New owner, what should I service next?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by parkp81, Aug 31, 2014.
  1. parkp81
    parkp81 Junior Member
    25
    Fullerton, Ca
    I just purchased a very clean, 2005 Prius Package #1 from a Toyota dealership. It had 1 owner and has 99k miles on it. The owner bought and had the car serviced at the same dealership during ownership. I purchased the car from the same dealership too. :) .
    I have saved a copy of the service history from Toyota owners website, and have attached it here. I think I so far am looking at changing the Transmission Fluid, but anything else I SHOULD do?
    Thank You:D
  2. drmanny3
    drmanny3 Member
    124
    Orange County, CA
    I have a 2006 that just hit 106,000. I recently changed out the spark plugs. The old ones were getting a bit dirty but otherwise seemed ok. The gaps were appropriate. I changed out the water pump for the engine as it began to weep but not really leak. Some folks have suggested that you can leave it when it weeps as long as the leakage is minimal. The part is cheap, but takes a bit of time to do. In the process I changed out the radiator antifreeze fluid and the belt that turns the water pump. Some folks will change out the PVC Valve though mine was still working correctly. My air conditioning compressor went south about this time. That was expensive. No service required unless the system is leaking. Other than that there are not a lot of things to do on this car. I also changed out the transaxle fluid though I think Toyota suggests that you leave it be. The dealer is happy to do it. The brakes are still good on the car at this point but will need to be replaced in the near future. Hope that helps.
    Manny
  3. parkp81
    25
    Fullerton, Ca
    Thanks Manny.
    The car looks like it had the engine coolant, inverter coolant, and water pump replaced at 74k miles (25k miles ago), so I think I should be good on that for some time?
    Spark plugs I think i'll wait until around 120k miles.
    So far I think i'm going to check on the PCV valve and change my transmission fluid.
    I just did a 12V battery test this morning after the car sat overnight and I go the following readings. Seems like a new battery is on the list soon too. Not sure if it has ever been replaced yet.
    12.1V (normal 12.4-12.8V) - Unloaded battery
    11.8V (normal 12V) - Acc Mode
    13.8V (normal 13.6-14.4V) - Car started
    51,154
    welcome to prius chat, congrats, looks like you snagged a gem! the 12 volt is weak, i would replace it. doesn't look like you need anything else, good idea on the tranny fluid. all the best(y)
  5. parkp81
    25
    Fullerton, Ca
    Thanks Bisco.
    Yea, looks like I will just go ahead and order the Optima battery I see that everyone recommends. Already experienced a dead battery out of nowhere on my other vehicle, no warning signs just dead when I went to go start, which was not welcoming.
  6. bisco
    51,154
    use caution with the optima, they have been having a bad run lately. many are coming with a poor charge after sitting in a warehouse for quite sometime. the oem is a good one, and there are several other alternatives.
  7. Patrick Wong
    18,200
    6,493
    I would recommend the GS Yuasa battery that your local Toyota dealer sells, or the Exide AGM battery that will fit Prius.
  8. parkp81
    25
    Fullerton, Ca
    Good thing you guys mentioned that. I just cancelled my order for the Optima battery on Amazon as they had it the cheapest I could find.
    Patrick, any recommendations on a good affordable place I can buy any of the two you mention online? BTW, I don't have the SmartKey.
    Thanks
  9. parkp81
    25
    Fullerton, Ca
    I think i'll go ahead and get the Optima one from Amazon, if anything they have excellent customer service so I can get it taken care of if I do get a bad battery, since it is sold by them. The other ones I just did a quick search and are much more expensive.
  10. Patrick Wong
    18,200
    6,493
    Since your car doesn't have the Smart system, the battery is going to be shorter in the length dimension. This means that any battery (other than the original equipment size) will not fit in the battery tray. So if you want to get the Optima via Amazon or whatever retailer you choose, you will also need to get the longer battery tray from your Toyota dealer.
    You may want to consider that if you buy the Optima from Amazon, you will be faced with having to ship the battery back to them if you have a problem. You cannot count on a local retailer giving you warranty service. So if it would be inconvenient for you to do without your car for several days, how much value will you get from the warranty?
    Another PC member recently posted that he bought a new battery locally rather than wait for Amazon to process a warranty repair on Optima.
