New Guy needs help please...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Fireboy, Apr 29, 2015.
  1. Fireboy
    Fireboy New Member
    29
    South Carolina
    I have a 2012 Prius four, and I want to order center caps for the stock wheels. Are they 55mm or 57mm? IMG_5540.jpg
  2. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
    57mm
    or if you do the Home Depot fix with knockout seals, then its 1 1/2"
  3. Fireboy
    Fireboy New Member
    29
    South Carolina
    Thanks Starbrand. These wheels were black this morning. I spent a rainy day making them look better. IMG_5541.jpg IMG_5536.jpg
    xliderider likes this.
  4. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    I see you have Michelin Defender's on the wheels. I just put on a set. What are you're thoughts on them? Have you run them through winter?
    Ryan
  5. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    What did you do to them? I hate the black with my Blizzard Pearl, so I've left the covers on.
  6. Fireboy
    Fireboy New Member
    29
    South Carolina
    I have only had the car for a week. I picked this car over another because of the color and the tires. I really like Michelin tires. So far the tires are very smooth and quiet. As far as the wheels go, I cleaned the crap out of them with some Brillo pads to scuff them up. Then I taped off the tires and cleaned the wheels with pre-paint. I put a couple coats of light gray primer, then a few coats of Duplicolor silver Wheel Enamel, followed by a few coats of Rustoleum Crystal Clear enamel(way cheaper than the Duplicolor clear and available at Walmart for $3.87 a can). I'll install the caps tomorrow. IMG_5540.jpg IMG_5538.jpg
  7. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
    It doesn't look like you need much help after all. :)
    Nice work.
  8. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Nice job, thanks for posting photos.
  9. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    FYI, 55mm is the inner diameter of the centerbore on the back of the wheel to fit the hub.
    On the centerbore on the front, you can see that it expands out a little bit where the lip is. So the center cap will have to be slightly larger than 55mm to fit.
  10. Mendel Leisk
    38,702
    Looks very nice. It's a head-shaker for me, why Toyota switched to black rims. That and charging a small fortune for bit of chromed plastic centre cap.
    I would think their intent is to further discourage people from pulling the plastic wheel covers off, on their "flagship" vehicle. Seems like they're at loggerheads with their customers, not the brightest tactic.
    (If you get the centre cap from a dealership parts department, I don't think you need to tell them the diameter, they can verify.
    #10 Mendel Leisk, May 1, 2015
    Christopher O'Brien likes this.
  11. Fireboy
    Fireboy New Member
    29
    South Carolina
    I painted the knock out plugs blue to add a little pop to the silver wheels. There's touches of blue all over the car so I thought it would work. Me likey. IMG_5546.jpg IMG_5545.jpg
    Dylan Doxey and Rhinoruns like this.
  12. Dylan Doxey
    1,389
    3,455
    92
    How about a blue shark fin?
  13. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    [​IMG] Amazon. com $25 for set .Same size front or rear on 2010
  14. Fireboy
    Fireboy New Member
    29
    South Carolina
    That actually isn't a bad idea!
    Dylan Doxey likes this.
