New brakes squeaking/creaking
Discussion in 'Gen 3 Prius Main Forum' started by markjosh51, Feb 5, 2020.
  1. markjosh51
    markjosh51 Junior Member
    42
    North Hollywood
    2014 Prius two
    Today I had my front brakes resurfaced and new brake pads put in. It was fine until I started driving in the afternoon. Now that I brake I hear this squeaking/ creaking sound, kind sounds like an old wooden chair, when braking usually at low speeds. Is this normal after a brake job? I do stop more quickly then before.
  2. Bibster
    Bibster Junior Member
    28
    România
    Not an expert here but it's not uncommon for new brake pads to squeak until they are worn in. There maybe more than one reason for this and I will leave it to others to give you more informed advice.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Did a prius experienced mechanic do this work?
    I just ask because there are a few differences then regular non hybrid brakes.
    You could try (safely) to drive and pop it in neutral and brake gently to see if anything clears up
    May take quite a few times to get them to conform nicely.
    In the rear, there is the caliper piston, with an X pattern which has to seat correctly to the brake bad.
    Possible if things dont clear up that this is off.
    You could also let the ones that did the work to check them, as if anything is wrong,
    they would be the one to make sure it is right.
    Grit and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius?
    Any reason for the brake work?
    How many miles have you added since the brake work?
    Grit likes this.
  5. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    You need to take it back. They probably didn't put the anti-squeal plates on the pads.
    Because usually pads do not include new ones. They should have reused the old ones.
    You just clean them up. And they probably didn't put any anti-squeal on the caliper or pads.
    And more than likely, didn't clean and re-lube the slide pins.
    Cosmo Tigato and dig4dirt like this.
  6. markjosh51
    42
    North Hollywood
    The reason why I did a brake job was because the rotors were warped. When I would brake at high speeds the steering wheel would shake.
    I have only added 100 miles.
    ASRDogman likes this.
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    o_Oo_Oo_Oo_O
  8. markjosh51
    42
    North Hollywood
    Really? I thought the brake changing process is the same as any other car. I took it to a mechanic who does basic work. I haven’t seen any hybrids so far.
  9. Mendel Leisk
    38,700
    Well, yes and no.
    The fronts are pretty straightforward. The caliper pistons are plastic ; you want to use caution if pushing them back: have uniform bearing on the full perimeter of the piston, a piece of plywood, the old pad, whatever.
    The rears are a little tricky: the integrated parking brake mechanism requires piston orientation to be so that the cross pattern on the face is like an "X", and the brakes must be well seated with the piston in that orientation. I'd recommend to test drive the car after rear brake service, then apply/release the parking brake a few times, raise the rear and verify the wheels are spinning semi-freely.
    For both the front and rears, you want to ensure the everything's well seated, so the car doesn't detect excess brake travel, throw a code.
    And last but not least: for a DIY'r, or basically anyone without techstream, it's advisable to disconnect the 12 volt battery at the outset, and when all done pump the brake pedal multiple times, and only then reconnect the 12 volt. One issue if you don't: opening the driver's door (and possibly other behaviours?) will very likely activate the brake pressurizing system, and if the caliper's off the rotor when this happens, it will likely pop the piston out.
    dig4dirt likes this.
  10. markjosh51
    42
    North Hollywood
    Update: so I went back to my mechanic they checked them but could not find anything wrong. I still hear the noise. I don’t know if maybe it could be the brand of the brake pads. Maybe I just need to break them in.
  11. ASRDogman
    6,084
    3,271
    Did they just "look" at the brakes? Or did they pull the pads???
    Do they only squeak when applying the brakes, or all the time?
    You can look through the wheel and see if you see any black or gray paste on the pads.
    The back half.
  12. Kenny94945
    Kenny94945 Active Member
    783
    399
    Sausalito
    2016 Prius v wagon
    If only change was new rotors and new pads....
    This is not normal.
    Creaking noise as opposed to squeal is concerning.
    Maybe the parts were not correct torqued upon recall?
    I would suggest you re-bed the pads.
    Get up to speed, brake hard, let brakes cool repeat maybe 5 to 10 time to be sure.
    Internet will offer the proper bedding procedure.
    One last comment, maybe clean the rotor (deglaze/ de grease) before re-bedding.
    Good luck.
  13. Mendel Leisk
    38,700
    Honda advocates a uniform application of anti-seize on all points of contact, ie between the pad backs and shims, and the shims and calipers. When I had Honda dealership doing our Accord brakes you would always see a uniform line of "squeeze out", all the way 'round.
    Toyota OTOH, recommends a lttle dab or two only, at specific spots. And their official stuff seems like a clear gel.
    So depending on the mechanic's school of thought, hard to say what to look for.
    I employ the Honda method, for what it's worth.
  14. Glee217
    Glee217 Junior Member
    Sf Cali
    Speaking of brakes.
    I just chatted with Lucious Garage in Sf and they specialize in hybrids for over 10 yrs and said the brake fluid on a 2014 Prius iii (3rd gen) DOES NOT need brake fluid changed unless there is a compelling reason to do so. And same for the power steering fluid. So I asked further what if both fluids discolor and not look original with many miles? Same answer lol
  15. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    I agree on the power steering on a Gen3
    Because it doesnt have it
    edit: maybe you meant coolant?
    but toyo does recommend changing both engine and inverter
  16. Glee217
    Sf Cali
    oh so no peer steering fluid lol ‍♂️
    But for brake fluid I am still baffled
  17. ASRDogman
    6,084
    3,271
    Brake fluid absorbs moisture in the air. Moisture is NOT good for the inside of the brake system.
    The brake system is not a sealed system, it's exposed to the air.
    DOT3 fluid should be changed every 2 years. Some say 3 years. The longer you wait,
    the more possible damage to the brake system.
    But you could wait 10 year if you want. You could also wait 50,000 miles to change your oil....
  18. ASRDogman
    6,084
    3,271
    When I pull the pads, I see where there the shiniest, and where the two parts rub.
    That's where I put the paste. Not a lot, just enough to cover it. Too much attracts more dirt.
    I also clean up all the area so they are clean before applying.
    Glee217 and Mendel Leisk like this.
  19. bettergolf
    bettergolf Active Member
    424
    339
    Sanford NC
    All that being said,,,,I've never changed any brake fluid in any car I've ever owned.....and never had a problem.
    Can you explain how it's exposed to the air?
  20. ASRDogman
    6,084
    3,271
    "The brake system is not a sealed system, it's exposed to the air."
    Through the cap.
