New noise like a roar or drone at higher speeds
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kpeeling, Nov 1, 2015.
  1. Kpeeling
    Kpeeling Junior Member
    30
    South Central PA
    2017 Prius v wagon
    I'm no mechanic and I don't know a lot about my Prius so I hope someone mechanical can help. I have a 2007 Prius (now has 220K + miles) I bought used about 2 years ago with 150K miles. I finally got used to the car sounds so this is something new, or rather it's becoming louder and enough for me to question it. The car is still quiet at low speeds but this sounds like something related to how fast the car is rolling, not the engine acceleration. It doesn't sound like it's coming from the wheels. It's a low roar like sound, not high pitched and it sounds like it's coming from under the middle to front of the car as if related to perhaps the drive train. If I am up to 40-50 mph and just rolling (foot off the gas) down a long hill, the sound is there. It gets louder the faster I go. Could it be a transmission sound? I've always had manuals so this is my first automatic transmission car. Is there a fluid level I should have checked or maintenance I should have had done by now? I hope someone has heard this before and knows what it is.
    Thanks in advance.
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Tyres? As they wear, their sound might change. Check for uneven wear patterns (fairly easy to see) which might be caused by bad alignment. hope this helps - Wil
  3. Kpeeling
    30
    South Central PA
    2017 Prius v wagon
    Thanks for responding. I only wish it is something that simple. Last fall I put on 4 new tires and have had them rotated. No abnormal wear is obvious. I plan to have my mechanic listen this week to see if he can ID the noise. I'm leery about having a dealer listen since they always recommend tons of work for tons of dollars.
  4. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Although it could be a transaxle issue surfacing, at your car's age and mileage I'd suspect one or both front wheel bearings. My daughter's '07 lost the passenger side at 140k and the driver side at 150. Diagnosing the passenger side was tricky as it was nearly impossible to tell which side the noise was coming from. When the driver's side went I just assumed it was not the passenger side again and this was correct.
    If you "'slalom" the car from side to side, does it make the noise louder with regard to which direction you're swerving? Popular opinion among mechanics is that the bad bearing will be opposite the direction which makes the noise louder. In my case it was just the opposite, swerving to the right was loudest and it was the passenger side bearing that was bad. I was able to make the call by having my wife drive so I could compare the noise I was hearing from both sides of the passenger compartment. Raising the front end and spinning the wheels in neutral was no help and there was no "play" in either wheel when lifted off the ground. It's really a bit of a crap shoot to diagnose. Knowing what I know now, and at your mileage, I'd just do them both.
    The Timken HA590064 is likely the OEM Koyo bearing and can be had for $101 on Amazon if you're DIY. This is the bearing I used. Toyota dealer will want $700-$1000 to do both. Perhaps a good independent mechanic will meet in the middle but I'd require the Toyota factory part or the shown Timken.
    #4 m.wynn, Nov 1, 2015
    Kpeeling and Dino33ca like this.
  5. dpeverhart
    dpeverhart Member
    126
    23
    I
    A good mechanic should be able to properly diagnose this. My guess is a front wheel bearing, or both fronts. I've seen these go at around 180k. If it's a northern car they can go much earlier. We've used Moog bearings with good results. They run around $100 at Advance Auto Parts after using online discount codes. Labor shouldn't be too bad, maybe an hour or two.
    Kpeeling likes this.
  6. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Wheel bearing. The noise is transmitted through the drivetrain and can sound like it is coming from elsewhere.
  7. Kpeeling
    30
    South Central PA
    2017 Prius v wagon
    Seems to be a consensus here so I will ask my mechanic to check it out. I'll take it out for a drive today and check the slalom suggestion. Thanks!
  8. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
  9. ChapmanF
    17,348
    How's your musical ear? Do you have a sense for what pitch the drone is at a given speed (or can you use a cheap tuner app on your phone for that)?
    The first time I had a wheel bearing go, I was concerned about the possibility it could be the transaxle, until I worked out that the pitch wasn't related to any whole-number multiple of the transaxle MG2 rpms, and that relaxed me about the major worry so I could just look more calmly for the real problem.
    A few years later when I had a front bearing go, I heard a characteristic pitch from it too, different from the rear (but I have a Gen 1, where front at rear bearings are quite different styles; the exact details may be different for your Gen 2, because it uses the same type of bearing front and rear, though the sizes might be different).
    -Chap
  10. Kpeeling
    30
    South Central PA
    2017 Prius v wagon
    Never have drained and refilled the ATF. Actually, that's why I am fearing the sound as transmission related. I'm headed out to test the slalom idea now.
    Update: Drove on curves. I'm now pretty sure we are talking wheel bearings. It is much louder on right curves and much quieter on left ones. There's no mistaking the difference. This forum is awesome! Off to the mechanic as soon as I can get an appointment to verify my suspicion. Thanks to everyone.
    #10 Kpeeling, Nov 2, 2015
  11. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Yes tires and wheel bearings are first to check.
  12. jdenenberg
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    While having the wheel bearing fixed drain and refill the ATF with Toyota type WS ATF (~$10 per qt - you need 4 and 2 crush rings). My Toyota dealer charges $100, but it is a straight forward DIY (see: ATF fluid changes ARE Required. | Page 27 | PriusChat). Capture a few ounces of the used ATF in a clean Poly bottle so you can send it in to R&G Laboratories, Inc. - Home for analysis (~$25) and report the results on PC.
    JeffD
    #12 jdenenberg, Nov 3, 2015
  13. Graham Salvage
    Graham Salvage New Member
    manchester
    Please can you let me know how it goes? - I have the same problem....(not tires...)
  14. fotomoto
    5,629
    3,802
    So. Texas
    FYI, sad to say but the OP hasn't been back to give us any verification since posting this over a year ago.
  15. Myst Yang
    Myst Yang Junior Member
    Brooklyn, NY
    I love this forum: I've been having the same issue for a few years now (in my own 2007 Toyota Prius) - i think, left unchecked, I ended up having to repair the drive shaft (something with the rack and pinion - very expensive). While I'm down there, I'm going to have them check the rotors, too, as the last time I had them checked there was at least surface-level rust. Concerned that at high speeds it might cause some additional wobble or shaking (something I looked up when attempting to ascertain this issue).
