New owner of an '07 Prius -- Any advice?
Discussion in 'Gen 2 Prius Main Forum' started by fuse, Nov 22, 2011.
  1. fuse
    fuse New Member
    NE
    As the title would hint, I recently bought an '07 Prius with 62k miles on it. I bought it from a certified dealer on eBay, so I didn't get the chance to test-drive it or actually see it in person outside of photos. Risky, yes, but I saved a good chunk of money doing it this way than buying locally (probably a good ~$5k). This is my first car purchase, coming off of the '94 Camry my parents loaned me with 215k miles. With that, I know nothing about cars, so I come to you all for advice regarding my situation.
    The car arrived, from Texas (to Nebraska), this Saturday. Sadly, I don't have any information on past owners or maintenance records. Both the exterior and interior are in great shape, although the interior needs a light cleaning.
    I haven't spent too much time with her, but it seems to run okay. There is one warning light on the dash and from my research, it just appears to be low tire pressure, so nothing major (I have a fancy new tire-gauge on its way for this).
    What should my next course of action be to ensure that I have a safe and reliable vehicle with no issues? Anything that an extreme novice can do by himself to save some money? I'm thinking I should find a Toyota dealership near me with someone knowledgeable on the Prius and have him/her look it over? Are those computer-diagnostic scans worth their cost?
    Well, I think I covered most of what I wanted. If you need any information from me, just let me know. And yes, I know there are a bunch of threads with a lot of information, and yes, I have read a good majority of them, but I hope this thread can still prove useful as a means of compilation.
    Thanks for any and all advice.
    -- Chris
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Congrats on getting a Prius finally!
    A computer diagnostic scan is meaningless unless one of the many check engine lights is on.
    Change the transaxle fluid. Now, 62K, is a great time.
    Register at toyota.com/owners to see if there are maintenance records, repairs, and recalls. Yours falls under the inverter cooling pump recall.
  3. fuse
    fuse New Member
    NE
    I am registered over at toyota.com/owners and there are no maintenance records there either. Like you said, though, I do have some recalls -- the water pump and some floor mat thing? I didn't even get floor mats with my Prius :(.
    Thanks for the heads up on the diagnostic scan though, that'll save me ~$75.
  4. JimboPalmer
    12,470
    6,869
    Greenwood MS USA
    Oil change, tire rotation
    Good chance it is time for a second air filter change
    Transaxle fluid is a good idea
    12 volt battery test
    Recalls.
    Could be $200 well spent
  5. tv4fish
    tv4fish Member
    202
    46
    Chris: I'm in somewhat the same boat - I bought my '05 on eBay also (mine had 133,500 miles). So far, I have done this - oil/filter change -- transaxle fluid change, replaced original Toyota 12 volt battery with Optima Yellow top, replaced spark plugs, replaced PCV valve, replaced engine air filter, replaced cabin air filter (what a difference that made in air flow in the psgr. compartment.) It does get cold in Nebraska, just like it does in Minnesota :). I just want mine to be dependable this Winter. Since yours has 1/2 the miles, you may not need the new 12v battery, or the plugs, or the PCV valve - but I WOULD check the 2 filters to see if they're dirty.
  6. fuse
    fuse New Member
    NE
    Thanks all, good stuff so far. Inspecting/replacing air filters seem easy/cheap enough, so that's definitely something I can do on my own.
    Any more pieces of advice would be greatly appreciated.
    Thanks again!
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    If you guys have to drive in the snow a lot then I suggest ditching the oem Integrity tires for something with more grip. Those tires are horrible and flat out unsafe in wet conditions.
    Also check your 12v battery voltage. You never know how many times it may have been depleted and it is common issue on older cars.
  8. jdenenberg
    jdenenberg EE Professor
    3,857
    1,857
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If either of these Prii are still driving on the OE GY Integrity tires, I would be impressed. They do not typically last very long.
    JeffD
  9. tv4fish
    tv4fish Member
    202
    46
    The PO of my '05 Prius had just put on a set of Hankok 724's -- BUT :) -- Minnesota DOES get snow (had some already) so I did put a set of Michelin X-Ice non-studded tires on her.
  10. fuse
    fuse New Member
    NE
    I can't remember off the top of my head, but I am pretty sure the stock Integrity tires have been replaced on my vehicle. I also checked last night and the engine air filter looks to be brand new, so nothing for me to do there.
    Some questions now --
    1.) What is an acceptable reading for the 12v battery?
    2.) Are there any proprietary fluids that I should know about? I know for oil I should use 5w-30 (correct?), but is there anything specific for say, the transaxle fluid (or any other fluid for that matter) so I can ask the mechanic/dealership to make sure they are using the right stuff?
  11. tv4fish
    tv4fish Member
    202
    46
    For the transaxle-- you DO want to use ATF WS and yes 5w-30 on the oil.
  12. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Congrats on the '07! My parents and I each have '07's we've had since new--they're incredible cars.
    I really like them because you can drive them without paying any attention to the hybrid system, or you can learn as much as you can and optimize your driving style to get really nice fuel economy. It can be just a car, or a whole hobby/lifestyle.
    We've been doing all our maintenance ourselves, from home. So far, it's just been oil/filter, air filter, cabin air filter changes and tire rotations. With one front tire up on the curb, it's pretty easy to crawl/reach underneath and undo the oil drain plug. The oil filter is also easy to reach. I use 5W-30 synthetic blend. Make sure not to overfill--it only takes 3.5 quarts.
    I haven't addressed the transaxle fluid yet--I'm still under 40k miles. The factory maintenance schedule doesn't have transaxle fluid replacement on it, I don't think, but it seems like many people do it anyway as a precaution.
    Thanks to the internet, there are plenty of how-tos and videos available for performing practically any maintenance item and there are plenty of sources for parts. I'm not planning on ever taking this car to a mechanic or dealer for anything except the service bulletin work--I haven't done that yet.
    We're both on our original 12v batteries. My parents' hasn't shown any sign of needing replacement but I had the Progressive snapshot device plugged in for a while and since I only drive once or twice a week, it was dragging the 12-v battery down. I kept putting a charge on it while parked but it looked like it wasn't going to recover. My Snapshot monitoring period ended a few months ago and it seems like the 12v battery is starting to hold a charge better again--I'm going to put off its replacement some more. When the red, triangle with exclamation point light on the dash comes on when you turn on the car, that's a sign that the 12v battery is under-voltage. Mine never failed to start but it showed the light and took longer to boot up sometimes.
    Many people are going with Optima Yellow Top batteries as replacements instead of the stock, Toyota items. They're expected to last 3+ times as long (10-15 years instead of 3-6) and cost close to the same. Optima just introduced a direct fit application that costs $199 but I'm going to go with the group 51 and adaptation kit from http://www.elearnaid.com/12vo1topraub.html for $170--the price difference is good for a few bags of groceries and the kit comes with a more readily-available battery size.
    A lot of us are running higher tire pressure to reduce rolling resistance and improve MPG. It's good practice to keep the front tires about 2psi higher than the back--it improves handling, since the front is the heavy end. I run 44psi front/42 psi rear. It also ensures that the low tire pressure light won't come on when it gets cold out.
    Don't get frustrated if you're not getting the kind of MPG numbers you want at first. A lot of people are initially disappointed but with some education and practice, you'll have things figured out in no time. The car also helps teach you how to drive efficiently if you pay attention to it.
    Have fun with it--this forum is a great place to search for information or ask questions.
    Eric