    #10 Patrick Wong, Sep 1, 2014
  11. Mendel Leisk
    40,584
    Up here there's a core charge (typically $12) when you buy a 12 volt automotive battery, refunded if/when you give the seller your old battery. Is it like that in the 'States?
    I'd concur, if problems arise, having the transaction local is a lot simpler.
  12. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    Welcome to Priuschat!
    Re the battery, I'd go for the OE Toyota Battery or the Excide and fit yourself if you are good with your hands. It's less than an hour and don't rush it. I bought an Excide for mine and replaced is not long after buying the car (2008 model Gen2)
    I've also done the plugs and the gearbox oil, both before 70k miles. It be a waste, but I prefer preventative maintenance
    Good luck and safe motoring
  13. parkp81
    25
    Fullerton, Ca
    Never thought of that, but you guys have a very good point. Well I tried to cancel my order with Amazon and its too late (its shipping now), hopefully I won't get a bad one, keeping my fingers crossed.
    Just to make sure is this the correct battery tray I will need? 2005 Toyota Prius Parts - AutoNation Toyota Gulf Freeway Parts
  14. Patrick Wong
    18,200
    6,493
    Yes, you are correct regarding the battery tray.
  15. bisco
    51,154
    when you get the battery, test the voltage before installing. if it's below 12.9, get a smart charger and charge it overbite before installing. all the best!(y)
  16. parkp81
    25
    Fullerton, Ca
    Thanks again. Ordered the battery tray and will test the voltage before installing. (y)
  17. JC91006
    16,673
    8,518
    The battery actually fits with the old tray, I installed one a while ago and didn't have any problems.
    Make sure you want the battery from Amazon, this item CANNOT be returned, unless defective. Your only choice to cancel is to refuse delivery or it's yours.......
  18. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Keep the "smart key" bottom battery tray from Auto Nation, it'll be too expensive to return (restock fee & shipping fee). When the Optima needs to be replaced, you'll be able to upgrade to the larger capacity smart-key battery from the dealer.
    Hopefully you'll be a blessed Optima battery owner.
    Good idea to get a Smart Battery charger, that is AGM compatible; Amazon LINK
    Just be sure the charger doesn't put out more than your Optima is designed to accept. (IE, Toyota Smart Key batteries are rated for maximum 4.2Amp)
    Schumacher SC-1200CA, $38) 3-6-12Amp charger
    Schumacher SC-1500CA, $54) 3-8-15Amp charger
    BatteryMinder 2012-AGM, $78) 2Amp dedicated AGM battery charger
    Noco Genius G3500, $59) 3.5Amp charger
    Ctek Multi-US-3300, $56) 3.3Amp charger, older model
    Ctek MXS 3.8, $unknown) 3.8Amp charger, NEW model
  19. writes123
    writes123 Junior Member
    92
    23
    Riverside, CA
    How difficult is it to adapt the Optima 51 vs the Optima for the Prius?
    Do I just need to buy a pair of marine battery adapters?
    524186 - is the Group 51 Optima
    Prius: 513308
    Basically, it it worthwhile to convert SAE posts to JSI?
    The reason for my question is that a local store sells the prius optima for $35 more than the regular Group 51 Optima.
    Thanks.
  20. exstudent
    2,214
    905
    Torrance, CA
    Read post #18 & #19; LINK
    Pricing would be helpful to know, to get you a better value. Are we talking $225 vs $190?
    Amazon has a YellowTop Prius battery for $147 (free shipping). LINK
    elearnaid, in Sylmar, CA, has a Prius YellowTop for $173 (free shipping). Free install if you want to drive to Sylmar. LINK
    Does your Prius have the smart-key system? If so, then you really want to get the battery from the dealer or the Bosch battery.
    Smart-Key battery (45Amp-hr/325CCA), Non-Smart-Key battery (35Amp-hr/), Optima Yellow Top(38Amp-hr).
    Prius specific Bosch battery at Pepboys is $190; there's a 10% off code/coupon. LINK
    I upgraded my non-smart-key battery to a smart-key battery; dealer battery cost was $163.31 before tax. LINK
    After the upgrade, I could have saved a few dollars ($12.13), by cutting the non-smart-key batter try, to accommodate the larger smart-key battery, as some people have done.
    #20 exstudent, Sep 2, 2014
