New plastic lift hatch, painting q
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simplifying, Aug 18, 2016.
  1. simplifying
    simplifying Junior Member
    33
    Lawrence, Kansas
    I just received a new lift hatch unit from Amazon which is black, unpainted plastic. I have a couple of questions:
    1. Will I need to apply a primer before I spray paint it and put a clear finish on it?
    2. The paint company I plan to order the spray paint and clear finish sells a 14 dollar mask to use while apply the spray paint. Is that necessary?
    Thabnkyou.
  2. JC91006
    16,673
    8,518
    do you have a link for the item? Your car is 10 years old, I don't think your paint job has to be perfect....it'll still somewhat match
  3. simplifying
    33
    Lawrence, Kansas
  4. JC91006
    16,673
    8,518
    If you need a black one, I have a perfect condition one for $100
  5. simplifying
    33
    Lawrence, Kansas
    Nope, I already have what I need. Just need to know if I need primer or not to paint the plastic before applying the color and clear coat.
  6. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    Primer would be suggested to increase adhesion.
    The mask, your call.
    Home Depot et al may have lower cost options.
    Paint fumes into the lungs suck.
    Have fun.
  7. simplifying
    33
    Lawrence, Kansas
    Thank you all for your responses! This is a great chat site!
  8. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Primer helps to reduce paint sagging. If the paint sags, then wait until it is really dry, coat the sag with Bondo Glazing & Spot putty. Spread sparingly over the sag. Let dry. Block sand the area until all the spot putty is gone. The sag will be gone too
