New Auxiliary battery installed but warning light keeps flashing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RandyRucker, Nov 12, 2020.
  1. RandyRucker
    RandyRucker New Member
    CA
    Just installed a new auxiliary battery but the warning light keep flashing when the car is off (not while driving). Does this indicate there's still an issue, or does the light need to be re-set for some reason? We called the AAA guy who put the new battery but he says he's never seen this before. Any ideas?
    51,984
    there is always a light flashing with the car off. which warning are you seeing?
    pjksr02 likes this.
  3. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    “Warning light” doesn’t exist on this vehicle.
  4. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Sounds like the immobilizer light. It should flash when the car is off to let you know its working.
