New Liquid Battery
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Bill Merchant, Mar 8, 2009.
  1. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    We've discussed the various battery technologies, from the archaic 12V lead-acid liquid electrolyte start-up battery to the Ni-MH traction battery, to the projected Li-ion battery for plug-ins. Now Donald Sadoway of MIT has conceived a different battery technology that can handle much higher current loads than any of these:
    In this six-minute video he talks about the battery for fixed installations and specifically says it's not for cars. While his work is aimed at solar power use, the current handling capacity may make a liquid battery ideal for cars. Reported in MIT's Technology Review. I learned about it in a tweet from @followgreen citing an EcoGeek article.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Bill,
    The reason the researcher says it is not for cars is that liquids slosh. This battery does look interesting but the elevated temperatures may put it in the commercial use only category.
    JeffD
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    May make a great home charging station. It would be used for electric cars, just not in the car.
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Liquid Magnesium and sparks would be quite a fire hazard if exposed to air. Definately in the commercial energy storage catagory. The battery room would probably have to be maintained in a CO2, or Nitrogen atmosphere, and the battery canisters would need to be air-tight gasketed, with pressure regulating controls.
  5. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    What happened in a collision, it would explode and burn furiously when ruptured. That's why it is not for cars nor EV.
  6. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Sometimes you just need a better mousetrap ....
    This liquid battery would be ideal for off-grid EV installations, and installations with wind or EV tie-in
    The safety comments posted above are very real.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Oh, I don't know. The Russians had good luck with liquid sodium cooled reactors. :rolleyes:
    Tom
  8. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
  9. jayman
    13,439
    640
    Winnipeg Manitoba
    I thought you were pulling my leg
    Fast Breeder Reactors
    Ok, the rooskies probably didn't use it
  10. qbee42
    18,058
    3,074
    Northern Michigan
    Right you are. It was the U.S. that used liquid sodium. We only used it in one submarine, the USS Seawolf (SSN-575).
    Pratt & Whitney considered liquid metal cooled reactors for nuclear powered aircraft. How would you like to have one of those crash in your back yard?
    Tom
  11. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    It's all good because we desperately need high-capacity *storage*
    for centralized and fixed-distributed generation facilities so
    they can continue cranking out power after the sun goes down
    or the wind subsides. Having it in the electrical domain already
    instead of screwing around with heated sodium or water pumped
    uphill is probably a win.
    _H*
  12. jayman
    13,439
    640
    Winnipeg Manitoba
    It would be exciting, to say the least
    Although very hush-hush at the time, the Atomic Energy Commission - now the Department of Energy - did research into nuclear powered spacecraft. Projects Rover and NERVA contributed to the design of spacecraft and even aircraft nuclear propulsion systems
    Rocket science ::
    http://area51specialprojects.com/nerva.html
    NUCLEAR ROCKET PROPULSION - THE 1960S - Nuclear Thermal Propulsion
    In hindsight, am pretty glad we don't have to worry about fallout raining down after every rocket launch
  13. jayman
    13,439
    640
    Winnipeg Manitoba
    That is the ideal facility to use such a battery. A properly engineered and maintained battery complex at such a facility would be far safer than allowing it in a home PV environment
  14. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Actually when I was at the Idaho National Labs decades ago, I had lunch with an old timer. He described the initial testing of the nuclear powered airplane engine. In one static test, there was a fuel element failure. The unique aspect of a airplane reactor fuel element failure is that is spreads the stuff like it was being blown out of a jet engine.....(er, scratch the word "like".) This resulted in setting off just about every radiation alarm at every site at the lab. Fortunately, the whole setup is in the middle of nowhere. It's amazing some of the craziness pursued back then.
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    the concept is good for certain applications and its a start towards a better solution for cars.
    the concerns over "sloshing" is somewhat valid, but in a container if the liquid and "moltened" components can be thicken up a bit, and airspace removed (if possible) i think it could be a workable solution.
    granted, the thickening process may reduce electron movement and reduce current capacity, but a halfway solution for performance and safety maybe viable... heck, 5 times better than Li is not as good as 10 times but i would consider it
  16. qbee42
    18,058
    3,074
    Northern Michigan
    The problem you describe is referred to as a "free surface problem" in the world of marine engineering. Removal of airspace and tall, narrow containers are the general solution to this problem. Baffles inside of larger tanks are an example of this. They convert the large tank volume into a number of smaller, more narrow volumes.
    Tom
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    oic??.... well "tall and narrow" would be a pretty tough challenge im afraid.
    to be honest with ya, i actually tried this this morning... now granted, it was with by son's breakfast so not completely scientific, but one thing i noticed (now this may change over a much greater period of time) was that semi solids of different densities, especially when separated by a liquid (milk) dont really mix when vibrated like you would see in a car. in fact it required a lot of vertical shaking, something i would think is minimal in a car.
    now granted, if in a high speed chase, it maybe different and with safety regs aimed at the extreme and not the norm, i can see this having to undergo extremely rigorous testing, but i still think (with my very non-scientific mind) its worth investigating
  18. MikeSF
    MikeSF Member
    416
    San Francisco
    Did I overlook something, how do you keep liquid metal a liquid? Magnesium has a melting point over around 1200 °F, don't know about the other "molten metals" in the thing, but I can't imagine that this would be useful in any way except perhaps research on the technology even with the most insulated of containers, keeping the metals in that "molten" state has to use tremendous energy.
  19. qbee42
    18,058
    3,074
    Northern Michigan
    It's not really a problem for a large, stationary application.
    Tom
  20. MikeSF
    MikeSF Member
    416
    San Francisco
    You can keep metal at a temperature of 1200+F for long periods of time? (and by you of course I'm being general). Hell my hot water maker has to kick on every few hours to keep water at around 150°F or whatever it keeps it at.
