new drive belt/loss of mileage
Discussion in 'Gen 2 Prius Technical Discussion' started by swanbeach, Dec 18, 2011.
  1. swanbeach
    swanbeach Junior Member
    Banner Elk, NC
    My 2007 Prius with 85000 mi just went in to dealer for service due to engine warning light. Warning light was due to coolant flow valve need replacement. Okay. done, while there also let them replace drive belt and do front end alignment. Had to take back because light came back on. Air lock in coolant, not bled properly. They took care of it. But... the car now feels like it is stuck in tar. Either high rolling resistance, or engine loading. Going downhill, I lose speed rather than having to use engine braking like normal on that hill. Mileage has dropped by about 15% on same daily round trip.
    Do not notice any unusual wear on tires from the alignment (yet). What might be the cause of this??
  2. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Did the dealer lower the tire pressure?
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    +1 on checking the tire pressure.
    For the record, did you get a report of before and after readings on
    the alignment?
    I don't want to get you bummed out at your dealership if you aren't
    already. But...
    There is the possibility that they set the tension in the serpentine belt
    too tightly. You would most likely notice this by the smell of hot or
    burning rubbber or a hot belt after the engine has run for a while.
    Further, the overly tight belt could lead to early failure of the belt
    tensioner bearing failing.
    Typically, 1/3 to 1/2 in. slack is recommended in the longest run in
    the belt.
    Here are two links for more info:
    Yahoo! Groups
    http://priuschat.com/forums/knowledge-base-articles-discussion/87166-belt-change-how-photos.html
    I'm hoping that I'm way wrong on this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Yes if they did a front end align they usually put tire pressure to the sticker on the door which is quite low like 28 lbs IIRC.
    Pump them back up to 44-42. Thats good for about 3 mpg's.
    God I hope your still not running Goodyear Integrities? :(
    Also your way overdue for Inverter coolant change and trans fluid change. Inverter coolant is pretty easy no special tools needed except a socket to open up the coolant dump in the trans.Trans a a bit trickier but both very easy for a shade tree mechanic.
    Both require putting the front end of the car up on a ramp.
    Oh and I assume your Inverter coolant pump has been replaced for the recall on the car?
