New battery, cold weather, Gen2 won't start
Discussion in 'Gen 2 Prius Main Forum' started by Tynyyn, Feb 20, 2021.
  1. Tynyyn
    Tynyyn Member
    108
    29
    Bella Vista Arkansas
    I've not driven my Prius for a week due to the cold weather. Very recently( about 3 weeks ago) I replaced the 12v battery because the original battery died. I went out to the Prius this morning and it would not do anything. Drats. I put the key in and no chimes. I pushed the on/off button and nada. So I then jumped my battery directly with another vehicle. Battery to battery connection, not the red lug underneath the hood.
    After I got my Prius to start I put a volt meter across the battery terminals to see if the battery was dead. It read 13.78 volts. I drove the Prius for about twenty minutes to make sure the battery was fully charged, I then came home and parked it for about ten minutes. When I tried to restart it the car would not do anything. I jumped it again and then took a reading on the battery. 4.28volts. The battery had not recharged after I had driven it for twenty minutes.
    What would cause a new battery in a Prius to not charge?
    Is this a common occurance for a Prius during extremely cold weather?
    What would be my best option for this Prius....crush it, find a fix, or use it as a driveway paperweight?
    As you might tell I am becoming annoyed at this vehicle. I really like it, yet it seems to develop gremlins when I least need to fight them.
    268K miles
    51,155
    the battery is defective, the car is fine. a prius barely maintains a good battery at 12.x volts, it ain't gonna charge a dead one in 20 minutes, or 20 hours.
    look at the battery warranty and return it
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    First, it takes more than 20minutes to charge a discharged 12v and investing in a quality 12v battery charger will be worth it in the long run... Second, I'd be willing to bet you bought an Optima yellow top 12v, which isn't a real battery, just fake battery sold by a criminal operation in Mexico.
    Steph1972 likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Best to always check the voltage at the jump points under the hood, the same place you should jump start the vehicle from.
    That reading was with the vehicle in 'Ready' mode, which means the dc/dc converter is working with a measured voltage of 13.78v
    Check the 12v at the front jump points when the vehicle is turned off, if the 12v isn't making it up front, then the vehicle won't ready.
    You could have a loose connection at the 12v battery, also check the 12v ground strap where it mounts to the body for corrosion.
    donbright likes this.
  5. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    is there any chance you accidentally left a light on when you put in the new 12v a few weeks back?
  6. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    It sounds like a loose connection in the 12V somewhere.
  7. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    23
    Pakistan
    In addition to all other points. It would take a minimum of 8 hours for the prius to charge ur 12v battery if it is discharged
  8. dolj
    dolj Senior Member
    8,217
    4,187
    I don't know if that is true for your Gen 3 but you are posting in a Gen 2 forum and it would take at least double that time for a Gen 2.
    Todd Allan McIntyre likes this.
  9. PriusCamper
    12,064
    4,896
    It depends on the charger... I'm glad I finallly stopped using cheap $10 trickle chargers than can take days... Now have a cheap $30 charger that can pump up to 8amps and is fully automated to send the most optimized amount of amps depending on the state of charge and that device can do a full charge of a mostly drained battery in 8 hours.
  10. dolj
    dolj Senior Member
    8,217
    4,187
    My comment was based on the OP's questions about charging using the DC/DC converter which certainly would not be done in 8 hours. I do agree that getting a good appropriate current (3 - 4 Amp) charger for the stock OEM battery is a better solution than charging in (and by) the car.
    @PriusCamper, you need to tailor your advice to include the fact you are not using the OEM battery, so what is appropriate for you and your situation is not general advice for a Gen 2 Prius with an OEM 12V battery.
  11. PriusCamper
    12,064
    4,896
    Aftermarket 12v AGM batteries are in no way different than OEM 12v batteries, other than being slightly higher quality...
  12. dolj
    dolj Senior Member
    8,217
    4,187
    If you say so. So every single aftermarket AGM battery is slightly better than the OEM? Oh, except for the Optima yellowtop, right?
  13. PriusCamper
    12,064
    4,896
    As per frequent discussion the amp-hour rating for a Prius battery is more important than cold cranking amps rating. There are plenty of batteries that are both better and worse than OEM...
    I bought my battery for $100 and put it in my Prius in Jan2013... It's still in the car and still works pretty good because it has 55 amp-hours. What's more I've bought a 1/2 dozen of these for other Prius for $100, also without issue: 12 Volt (12V) 55 Amp (55Ah) VRLA AGM Sealed Lead Acid Battery 55 AMPS HIGH CAP | eBay
