New Prius 2 Eco
Discussion in 'Gen 4 Prius Fuel Economy' started by Northshore_Paul, Sep 4, 2016.
  1. Northshore_Paul
    Northshore_Paul Junior Member
    Covington, La.
    Two Eco
    I took delivery of my second Prius a week ago and now have over 900 miles on the odometer! This is my second Prius, my first was a 2103 Prius 2 and I am loving this car! I put 70,000 on my first Prius in three years and on a whim I traded it and got this new one in a beautiful Sea Coast Metallic green. My computer says I have averaged 65 mpg so far and the first fill up at 575 miles by computation showed 60.4 mpg. These new cars drive altogether so much better than the previous versions, sportier, quieter, hold the road better and so much nicer interiors and sound systems. Now I just have to relearn all the possible functions of the computer displays. The only negative about the car is no spare tire!
    AKCoffee, RCO, Coast Cruiser and 3 others like this.
  2. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    sounds like us, same color prius you have, we've had ours 2 weeks tomorrow, already over 1,200 miles on it. We love new prius, find it lot easier to get full of gas than gen 3 prius
    52,373
    congrats! when was the last time you got a flat?:p all the best!(y)
    RCO likes this.
  4. GaryD1
    302
    138
    Seagrove, NC
    Its been about 10-15 years since I had a flat.
    RCO likes this.
  5. stanley soroka
    stanley soroka Junior Member
    Largo
    I just got mine on Thursday, This is my 3rd I had a 2012, 2015 and now this great 2016. My color is Hypersonic (Barcellona RED).
    I got no stas yet, but will post them later once I can get the hang of the displays. My only neg is the lack of the small space under the rear mat.
    bisco and GaryD1 like this.
  6. Mendel Leisk
    41,889
    Well, technically it was our son's car, last Tuesday. It was in our driveway, and just a slow leak (until I pulled out the screw, then hoo boy!). I removed the tire and plug repaired. Still, I've been out and about, found tires completely flat, needed that spare.
  7. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Good job on plugging this yourself.
    In my experience (n = 4 or 5) flat tires found in the driveway or parking lot respond well to a can of Fix-a-Flat or a portable compressor only.
  8. krmcg
    2,592
    2,392
    Whittier, CA
    You have some uneven tire wear there. Looks like alignment-caused. (The inside edge is worn more than the outside).
  9. Mendel Leisk
    41,889
    I was waiting for that. The rears have negative camber, it is spec'd. They always wear a bit faster on the inside.
    krmcg likes this.
  10. tzx4
    tzx4 Active Member
    164
    148
    I have not had a flat in at least 20 years. That said I do an annual drive in Nevada where I go 60 miles on a mid-quality dirt road in the middle of nowhere, and for that, I take the Corolla with its spare tire. No way would I chance having no spare on a road that handles maybe one or two vehicles a day.
  11. bisco
    52,373
    same here, except for the dirt road in nevada, and the corolla.
  12. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Maybe plugs have changed, but I tried one in the past and it leaked. Not a long term fix. I was taught that tires must be patched from the inside, which means removing the tire from the rim which also means a tire shop must do it. Something also about the plugs being sawed off by the steel belts causing a leak. Not sure I believe that, but I always have tire shops repair my flats. Usually, if there's a nail in the tire, you get a slow leak, and you can pump up the tire and drive to the tire shop.
    A combination patch & plug is best:
    Tire Tech Information - Flat Tire Repairs
    #12 MikeDee, Dec 31, 2016
  13. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I had a flat within the 1st thousand miles on my new Prius, it was a 2011, glad it had a spare, cause the tire was ruined before I could safely stop. Got a spare with the Avalon, wouldn't go without one.
  14. Does the lack of a rear windshield wiper bother you?
    #14 Deleted member 111882, Jan 31, 2017
  15. Alan Stubblefield
    Alan Stubblefield New Member
    Hettick
    the same story, man
