New or Custom Hub Caps
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Nave, Apr 24, 2024.
  1. Nave
    Nave Junior Member
    Northeast PA
    My hubcaps are pretty dinged up, and I'd like black ones anyways. What are the specs for the hubcaps on a 2014, and where is a reputable place to buy them? I'm capable of putting them on myself.
    Also are the center caps really worth it?
    TY
  2. ASRDogman
    ASRDogman Senior Member
    7,833
    3,990
    You could paint yours....
  3. Nave
    Nave Junior Member
    Northeast PA
    Yeah but some of the other rims have more appealing geometric patterns that would be cool.
    Mine have some big ugly scrapes and gauges, but I suppose they would be less noticeable if I spray paint them black. Would save some money too.
  4. ASRDogman
    7,833
    3,990
    You said "hubcaps", actually, wheel covers. But I take it you meant the rims?
    Either way, less expensive to paint them.
    I've watch videos of they using body filler after cleaning them.
    seaglasspearl2013 likes this.
  5. Mendel Leisk
    41,925
    Yeah hubcaps traditionally meant the caps on the hub openings, the small diameter holes in the centre of rims. Then popular usage shifted the terms to wheel covers, plastic faux-wheels, sometimes complete with faux-lug-nuts.
    the alloy rims underneath were silver for 2010~2011, then black from 2012 onwards.
    My first thought when I saw those black rims, was that Toyota was dismayed by the numbers of owners removing the wheel covers and adding centre caps (again, what hub caps traditionally meant), and they went to black painted rims in an attempt to dissuade the practice.
    But owners continued to remove the covers, add centre caps, and black rims went from ghetto to chic.
    If you’re set on wheel covers, I’d do some Bondo and sanding of what you’ve got, then sprayed them. Tastes vary, but consider just restoring them to stock; that colour is apparently Toyota’s Classic Silver Metallic (1F7).
    #5 Mendel Leisk, Apr 25, 2024
  6. Nave
    Nave Junior Member
    Northeast PA
    I meant wheel covers/hubcaps. sorry for the confusion
    Can I get something like this? 15" wheel covers
    Will any 15" work, or is there something I'm missing?
    Thanks again.
    ASRDogman likes this.
  7. Merkey
    Merkey Active Member
    319
    291
    Birmingham, Michigan
    Try ebay. You can find used OEM covers or knock-offs for your wheel.
  8. Mendel Leisk
    41,925
    May be ok. Buy from a local store, and see if they’ll let you return if not compatible. Avoid anything with metal jaws that’ll gouge your rims. From the description sounds like plastic jaws and a steel ring pushing them outward, which is ok.
    seaglasspearl2013 and Merkey like this.
  9. ASRDogman
    7,833
    3,990
    I'm not sure, you'll have to ask them if they work on a Prius.
    Ebay, as Merkey said, would be a good place.
