new modules
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wilsid, Aug 27, 2018.
  1. Wilsid
    Wilsid Junior Member
    91
    I need 2 modules & ebay has new ones for $45, has anyone tried these?
    THANKS
  2. audiodave
    audiodave Active Member
    787
    268
    US
    There not new, I'm sure used.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Read the descriptions thoroughly as the $45 modules are USED.
    I did find one person selling new Toyota modules parted from a new pack for $90 and that's the only way you can buy a new module because Toyota (and their supplier) do not sell new modules separately; only as a pack.
  4. JC91006
    16,482
    8,400
    I think we have members that will sell you 2 good tested modules for around $100 shipped.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    If you are fixing a used battery you probably don't want to put in NEW modules. They will be to different than the used ones.
    Stick with used.
  6. Wilsid
    91
    the read out said that 2 were bad, I took them out & 1 read 7.74 v the other 6.29 so I
    got 1 on ebay out of a 2013 for $39 with shipping. while have it out i may as well check them
    all.
    #6 Wilsid, Aug 28, 2018
  7. JC91006
    16,482
    8,400
    This is a classic whack a mole type of repair. You are blindly mixing 2004 modules with 2013 modules. You should have at least bought 2 matching pairs for the block. Gives you a slightly better chance at getting a repair to last more than 30 days
  8. Wilsid
    91
    18 months age i replaced 1 with 1 out out of a 2013, & now am replacing another one. seems to
    work out fine. i think the new ones on ebay are made in china
    Raytheeagle likes this.
  9. JC91006
    16,482
    8,400
    18 months, very nice. Hopefully you get the same result this time.
  10. ericbecky
    4,371
    3,220
    Madison, Wisconsin
    There are new Prius modules available from Asia.
    In the past they have not played well with existing modules. And even a pack of all new Asian cells never faired well. Maybe things have changed, but I'm not going to have my customers take that chance.
  11. fotomoto
    5,602
    3,779
    So. Texas
    Again, please read the entire ad as they are VERY misleading. There aren't any new INDIVIDUAL modules being sold on ebay (only entire packs). Here's just one example of a module designated as "new" but when you read the description it says (bold mine),
    "Hybrid Battery Cell Module Toyota Prius Camry Lexus 6.5ah* by HV HYBRID PARTS Used OEM Hybrid module tested under a heavy 60 Amp load..."
    Hybrid Battery Cell Module For Toyota Prius Camry Lexus Chevy Chrysler NEW | eBay
  12. Wilsid
    91
    i just checked all modules v. they were from 7.50 to 7.74 with a head light bulb on. i think I'll put the 2 from a 2013
    together.
  13. JC91006
    16,482
    8,400
    What does that mean "7.5v to 7.74v with head light bulb on"?
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,228
    5,910
    Columbia, SC
    Wil,
    I would be wary of putting 2 "new" 2013 modules together as one block. That could cause issues with voltage differences. If the 2013s are significantly higher/better capacity, they will have less voltage droop during discharge, and less less voltage increase during charging compared to the older modules. This could cause the ECU to think there is a problem if the voltage difference between the highest and lowest block exceeds its limit. This is why it's important to consider matching replacement modules to the expected characteristics of the remaining modules.
    I'm not saying it won't work, just providing input from experience gained from testing many many many many hundreds of modules
  15. ericbecky
    4,371
    3,220
    Madison, Wisconsin
    It's amazing how crappy modules can be as long as they are all equally crappy.
    Adding in a new, awesome set into a crappy pack is a recipe bfor failure.
  16. Wilsid
    91
    i hook up a halogen blub with both elements (on) to the module then check the v
    i'll put an old one with both 13s
    THANKS
    #16 Wilsid, Aug 28, 2018
  17. JC91006
    16,482
    8,400
    What does this prove? Is there a set time frame on the load? Did you do it to the rest of the pack?
    Usually when people are load testing with a bulb, they record the starting voltage and run it for 120 seconds, then record the ending voltage. You do that to all the modules and you'll see which ones are weak and needing reconditioning/replacement. This is preferably done with a pack that's fully charged.
    Although the load on the bulb is not that great, it'll give you a pretty good idea on which ones will crap out soon.
  18. Wilsid
    91
    i checked the entire battery, when i start car battery discharges so i think i
    have about 40% charge
    #18 Wilsid, Aug 28, 2018
  19. Wilsid
    91
    got the 2013 module sept 1 put it in everything ok for now, drove the car several
    miles sun today all lites are off, put old mod 1st then 2013 mod another old one
    then the old 2013 mod will see how it goes.
  20. swoll001
    swoll001 Junior Member
    Dania
    any updates on how it went?
