New battery and starting troubles
Discussion in 'Gen 2 Prius Main Forum' started by PriPriBadDay, Apr 15, 2019.
  1. PriPriBadDay
    PriPriBadDay New Member
    Massachusetts
    I have a 2005 prius, about 170,000 miles, that’s having a bad week. I just got the starter battery replaced. Went to great efforts (no one had it in stock...) to get the right one, so I sure hope the dealer did that right. It was starting fine, just not able to sit long before dead, and the battery tested very low in amps and whatever they do to determine if a new one is needed. Ever since I got that new one in there has been funky. one thing that may be to do with it is that I ran it dead shortly after, airing it out with the back door open, because my car needs to air out a lot, as it’s been through some dirty shoes and moisture. We started it again, but now it has everyone where I live alarmed... once off, it does not start again. That has me baffled. Someone said maybe it was so dead it needs to drive for a while. Is this true? I drove it a little, and it was on, running occasionally, for 30+ minutes. Right now it does not start properly at all, behaving weirder than it’s ever behaved. Any ideas? Thanks so much
  2. PriPriBadDay
    Massachusetts
    Clarifacation
    Does not start without jump. Was not starting properly as of last night even with a jump. Some connection, probably around it’s starting mechanism, was making funny noises. The screen was on, the dash was off. The dash was on, the screen was off.
    52,390
    welcome!
    start with a voltage test. a cheap meter is around $20.
    you probably need a smart charger to bring it up to snuff, but driving it for 4 hours may do the job.
    new batteries have a warranty. contact the dealer and see what they say.
  4. 09Prius2
    09Prius2 Member
    201
    88
    FL
    The starter battery is actually the hybrid battery.
    The accessory battery only needs enough voltage to start the computer, then the hv battery takes over and feeds the little battery.
    If it starts with a jump than something is draining your new battery. Nothing about it really requires a long charge cycle, since it doesnt discharge from cranking.
    Is the hv battery holding power? What if you get it up on the highway and coast down so you have a full charge, and park it with at least a half charge, once your small battery is fully recharged.
    Also if you have a mechanical issue that can prevent the system from charging at all, so basically the engine is always running but the batteries are always low.
