New hybrid battery. How often do I need to drive?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chizet, Jun 28, 2020.
  1. chizet
    chizet Junior Member
    My 2007 Gen2 hybrid battery died at the beginning of the pandemic. It's time to get a new battery but I still don't plan on driving super-often. Is that okay? Is there a minimum amount of time(s) I should drive it? Is this even an issue?
    TIA
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    If you're buying a new from the dealer OEM replacement, you'll be fine. But do drive it around or keep it 'ready' to maintain the 12v battery.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. The HV battery doesn't much care now often or how little it is used.
    The 12 V does though.
    kenoarto likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,512
    6,597
    Texas Hill Country
    There are plenty of reasons including your batteries to warm up and drive the car every 7-14 days. You want to avoid flat spotting your tires, reduce excessive rotor rust, lubricate the top of the engine, exercise seals especially brakes & ac, circulate the coolant systems, etc.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    YES. But a "drive" of less than 5 minutes doesn't really count.
    30 minutes total "ON" time or more to properly exercise everything.
