Featured New Nissan Qashqai
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Apr 23, 2024.
  1. bwilson4web
    16,437
    Source: Daily Automotive News
    the second [Qashqai rjw] is what Nissan calls e-Power, but this e-Power operates differently than some other e-Power vehicles. It uses a three-cylinder turbo engine to generate electricity for the 140-kW electric motor or send it to the 1.8 kWh battery pack.
    Almost the reverse ratio as my 2017 BMW i3-REx bought used last August. Both vehicles do not have a mechanical or electro-mechanical transmission:
    • Nissan e-power :: BNW I3-REx - metric
    • 143 kW :: 23 kW - ICE power, the BMW has just enough power to sustain 70 mph
    • 1.8 kWh :: 28 kWh - Battery capacity, the 1,8 kWh is similar to my early Prius battery
    Source_2: Nissan Qashqai: the original and now even better
    In keeping with the pioneering spirit that gave birth to the original Qashqai and which invented the crossover segment, e-POWER is the unique and innovative electrified powertrain that has proved so popular with customers since its launch in 2022.
    In the world of engineering, the simplest ideas are often the best. And e-POWER perfectly reflects that principle. The petrol engine generates the electricity which is used to drive the wheels. This is a far simpler solution than the myriad traditional hybrids on-sale today.
    The result of that simplicity is a drive experience which combines responsiveness and refinement with efficiency – with no compromise on driving pleasure. Thanks to e-POWER, customers no longer need to accept a mediocre driving experience as they do with traditional hybrids.
    There is some merit as all of my Prius had very nice acceleration for about 75 yards . . . enough to get across the intersections first. But like a sprinter in a long race, it soon ran out of power. But unlike the Prius that used the hybrid drive to maximize ICE efficiency, the Qashqi will have a challenge with engine efficiency at partial power. How Nissan handles this will be interesting.
    Speculation, ICE efficiency comes from the cylinder operation. It may be possible that using fuel injection and per cylinder valve operation, the three cylinder engine uses 1, 2, or 3 cylinders at peak efficiency and the other cylinders are just a passive, balancing mass. Lacking a mechanical link to the wheels, the battery can buffer any ICE vibrations that would be ordinarily be unacceptable. There are clues suggesting this:
    The sole role of the advanced turbocharged 3-cylinder engine – with variable compression ratio technology – is to generate electricity, which is sent via the inverter to either the 140kW electric motor or the 1.8kwh battery (or both, according to the driving scenario). The engine works quietly in the background to provide the necessary charge to the battery and motor. It's been programmed to provide the electricity in relation to vehicle speed to avoid the disconcerting disconnect between background sound and vehicle progress.
    Gokhan likes this.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    There have been some issues with this engine regarding reliability.
    Also the fuel efficiency is low comparing to the Rav4 hybrid 2.5...
    Which is nothing new, theoretically a serial hybrid fares worse in the energy path.
  3. bwilson4web
    16,437
    Usually I would agree. But I can see a way that a software controlled engine could operate at peak efficiency and achieve similar to ordinary ICE car efficiency.
  4. Trollbait
    12,744
    Not if they are varying engine output to keep the noise at what the driver expects.
  5. telmo744
    2,181
    769
    Portugal
    Real world hybrid match:
    Gasoline consumption: Toyota - RAV 4 - Spritmonitor.de (39.8MPG)
    Gasoline consumption: Nissan - Qashqai - Spritmonitor.de (36.7MPG)
    Gasoline consumption: Honda - CR-V - Spritmonitor.de (35MPG)
    I believe both e-power and Honda "series with a clutch" do better than an ordinary ICE, but TBH there is a proven transaxle design that brings FE to a different level: e-cvt from Toyota. It is all about energy path efficiency, not only the ICE BSFC operation.
    #5 telmo744, Apr 26, 2024
