New owner info request 2007
Discussion in 'Gen 2 Prius Main Forum' started by Moresnow, Dec 1, 2021.
  1. Moresnow
    Moresnow Junior Member
    37
    midwest
    After much looking/waiting to find a decent clean appearing Prius we brought one home this afternoon with 136,000. Anywho. I am interested in what I need to to acquire for code reading, diagnosing etc. Also any words of wisdom on fluid changes etc. I should look into asap. I realize these questions are covered in detail elsewhere but thought this would be a good way to get my feet wet here. I have been researching/reading here for some time.
    My mechanical background is varied and includes bikes, sleds and racecars to list a few that have cost me large amounts of cash and time;) Unfortunately my electronic assisted diagnosing experience is next to zero. Sooo. Looking forward to figuring these cars out. Thanks all.
    52,405
    congrats and welcome!
    do you know the service history? some info may be available at 'toyota.com/owners', along with a maintenance schedule. all fluids and spark plugs should have been done by now.
    tech stream is the gold standard prius reader, but dr. prius or hybrid assistant work fairly well.
    all the best!(y)
    Moresnow and nancytheprius like this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    2007 Toyota Prius Manuals & Warranties | Toyota Owners
    Here is the page with all the manuals. You want the warranty and maintenance guide at least.
    Toyota never recommended an ATF change interval for the Prius in the US. No lubricant is forever, so owners are free to make up their own routine. My recommendation would be to change ATF WS now, at 200,000 miles, and then every 100,000 miles. It is a drain and fill, no need to flush as no ATF WS is trapped in a torque converter. The transaxle also lacks clutches and hydraulic shift logic, so none of the old wives tales about don't change high mileage ATF apply, even a little bit.
    With the car level, open the fill port before opening the drain port. The dealer should have 2 crush washers and 4 quarts ATF WS.
    #3 JimboPalmer, Dec 1, 2021
  4. ETC(SS)
    7,367
  5. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    replace pcv valve. its quick and cheap (get one from toyota less than 20 dollars). If yours is gummed up at all from the 138k miles, then itll especially be beneficial
    Moresnow likes this.
  6. Moresnow
    37
    midwest
    Appreciate the replies. This car came from a small local used dealer who specializes in older Prius models almost exclusively. They had no prior service records but did run it through there in house shop. All fluids were verified to be up to the full marks and at least appear to be in decent condition. The coolants were tested for my area and deemed fine. Irregardless, I plan on changing everything for a fresh start. The PCV valve is on my list. Now I am off to Utoob for some guidance! Thanks everyone.
    ColoradoCrow and nancytheprius like this.
  7. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    If service history doesn’t show spark plugs changed by 120k, I’d do those and at the same time PCV valve since it’s right there.
    Oil, both coolants and transmission fluid all should be checked and changed if not already done so.
    nancytheprius and Moresnow like this.
  8. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    DiY info here
    PriusDIY.com: The Toyota Prius DIY Resource
    Lots here
    Prius content
  9. OC63RAG
    OC63RAG Member
    94
    42
    In addition to the things already mentioned, I'd add the air filter, cabin filter and clean the throttle body and MAF sensor. Congrats on the purchase by the way.
  10. Moresnow
    37
    midwest
    All good ideas. Cabin filter had not crossed my mind. Any "go to" online parts ordering sites?
    OC63RAG likes this.
  11. OC63RAG
    OC63RAG Member
    94
    42
    My local Autozone had one in stock but I'm sure there are online options as well. I'm still trying to support local stores as much as possible. Even my local Toyota dealership has surprisingly fair prices on most parts. The guy that works the counter there will give me the web price which saves me about 10%.
  12. Another
    1,819
    517
    Naples, Florida
    I buy them on Amazon
    Cheap and fast ship to home.
    Same with air filter
    dig4dirt likes this.
  13. Moresnow
    37
    midwest
    Are you buying OEM or aftermarket components?
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In 2009, I bought a Scangauge II, it has served me well but is very expensive and 12 years old.
    Modern gear tends to be mobile phone based using OBDII to Bluetooth adapters.
    Torque Pro (OBD 2 & Car) - Apps on Google Play as an example.
  15. Moresnow
    37
    midwest
    My low post count if limiting my response options. Goofing up my responses! Anyway.
    I've just scratched the surface on scan tool researching.
    One that seems impressive: XTool D7 Guess I can't include the Amazon link with my low post count.
    Way more money but it seems to have some advanced capabilities and a very good video review from an actual Toyota tech (supposed). Gawd forbid I purchase something I can use on more than one vehicle! It may be time for me to get up to speed on using these electronic gizmo's. Why not.[/QUOTE]
    #15 Moresnow, Dec 2, 2021
  16. Moresnow
    37
    midwest
    Lots of good info. Thanks
    #16 Moresnow, Dec 2, 2021
  17. Moresnow
    37
    midwest
    Need a little direction finding a few parts. I need a front license plate holder and hardware is possible. Mud flaps and hardware. Good rubber floor mats front/back and rear storage area. I also need to get a second key/fob working. The dealer tossed in an extra fob that seams the same. Silver symbol fob. My car has the button on the door handles. My functioning fob has the silver symbol. Guessing this is a smart key car? Anyway. Any help is appreciated.
    I have zero problem buying used parts/components as well.
    Also. How about a link to the preferred Cat protection plate. Unreal requirement. I plan on using this car for an extended road trip east of the Mississippi and deep south at the tail end of Jan.
    #17 Moresnow, Dec 9, 2021
  18. nancytheprius
    365
    156
    iowa
    keyless entry! dont know if ill ever be able to have a car without it going forward haha
  19. nancytheprius
    365
    156
    iowa
  20. Moresnow
    37
    midwest
    I see you are in Iowa. I am just north of Cedar Falls.
    nancytheprius likes this.
