New car shopping
Discussion in 'Gen 2 Prius Main Forum' started by thefly, May 13, 2005.
  1. thefly
    thefly New Member
    I'm in the market for a new car. Something between small and midsize, wagon/hatchback preferable. I noticed that the Prius is actually categorized as a midsize.... do you think it would fit in for what I need? Also, I'm quite tall.... about 6'3", mostly legs. How are the Prius's front seats for legroom?
    And one last question, I read on Road & Track's website that the Prius's "auxillary battery" (?) may not be able to start the vehicle if it is left to sit for a few weeks... they even claim a Toyota rep. told them that. How true is this, honestly? (I know it'll be mostly Prius loyalists here, understandably, but please be as honest as possible in your answers)
    Thank you!
  2. popsrcr
    popsrcr New Member
    232
    Richmond, VA
    I believe the non- starting bit is only if you leave the smart key stuff on. Turn that off when you go away for trips. Don't know *how* true that is, but better safe than sorry.
    As far as size, I'd say try it. There is plenty of leg room, but obviously that could compromise rear leg room.
  3. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    My salesman was 6'5" and he did not have a problem in the front seats, however, he did mention he had to slouch to sit in the back seats due to the hump of the cabin being over the front seats so his head hit the top in the back seats.
    The car can be left for at least 6 weeks with no problem. Just shut off the RF smart key transmitter (small button under your steering wheel). To get in the car when you get back just use the remote buttons.
    I am not sure what the Honda Civic was categorized but it is much bigger than the Civic and comparable to the Accord in size.
  4. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    The aux battery (12V lead acid, like in a regular car, but smaller) is used to power the locks, lights, etc. when the car's not on. There is always some drain and due to its small size, not using the car for an extended period can drain it too far. Two weeks is definately safe, many have reported four weeks with no problems, and after that is iffy. Turning off SKS and leaving headlight switch off reduces the drain.
    The good news is that battery doesn't actually start the engine, just powers the electronics to put the car in ready for the big friction battery to come online. So if your battery is dead you only need a small amount of juice to start the car, any portable jumpstarter, even a tiny one, will work. People have put together all kinds of devices with small batteries for jumps. Also, you can disconnect the battery if you're away for a long period (eliminate the trickle drain), use a solar battery charger or battery tender to keep the battery topped off. Starting the car for a short period (~20mins) every few weeks also keeps the battery full.. it charges quickly from the traction battery thru the converter, not the engine itself, so the engine doesn't have to run nor the car be driven, just be in "READY"
    If you look around you will find more info than you ever would possibly want to know about the subject. Again, unless you're leaving the car for 4+ weeks it's not an issue. If you are and don't plan ahead, the worst that happens is you need a small amount of juice, much less than a regular jumpstart, so you have lots of options.
    (I have a 12V plug on my cordless air compressor that I hook directly to the battery if need be...thou truthfully I've never gone dead, except on purpose to test my backup system)
  5. thefly
    thefly New Member
    The Accord? That would be plenty of room. I'm thinking of family of 3 + a small dog, and all their luggage on the occasional road trip.
    Are dealerships still charging a premium for the car?
    Thanks to everyone for the answers so far!
  6. Dan Gross
    Dan Gross New Member
    38
    Western New York
    I plan on buying for a family of 4, as it does have pretty much the same interior space as a mid-size...
    You shouldn't have to pay a premium, though you may have to wait a while...where are you located, Mr. Dickinson? ;)
  7. thefly
    thefly New Member
    I'll be buying a new car, whatever I choose, at the end of July. I'll be buying in either NC or TX.
  8. AnOldHouse
    AnOldHouse Member
    677
    Middlesex County, Connecticut
    That varies by region and dealership. In Connecticut, of the 9 dealerships I contacted, 4 were charging premiums. Of course, they immediately lost any chance of a sale with me. The other 5 are doing MSRP only.
    Here's a fairly new resource for this kind of information: http://www.hybridcars.com/pricepulse/index.php
    It will only get better when more people contribute their market experiences as well, helping to steer new buyers to decent dealers.
  9. Tideland Prius
    16,161
    Civic is classified as Compact, Accord as Mid-Size.
    It should be sufficient for a family of 3 + dog. There are lotsa cubby holes for knicks and knacks. The hatchback design is useful for large goods and the seats fold down almost flat. The front seats can be fully reclined for those extra long objects if needed. It's a comfortable cruiser though some have mentioned that it may be susceptible to wind.
