new line on the 12v
Discussion in 'Gen 2 Prius Main Forum' started by parky, Jan 26, 2008.
  1. parky
    parky New Member
    51
    montana
    There is so much going back and forth on this 12v which I started only a few days ago, I am starting a new thread.
    Question: if you jump start a Prius car (obviously the battery is dead enough not to power up the boards), can you just drive around town - go home, plug in your Battery Tender, and say to your car - see you in the morning? Is this suffficient only for a barely undercharged battery. This is where a voltmeter would come in handy. I am wondering at what point the battery degrades to before it won't flash those computer boards.
    The dealer told me that even if the battery wasn't fully charged upon delivery, in Nov '07, that with two hundred miles on the car it would have come up. As I understand it the charging system only brings the battery up to a certain level but not as high as allowable.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    That is only true for the High Voltage battery not the 12v.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Good questions. If I understand your question:
    The VDC Battery Minder – the new model - is current limited to 1.33 amps and voltage limited to 14.4 vdc. Once float charge level is reached, the current is limited to a range of 5-200 mA and the voltage is limited to 13.4 vdc. These are quite safe values and allow the unit to be used indefinitely on a battery
    Once float charge level is reached, the unit will switch to a desulfation mode to break up any sulfates on the plates. The desulfation works by sending a pulse into the battery of 1 amp at 3.26 MHz. I was concerned this pulse might trigger the car alarm, but after almost 4 years everything is fine
    VDC has the manual for download. According to VDC, a badly discharged battery should be recharged first with a conventional battery charger. A mildly discharged battery can take up to 72 hours to reach float charge level using the Battery Minder. VDC also has an approximate voltage vs SOC (State Of Charge):
    VDC, SOC
    12.7, 100%
    12.5, 75%
    12.3, 50%
    12.1, 25%
    11.8 0%
    If the battery voltage is 11 vdc or lower, the Battery Minder is designed not to work at all. This is a safety feature
    I disagree about the dealer comment. That may be true in warm climates, but in bitter cold climates a Prius delivered with a partially discharged 12 vdc battery will have problems. The voltage-limited charge works fine in warm climates, but in bitter cold temps it can fall short of recharging a battery, especially if severely discharged
    I think a lot of dealers have an incentive to skip parts of the PDI. I sent you the pdf and I’m sure you’ll agree it is quite picky and time consuming. If the dealer can skip the time consuming parts, just wash the car and hand you the fob, the PDI charge on the invoice is money in his pocket
    I’m sure a lot of Prius owners have noticed after picking up their car following a dealer service, the traction battery SOC is lower, sometimes even purple. The lot boy who washed/vacuumed the car probably had it in Ready the entire time. Unless he put the car into Accessory so all the load was on the auxiliary battery, with no charge
    Given the short commute you have, I think it best to use a Battery Minder whenever the car is parked. Saves the hassle of a dead Prius and early – pricey – 12 vdc replacement
  4. parky
    parky New Member
    51
    montana
    11 vdc is not much of a drain on the battery. I would assume then that if my battery tender doesn't work below that (I'll check) the battery needs to go on a charger in order to get the car running for the next outing. I am keeping my voltmeter in the car, a guage (a real one) mounted in the car would be a quick visual check.
    So, driving around town (not hiwy) after a jump start plus the battery tender at home doesn't appear to really boot this battery up to a high working level. Perhaps over a period of time, if the battery doesn't croak again, then the battery tender could get the 12vdc into the 14 v range.
    That is where I have my solar panel batteries operating.
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    I think once the VDC has been in use for awhile, the 12 vdc battery performance will be restored and it will recharge much quicker, plus not be as sensitive to bitter cold temps
    Just do what I do and plug in the Prius whenever it will sit for more than 4-6 hours. Absolutely leave the Battery Minder plugged in overnight
    When I had the condo, I always backed into my assigned space in the underground parking. That way if I forgot to unplug the connector when driving away, it would harmlessly unplug itself. With the house, I also back into the garage for the same reason
    In practise, when I use my Prius for a short trip to get groceries in bitter cold temps, upon return from the store I plug in the harness once I get the bags out of the hatch. Usually within 10-20 mins the green LED is blinking, indicating a float charge has been reached and the unit is actively desulfating the battery
