new battery mpg less than previous?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by James Milbourne, Jun 5, 2023.
  1. James Milbourne
    James Milbourne New Member
    Austin, TX
    2013 Prius v wagon
    Hello Folks!
    I just had to replace my 10 year old Prius V battery. Done at the dealership, where I have serviced the car, since I purchased it. With the old battery, the average mpg was about 38.0. VERY consistent. Now with the new battery, the average mileage is jumping around LIKE CRAZY!! Showing me much lower - and much higher than you would expect. Is there some sort of "reset" necessary, or calibration? I'm perplexed!
    Thanks in advance for any input!
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Replacing the battery without maintaining 12v power on the car may have reset the long-term MPG, visible on ‘DISP’, which would have been very steady. You are now building a drive by drive replacement for long-term MPG.
    Tim Jones likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    Toggle the Display button to Average rather than Instantaneous. There are separate mpgs for Trip A and Trip B along with overall.
  4. James Milbourne
    Austin, TX
    2013 Prius v wagon
    thanks for your speedy reply! I'm aware of the differences in settings between the "MPG (current)" and the "avg. MPG". The avg. setting had been acting almost as crazy (volatile) as the current. In the last 24 hours, it seems to have settled considerably. (only going up and down 1 to 3 miles at a time. Maybe it is self calibrating? (wishful thinking on my part! ha, ha)
    Thanks again!
  5. Air_Boss
    3,952
    1,083
    New Yawk
    As earlier noted, you are now building a drive-by-drive replacement for long-term (average) MPG, which will go up and down by the drive, until the long-term average stabilizes.
  6. rjparker
    7,975
    4,716
    Texas Hill Country
    The trip averages can be reset anytime. I usually reset Trip A with every fillup. It takes maybe 30 miles to settle. Realize avg mpg is built with instantaneous readings that vary from 99 to 15 mpg all the time. If the hybrid battery is low after a reset charging it takes a short time mpg hit.
    The overall odo mpg normally does not reset but your shop may have done it.
  7. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    38 is not very good............. I always got 42/43
  8. Air_Boss
    3,952
    1,083
    New Yawk
    In my recent experience, a dead-dead 12V aux battery resets LT AVG MPG (but not ODO) and anything connected to the OBD2 port.
