New HV battery and doesn't run
Discussion in 'Gen 2 Prius Technical Discussion' started by Cybersurgeon, Jan 25, 2020.
  1. Cybersurgeon
    Cybersurgeon Junior Member
    45
    Reno,NV
    Four Touring
    I installed a new HV battery that I got from NewPriusBatteries.com and guess what? All I get is an intermittent buzzing sound in the engine and all kinds of lights in the dash, including the red triangle of death.... :( . I give up. I've attached a picture of the dash.
    52,350
    did you reinstall the orange safety switch properly? third step sliding it over?
    Raytheeagle likes this.
  3. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I installed a new HV battery from NewPriusBatteries.com and guess what???? All is get is an intermittent buzzing sound in the engine compartment.... I also get all kinds of lights including the “triangle of death” in the dash. I give up!!!!! :(. I don’t have a code reader as it’s in my garage. I tried jumping it and that didn’t work. It just sits there and buzzes. Anyone want a good deal on a used Prius in Reno?
    52,350
    did u do all 3 steps of the orange safety plug?
    SFO and VFerdman like this.
  5. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    Check the safety plug. Make sure it’s in the proper way. Without it you do not have an hv battery.
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Check the safety plug dude
    VFerdman likes this.
  7. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    I don't think you have, but even if you did, it is not really much use. What you need to do is run the codes and post them up here.
    But like bisco said, check you installed the orange safety interlock correctly.
    Prius safety Interlock.jpg .
    You should be aware that if you disconnected the 12 V battery at any stage, you will need to press the power button with your foot ON the brake twice to get the car to go READY. The first press will be as if it only went to IG-ON.
    Let us know how you got on.
    ydpplqbd likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  9. Cybersurgeon
    45
    Reno,NV
    Four Touring
    What 3 steps? So, obviously, no. I put it in and set it “locked” it. That’s all...
  10. Cybersurgeon
    45
    Reno,NV
    Four Touring
    Thanks all for the tips... Tomorrow, I’ll re-check the Orange HV plus and try the steps listed above to start it. I think I can get a code reader from O’Reillys? Or where? To see what the code # is... So I can post those #’s here... I’m a newbie to this and I appreciate everyone’s help.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Its usually the orange switch. Everyone forgets to slide it down.
    And many have killed there 12 volt battery leaving the doors open while installing that battery. Check the 12 volt jump point under the hood and see what the battery reads there. Not at the battery in the trunk at the front jump point.
    Check the voltage there. Then with car OFF turn on the headlights in high beam and while lights on and car off read that voltage again. That is the true voltage the car is seeing when you hit the ready button. That's what the battery will supply under a very small load.
    Also most autoparts store obd readers are not hybrid capable and cannot interrogate the hybrid battery so don't be surprised if they cant harvest the codes.
  12. bisco
    52,350
    plug in, snap down, and slide to complete. you can find a video on youtube
  13. George W
    George W Senior Member
    911
    514
    San Antonio
    Were their any steps in the DIY manual which were not clear? 15800538499783852680623225211742.jpg
  14. bisco
    52,350
    if the safety switch doesn't help, contact newpriusbatteries before going to more trouble and expense.
  15. Cybersurgeon
    45
    Reno,NV
    Four Touring
    Oh yeah. I’m a newbie to this and shouldn’t have done it. The instructions were ok. They don’t have live tech support only email. I got the battery done (after 20 emails) I think correctly or the dash wouldn’t show the charge level on the dash? It has the red triangle of death
  16. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I did that and triple checked it. It just lights up and nothing happens. Just the buzzing by the Inverter and all the lights on the dash. Here's a picture.
  17. Cybersurgeon
    45
    Reno,NV
    Four Touring
  18. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I've tripled checked the Orange Safety Interlock and it's installed correctly. Here is the picture of the dash. It just buzzes intermitenly (sp) by the inverter box in the engine compartment and doesn't do anything. I've ordered a scanner from Amazon and will download the app when it comes in.
  19. Cybersurgeon
    45
    Reno,NV
    Four Touring
    Yes and it's inserted correctly.
  20. bisco
    52,350
    do we know the problems before you replaced the hybrid battery?
