New Owner needs your opinion!
Discussion in 'Newbie Forum' started by jt408x, Oct 29, 2012.
  1. jt408x
    jt408x New Member
    Hello new owner here just asking for those experienced owner about a few things, so i just got my new 2012 blizzard pearl prius had it for a week now and im loving it so why I am here is because I seen some posts of lowering their prius with springs and I was wondering would it work if I wanted to install air suspension?
  2. RxGATOR
    RxGATOR Go Gators!
    49
  3. CAlbertson
    CAlbertson Member
    99
    24
    Have you looked under the car? It is already about as low as you need to be. Any more and I can just see the Prius stuck on a speed bump with all four wheels off the ground.
    Before you lower it get a tape measure and check your ground clearance WITH people in the seats.
    PriusGuy32 and OceanEyes like this.
  4. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    This was the post with the interesting visual... :D Would hate to be teetering on a speed bump... was bad enough learning that the front of a Prius can nose up real easy to curbs... luckily I stopped conservatively when my sister said "Do you realize how low the nose on your car is?!" As a result I cannot park worth squat but I am learning....
