    1 TOYOTA GEN 2 EVAPORATOR SUB-ASSY 88501-47041
    1 ACKOJA GEN 2 OIL PAN 12102-21010
    2 TOYOTA PLATE, PAD SUPPORT (FOR FRONT DISK BRAKES) 47717-12030
    2 TOYOTA GEN 2 SHIM KIT, ANTI SQUEAL 04945-20210
    1 GEN 2 Plate, Pad Support, NO.1(For Front Disc Brake) 47716-12070
    1 GEN 2 BRAKE ADJUSTER 0494312010
    1 TOYOTA GEN 2 FRONT SEAL, TYPE T OIL (CRANKSHAFT) 9031125032
    2 GEN 2 RH SEAL, TYPE T OIL FRONT DRIVE AXLE SEAL 90311-35069
    4 DEA GEN 2 RUBBER AUTO TRANS MOUNT 4246
    1 REAR DRUM BRAKE SPRING KIT 0494252050
    I also have Fenders, Grilles and Retainers.
  4. WRENCHDOC
    Tempe AZ
    UPDATED LIST -
    1 KOOL-VUE GEN 2 RADIATOR FAN/MOTOR ASSY TO3117100
    2 OEM BLOWER MOTOR 87130-47070
    1 PARKING BRAKE CABLE BCA660009
    2 AKEBONO FRONT BRAKE DISC ROTORS 4351247030 / AK20413
    1 MANDO AC COMPRESSOR 10A1549
    2 PDL WHEEL BEARING AND HUB ASSY
    2 FRONT LH STRUT/COIL SPRING ASSY 2701-524529 / 1331620L
    1 FRONT RH STRUT/COIL SPRING ASSY 2701-524530 / 1331620R
    1 RH REAR SUSPENSION STRUT AND COIL ASSY 2701-545913 / 1345378L
    1 LH REAR SUSPENSION STRUT AND COIL ASSY 2701-545912 / 1345378R
  5. JC91006
    16,479
    8,395
    Can you put this stuff on eBay? That’s what most shops do and it’ll reach a bigger audience. Just curious the name of your shop?
    #5 JC91006, Jan 27, 2024
