new body old heart engine and transmission transfer
Discussion in 'Gen 2 Prius Main Forum' started by Peter Vawter, May 8, 2023.
  1. Peter Vawter
    Peter Vawter Junior Member
    39
    Michigan
    Okay all here's my conundrum
    I have an amazing Prius that recently had a transmission replaced, all four shocks and struts, catalytic converter, has a trailer hitch and has been modified to a Pico camper that I love to take on trips.
    In other words my car is absolutely perfect in every way.
    However I live in Michigan and it's slowly killing the body of my car.
    It's not what I would call bad but today when I rotated my tires the large Jack went up into the frame a little bit more than I wanted it to where I have some rest in the back.
    I recently found a beautiful Prius near my home for a semi-reasonable price whose engine has just developed some knocking
    I was wondering if you all thought it would be worth buying and transferring the parts of my car that work into that year newer Prius.
    I'm disabled so a good deal of this work would possibly have to be done by a mechanic or by me over months and months of time.
    In all honesty I don't care how my car looks if I could take body parts from the other car and attach it I don't care either I only care if my frame wraps out underneath me.
    So I'm open to that as well
    Truth be told I probably have years left on my car but I like it so much I don't want to be without one and could see it going for easily a couple hundred thousand more miles
    Thank you all for your wisdom and insight on this
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,013
    6,902
    Texas Hill Country
    Sure. Have someone drop the front subframe with engine and transaxle on both cars and swap them.
    douglasjre likes this.
  3. Peter Vawter
    39
    Michigan
    That was my hope and hopefully they could take my struts with it LOL
    Just didn't know what kind of pain that would be with all the electrical side of things I've really never done that kind of work
  4. rjparker
    11,013
    6,902
    Texas Hill Country
    It would be a couple of days job, ideally by a shop that has a lift. Not cheap due to the manhours but relatively straightforward.
  5. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    It's all plug and play you'll be going from first generation generation 2 or the second iteration to the second iteration You don't want to try and flip flop in between the two so you're working on '04 to '06 or '07 to '09 as long as you're doing that you're in good shape your struts can go with it all of that..
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Hasn't been online in quite sometime, but you might inquire with MilkyWay | PriusChat regarding a local mechanic.
  7. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    I would put your current vehicle in the air and assess it more carefully before making a determination about what you should do. Very often you don't need to do anything yet. Car prices will probably hit the bottom in January coming up
