New Owner Wheel/Tire Question
Discussion in 'Gen 3 Prius Main Forum' started by Redryder, Sep 25, 2011.
  1. Redryder
    Redryder Junior Member
    NH & NS
    Hi . . . We just took delivery of our Prius III a couple of days ago and at the risk of asking a question that's already been addressed (I checked threads and didn't see anything covering this) I was wondering if a Gen II stock wheel would fit on our Gen III? Looks to be the same bolt pattern and offset per the description. The snow tires mounted on the wheels are 185/65R15 Michelin Ice-X Snows with 9k miles and the package includes TPMS. The Miata tire size calculator program puts the 185s real close in all areas to the 195s we have on there now so the real question is whether the Gen II wheels are compatible with Gen III.
    Thanks in advance for any help/guidance you can provide and, again, sorry if this has been addressed somewhere else.
    Great forum and great source of info. Looking forward to continuing in it.
    RR
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Everything you wanted to know about Prius wheels and tires but were afraid to ask:
    weight comparison
    ce28 ecodrives
    15 inch: 10.1 lbs
    16 inch: 10.8 lbs
    Prius factory wheels
    15 inch 14.3 lbs
    16 inch 15.2 lbs
    5X100 mm holes
    45 mm offset
    6jj rim size
    2004-2009 Prius
    15X6JJ: 5X100mm PCD, 45mm offset
    16X6JJ: 5X100mm PCD, 45mm offset
    15X6J: 5X100mm PCD, 45mm offset
    17X7J: 5X100mm PCD, 50mm offset
    17inch:11.0kg
    15inch: 7.4kg
    Looks like the GII wheel/tire combo will be fine.
  3. Redryder
    NH & NS
    Thank You very much :)
