New one: car now locks itself on occasion
Discussion in 'Gen 4 Prius Technical Discussion' started by Mambo Dave, Sep 6, 2022.
  1. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    I believe this is a new one to me. 46k miles on the car now, and once in a while I'll catch it locking itself. For example, unlocked all doors from the house, left the keys inside as I only needed to get something out of the car. While outside I decided to turn the hose on and water some plants. About a minute into doing that the car re-locked itself.
    This was probably 6 AM in the morning.
    Are your cars locking themselves now?
    49,490
    my 12 does that when i unlock with the fob instead of the handle. do not know if there's a setting that can be changed, and gen4 might be different.
    alanclarkeau likes this.
  3. PosauneGuy
    PosauneGuy Member
    117
    88
    California, here I come...
    If you unlock your car with the fob and don't open the door, the locks will re-lock themselves after about 30-60 seconds. Not specific to Prii...we had a Honda that did the same thing.
  4. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    Check your manual and you should find the explanation. Ours has done that since day one under the right conditions.
    Mambo Dave and alanclarkeau like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    My last 4 cars have done that. If you were to open a door and close it again - it would stay unlocked for eternity - or longer.
    Mambo Dave likes this.
  6. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    Iirc, on my 2022 Prime, that's a programmable feature.
    Iirc, the time delay (?3 choices?), and the lock/no-lock are programmable.
    You may be able to program some of those features from the bigger info display (?car settings?).
    I programmed the features on my car with an Xtool D8.
    A 1 month Carista obd app subscription may be able to do the same thing, but at a much cheaper price.
    Iirc, even without a subscription, Carista showed the options that were available to customize on a particular car?
    Good Luck!
