New guy here! I'm having brake issues and need help.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jasoncarguy, Sep 25, 2018.
  1. jasoncarguy
    jasoncarguy New Member
    MInneapolis, MN
    I just bought a 2010 Prius, level II trim, and I have to do some brake work on it. It has 230K miles on it, although the motor has been replaced at some point. Supposedly the brake accumulator went out and was replaced. Currently, there is a constant low-level hissing noise and the accumulator pump cycles every 5 to 7 seconds. The ABS/Brake/Stability control lights are on. I'm getting codes c1214 hydraulic control system malfuntion and c1391, abnormal leak in accumulator. My question(s) are: Is it possible something was not connected correctly when accumulator was replaced? Or is the accumulator (or something else) kapoot?
    THanks, Jason
  2. Mendel Leisk
    41,928
    @ChapmanF is one member that's pretty conversant in this stuff. My mentioning his name will give him an alert.
    jasoncarguy likes this.
  3. Mendel Leisk
    41,928
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I received Customer Support Program ZJB a couple of days ago.
    It doesn't list the DTC needed for this warranty work. "Coverage applies to the brake booster and brake booster pump assemblies. If the condition is verified the vehicle will be repaired with a new brake booster and brake booster pump assemblies under the terms of this Customer Support Program."
    "The primary coverage will be offered until November 30, 2019 regardless of mileage. Secondary coverage is applicable for 10 years from the date of first use or 150000 miles whichever comes first."
    Either call Toyota 1-888-270-9371 or the dealer to confirm ZJB applies to your car. If so, take it to the dealer. There is a mechanism to recover the cost of prior repairs as well.
  5. JC91006
    16,833
    8,603
    Who did the repairs on your car? The Gen 3 cars have both an accumulator pump and actuator pump for the brakes. Sometimes mechanics that are not too familiar with the Prius may confuse the two items. So you should make sure the correct part was replaced by the mechanic
    Raytheeagle likes this.
  6. Mendel Leisk
    41,928
    Somehow I though OP had 2nd gen, need more coffee.
  7. ChapmanF
    18,569
    The codes are telling you the same thing your ears are: pressure isn't being held in the accumulator, and the pump has to keep cycling to pump it back up.
    A leak can be external (fluid escaping the system somewhere) or internal (some valve in the hydraulic system isn't closing completely, fluid is just returning back to the reservoir in the usual way).
    If yours is leaking so constantly and so fast that you hear the hiss, and the pump has to cycle every several seconds, I'm guessing you don't have an external leak. You'd have a lake of brake fluid under the car by now if you did. So you have an internal leak; a valve somewhere is letting the pumped-up fluid hiss right back to the reservoir.
    You've got a Gen 3, so there are parts of this story in two different assemblies. The accumulator assembly has the pump itself, and the pressure vessel that stores the fluid, and one relief valve. That is one place the hissing could be happening. On the other hand, all the rest of the valves in the system (about a dozen) are in the other, ac·tu·a·tor assembly.
    Although those are two separate parts, you have to remember they're an interconnected system in practice. It can easily be one of the valves in the ac·tu·a·tor that is really where the fluid is leaking when the ac·cum·u·la·tor isn't holding pressure.
    Sometimes the one-liner "fortune cookies" you can pull up for the trouble codes are no help there. If a mechanic reads a code that fortunes out as "abnormal leak in accumulator", he might just buy an accumulator and swap it in, instead of stopping to think, wait a minute, the ac·cum·u·la·tor pressure being lost could still be due to a problem in the ac·tu·a·tor, so I'd better figure out which it is before I buy one and swap it.
    That's what I would guess happened here.
    Since yours is leaking fast enough that you can hear a hiss, I bet you'd be able to touch your accumulator and your actuator with the end of a mechanic's stethoscope and find the culprit in one step.
    Under support campaign ZJB, you might be able to get the actuator swapped at no charge at the dealer (and maybe even reimbursement for the already-swapped accumulator, if you paid for that).
    -Chap
