New Hybrid battery or electrical issue??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sue8950, Dec 26, 2013.
  1. Sue8950
    Sue8950 New Member
    We have a 2005 Prius which died while I was driving it to work and I had it towed to the Toyota dealership in the town I work in (Colorado). The car has 171,000 miles on it. We would like to keep the car and wanted to get it fixed. The dealership said the hybrid battery had died. They happened to have a new battery they had installed in a car where the owner decided not to purchase it which they said they would sell us at a discount. They installed the battery in our car and are now saying it won't 'communicate' with the charging system because they believe there's some type of wiring issue. There's a fuse that they say was missing from the car and when they install a new one, lights, the horn and other electrical items come on. They say it will cost $1000 - $1500 to further diagnose the wiring harness by going through each wire and determining whether it's bad. They also are not sure if the battery is bad or just the wiring. They've had the car for almost 4 weeks and we think their service stinks. It seems like it's been a struggle to get info from them.
    Any thoughts on other options for us? Is there any options besides the 'we buy junk cars' companies we could sell the car to?
    51,155
    welcome to priuschat! have you paid anything yet? i would tell them to put the old battery back in and take it to another dealer. or look for a shoppe that does hybrid work. where are you located?
  3. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    ...also thinking there is Colorado private battery replacement shop online here at PriusChat (3prongpaul?)
    51,155
    seeing they were willing to install it in the person's car and then remove it, they will probably do the same for you. i don't quite understand the missing fuse part. where would it go on a car that was working fine up until it broke down? how does the wiring harness come into play? it sounds to me like they don't have a goos grasp on what they are doing. i wonder if your battery was really bad to begin with or if it was another issue such as your 12v?
  5. Sue8950
    Sue8950 New Member
    The car is in Fort Collins, Colorado. I work here and it died here. I live in Longmont.
  6. Sue8950
    Sue8950 New Member
    I feel like they're focusing on the missing fuse because they think it's related to a wiring issue that is causing the system to not charge the battery. They put a good battery in it but it won't stay charged. The fuse was missing and when they replaced it, 'odd' things happen, like the horn comes on and won't go off. I wasn't aware of the missing fuse, but it must have been missing since I've owned the car (3 years). I don't understand how it would be related to the issue either. Yes, there's a strong possibility that the battery is not bad.
  7. bisco
    51,155
    if the fuse had been 'missing', you likely would have noticed something not working. every fuse has a purpose and when it blows, it is obvious to the driver at some point. if it is missing, same symptoms would show up.
  8. bisco
    51,155
    i agree with wjtracy above, pm 3prongpaul. he is in boulder and is a trusted member and expert prius repair shop. if he's too far, he will at least give you some good advice. all the best!(y)
  9. Sue8950
    Sue8950 New Member
    Thanks, I've contacted him.
  10. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I agree that something is fishy with the dealer diagnosis re: the fuse. If possible ask them which fuse exactly that it is, and let us know. Also, please find out what the DTC ("codes") were that the dealer read, and list them for better advice.
    While you may indeed have wiring problems somewhere, the fact that the car has been working all this time says that it may not be not the reason for the new battery install to not work. Tracing bad wiring is time consuming and in general a pain. Sometimes it happens as a result of rodent damage, in which case it is often visually apparent, but requires some digging to expose. If it is possible that the wiring damage was recent, then that may be related to the recent apparent battery failure.
  11. Sue8950
    Sue8950 New Member
    Thanks for the suggestions. I am towing the car to another shop (3prongpaul). The dealer is removing the battery they installed and I'm towing it elsewhere. I hope to have good news to report after he looks at it.
  12. bisco
    51,155
    i think you're doing the right thing, good luck!
  13. Sue8950
    Sue8950 New Member
    Kudos to 3prongpaul!! Found the problem with my Prius in one day and fixed it in two! The dealership had my car for 30 days, misdiagnosed it, replaced the hybrid battery for no reason, requested $1000 - $1500 to diagnose a wiring issue and never figured out what the issue was. Towed the car to Boulder and Paul discovered the issue in a day and repaired it in two. It was a known issue with a recalled part. Just can't believe the dealership couldn't figure that out.
    I highly recommend Paul. He's knowledgeable, courteous and sensitive to the hassle we had been through.
  14. nh7o
    1,686
    340
    Hawaii
    Could you give us more details on the exact part replaced, and the diagnosis that Paul made? Just for the record here. Maybe Paul himself can describe it.
  15. Sue8950
    Sue8950 New Member
    Yes, I would guess Paul could give better details but the Inverter coolant pump short circuited and blew fuse AM2. He replaced the pump. I included the recall notice below. Our check engine light did not come on, however.
    This is the recall notice:
    On 2004 through certain 2007 model year Prius vehicles, there is a possibility that air may remain at the bearing of the Hybrid Electric Water Pump (HV Water Pump), causing pump actuation to be slow. In this condition, the temperature of the coolant could rise and become high, which will result in illumination of the Malfunction Indicator Light (check engine light “ON”) for diagnostic code P0A93 with information code 346 (Inverter cooling system malfunction).
  16. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,151
    1,701
    Mars Hotel
    This may be along the line of "other than that Mrs. Lincoln, how did you enjoy the play....
    But, how was Pedersen about releasing the car, etc. ? Yes, apparently they did not find the problem, but sometimes even the best of us drop the ball.
    It goes a long way with me about how they handle it all>>>
  17. vskid3
    vskid3 Active Member
    773
    228
    Had the recall been performed on your car? If not, you might be able to get some compensation from Toyota for the dealer failing to do it and giving you this hassle.
  18. Sue8950
    Sue8950 New Member
    No, it hadn't and, yes, I'm contacting Toyota. I believe I should be reimbursed for the repair cost and the cost of the tow. I have a bit of a list of items I'm addressing regarding Pedersen. They also replaced part of my dashboard that needed to be removed to view the wiring with a part from a different Prius. Not happy with them at all.
  19. bisco
    51,155
    if it wasn't taken in for the recall, they may not pay for the tow, but they should reimburse you the alloted amount for the pump change, unless the recall has run out. it really is amazing how poor some of the dealers are at diagnosing fairly simple problems. or perhaps they prefer not to.
  20. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Another example of why it pays to use an independent hybrid expert and not just anyone (Dealers included).
    Paul is one of the best guys out there.
