New Goodyear Assurance Fuel Max
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FL Buckeye, Mar 22, 2009.
  1. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    I was doing some looking online today for tires for the Prius and found that Goodyear has a Assurance Fuel Max tire that is suppose to have 27% less rolling resistance that the original Assurance tires. Has anyone here checked them out yet?
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    First I've heard of this tire. Sounds good! Goodyear claims that when tested on a 2008 Honda Civic, a 4% gain in fuel economy. Not sure if it would have any sort of winter traction capability ...
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    the Assurance has been one of their top lines of tires, I assume that it is from the same mold (same tread pattern) as the regular Assurance but has a slightly different rubber compound.
  4. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Interesting. It's a mid-tier tire, unlike the TripleTred which is a premium tier tire. Here are some comparisons:
    Fuel Economy: Goodyear says that it should get 4% better highway mpg than the regular mid-tier Assurance tire. I wonder how it would compare to the premium TripleTred.
    Treadwear Warranty: 65,000 miles vs 80,000 miles for the TripleTred.
    TireRack Price (in 195/60/15 size): $81 vs $98 for the TripleTred.
    Available in OEM Size: It's available in the Gen II OEM size of 185/65/15 (unlike the TripleTred, but like the ComforTred).
  5. ualdriver
    ualdriver Member
    358
    62
    Midwest US
    Anyone seen anything comparing this new tire to other tires as far as wet traction, snow traction, ice traction, etc.?
  6. Boo
    5,051
    483
    97
    Flushing, NY
  7. ualdriver
    ualdriver Member
    358
    62
    Midwest US
    Bummer, they rate the Fuel Max tire with the same snow traction as the Integrity.
  8. jayman
    13,439
    640
    Winnipeg Manitoba
    If I lived in CO or any place with real winter conditions, I'd run "real" snow tires, preferably factory studded like the Nokian's
  9. Boo
    5,051
    483
    97
    Flushing, NY
  10. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    I found them on Tire Rack's web site, shows good pic of the tread pattern. Too new for any reviews yet.
    Goodyear's site give them better ratings than the OEM Integrity tires.
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Interesting... 195/60/15 is 1lbs lighter than 185/65/15. This makes the plus sizing to 195mm wide without weight penalty compare to the Integrity OEM size.
  12. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    Tom, are these "mid-tier" and "premium-tier" official designations? If so, what determines a tire's tier?
    I am having a wretched time trying to find a replacement tires for my '04. I would really like a lower rolling resistant tire than the original Integrities, but that info is no where to be found. Lots of opinions out there, including on this site, but no hard data that I can find. These Max Fuels at least have a sidewall 51 psi rating. Is anyone running them higher? They also have a 65,000 mile warranty, which is better than the pending Michelin EnergySaver, with no warranty and an expected 35-40,000 mile treadlife.
    PA P
  13. Boo
    5,051
    483
    97
    Flushing, NY
    Those were TireRack's terms, I think based on price and performance. But really, when you think about it, they may as well be Goodyear's terms too, given Goodyear's own performance ratings of its tires.
    See: Goodyear Tires | Car And Minivan Tires | Compare Tires
    The part I thought interesting was that Goodyear decided to use the new tread compound on its mid-tier Assurance tire. As a fan of the premium-tier Assurance TripleTred, I would have liked it if Goodyear came out with a TripleTred with the same tread compound.
    I know what you mean about the lack of real data on rolling resistance of tires. But I'm also pretty confident that the Fuel Max will be among the lowest rolling resistance tires out there.
  14. tbradway
    tbradway Junior Member
    cary nc
    just bought the tire in 195/60/15 at discount tire cary nc
    seems like a small mpg hit but i have only driven 30 miles i will post again after trip to fla. running 48/46 but might go to 51/49
    so far i like the handling better but will know more once i get on highway and let some semis go by . stock tires were kind of squirly in wind.
    kind of wish i had stayed with the 185/65/15 stock size for a better comparison with the integrities. although 195's are only .4 inch wider.
  15. jayman
    13,439
    640
    Winnipeg Manitoba
    Awwwww what a cute baby
  16. Rakimb17
    Rakimb17 Junior Member
    48
    Palmdale CA
    Anymore info here? Its tire time for me and i'm debating between the Assurance Comorted and the fuel max.
  17. Boo
    5,051
    483
    97
    Flushing, NY
    You might want to check out the other Fuel Max threads. Here are the results from searching titles for the phrase "Fuel Max":
    PriusChat Forums - Search Results
  18. PA Prius
    754
    241
    SE Pennsylvania
    I continue to be pleased with our Fuel Max. They are quieter than the Integrities and as they break in I can imagine the rolling resistance will be lower than the Integrities, especially with the higher side wall psi max. I'm running ours in the mid 50's.
    PA P
  19. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A "Premium Tier" choice would be the Nokian WRg2. They should also beat the Integrity junk in MPG (by about 4%), have great traction in bad weather, handle well and are quiet (unlike the older WRs). I just put a set of WRg2s on as my WRs were worn out at 47,000 miles (the WRg2's should last a little longer with their less aggressive tread design). They were $525 installed at a local tire shop (luckily I found one in West Haven, CT that carried Nokians that didn't overcharge for them).
    JeffD
    ps. It's generally not a good idea to go over the rated sidewall PSI. I am in the habit of running my Prius tires at 42/40 since the first two sets of tires were rated at 44 PSI cold (Integrity and Michelin MXV4+). The Nokians (both WR and WRg2) were/are rated at 51 PSI.
  20. jayman
    13,439
    640
    Winnipeg Manitoba
    I'd go with the Fuel Max. Although the Comfortred will absolutely help ride quality, most who run this tire report a fuel economy loss.
    If you have really bad streets where you live, or have to bounce down washboardy gravel roads, then the ComforTred is for you
