New Michelen Primacy MXV4's today :)
Discussion in 'Gen 2 Prius Fuel Economy' started by fishbones, Mar 1, 2011.
  1. fishbones
    fishbones Junior Member
    27
    Michigan
    Ok, I could not take driving on my Goodyear Integity's any longer so I broke down today and picked up a set of Michelen Primacy MXV4's. Discount Tire had a pretty good deal, I got them to match my best local price $487, they had a $70 Michelen rebate and gave me $40 for my old tires so I walked out the door for $365 bucks.
    I have been reading some conflicting information about tire pressure and breaking the new tires in. I ask DT to set them at 42F and 40R.
    I was hoping someone could share there experience with the break in period for this tire.
    Jim
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    42 and 40 is the norm. What is the max. cold setting printed on the sides 51 lbs.? Your safe to what ever that is. Hal
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Nice that they gave you $40 for your old tires. They must have had some tread life remaining. Last time I had to get new tires they charged me 5 bucks a tire to take them.
  4. fishbones
    27
    Michigan
    Thanks Hal, I believe the max inflation is 44psi.
    uart, I still had 6/32 on the tires.
    Thanks
  5. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    Which size did you get? I've had mine for half a year, seem pretty good.
  6. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    I pulled the trigger and went with the Michelin Primacy MXV4 in 185 65/15. I've driven about 300 miles so far the the MPGs have decreased some (around 2 mpg).
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Did you catch the Michelin $70 rebate from TireRack.com or Costco?
  8. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    I think the $70 comes direct from Michelin, doesn't matter where you buy them. At least it did when I got mine over a year ago. Typical mail it in and wait for the check.
    Yeah Max is 44 on the sidewall. I've run mine at 44 - 43 most often, with a pound or so lost between checks. Tire wear is even at 30K miles after having alignment corrected when the tires went on and rotating every 5K miles since. Had alignment checked and corrected again at the one year mark. Break in (in terms of mpg) seemed to settle after the first 2K miles for me.
    - D
