New Prius (2002) with new / old battery problems :)
Discussion in 'Generation 1 Prius Discussion' started by SEaton, Nov 29, 2013.
  1. SEaton
    SEaton Junior Member
    29
    Eagle Mountain, Utah
    2002 Prius
    Sorry for the super long post.
    I bought my first Prius today a 2002, has roughly 58k on it. I figured worse case I put a 3k battery in it and it would last me for years. The owner had a fender bender, got that fixed, and shortly after that had tons of codes. Toyoda report said that MIL 3006, C0278, C0200, C0205, C1246, C1253, C1254, C1259 codes. of note
    It said Diagnostic procedure was performed and it was found that the Block 3 was dropping to 15v while the other cells were 17v or higher.
    They also say the other codes were ABS ECU, and battery ecu codes, but they suspect they are related to the failing HV pack. Hope so !!! :)
    So I drove it home, the car seems quite tight and drove well. I had one hickup, at one point the car was running, but was like it was in neutral, went no where. I shut it off, and on, and it was ok again. It only had one solid fuel bar so I put in some fuel and drove home with no more problems.
    I pulled the Gen1 Battery.
    #1 being the furthest cell away from the power connections / computer
    #1 8.23
    #2 8.21
    #3 8.21
    #4 8.20
    #5 8.20
    #6 8.20
    #7 8.20
    #8 8.19-8.20
    #9 8.20
    #10 8.20
    #11 8.20
    #12 8.19-8.20
    #13 8.20
    #14 8.19
    #15 8.19-8.20
    #16 8.20
    #17 8.18
    #18 8.20
    #19 8.20
    #20 8.19
    #21 8.20
    #22 8.19
    #23 8.20
    #24 8.20
    #25 8.19
    #26 8.18
    #27 8.19
    #28 8.19
    #29 8.18-8.19
    #30 8.19
    #31 8.18
    #32 8.19
    #33 6.88 !!!
    #34 8.18-8.19
    #35 8.18-8.19
    #37 8.19 -8.2
    #38 8.21
    So the voltage readings make sense, as #33 would be in bank #3 and would make around 15v for that bank like their diagnostic said.
    So to me, it looks like only the one bad cell if I replace that I should be ok.
    Interesting things of note, the batteries had numbers written on them in sharpie up to around 27, and blue dots on top with sharpie. So looks like someone has been in this thing before. Very very odd for such a low mileage vehicle to have a refurb, or someone work on that battery with so few miles. Other thing of note was that for around 1/2 inch or so close to both sides of the battery you would see this brown looking stuff near the top of the batteries and connections. not sure if someone shot dressing of some sort on the connectors, but weird that brown looking stuff.
    Here come all the newbie type questions, sorry in advance guys.
    So if I buy a new cell from someone, I have found Gen I on ebay and on here etc etc. I was thinking of buying 2 or 3 (spare never hurts).
    I have been reading threads on here about using the RC charger to balance batteries etc, and also how a person can use a 12v charger in series etc. So my thought is if I get a new module, and I get it charged up to roughly 8.19V and installed in the pack, I would be good to go.
    #1 how do I determine if a cell I get is a good match capacitance wise etc ? I have a good multimeter
    #2 do I really need to do much to all the cells, they are pretty uniformly around 8.2, and the car should do the rest, maybe charge up the ones at 8.18, and get the 8.23 and 8.21s to around 8.2 also with a load. Then I would think that when plugged in the car would do the rest and charge them all up ?
    #3 if I buy a spare, will they be ok sitting around (stored in a cool place)? or is that a waste
    Obviously its a crap shoot and I could replace a cell only to have another go bad in the future, but figured I would try it at least once before considering putting in Gen II cells.
    If it fails me again and I do need to put in some Gen II's.
    #3 Does the whole battery need to go to Gen II at once ? or one half at a time ?
    #4 will a gen II match up bolt for bolt ? do I need to drill or any mod to make them fit ?
    Thanks sooooooo sooooo much for your help.
  2. SEaton
    29
    2002 Prius
    ok, reading reading reading. So it looks like I should consider buying a supermate dc 6. If I understand what I am reading right, it will read the capacity of the cells, and if I do like 3 cycles on the cells or so it should get them back close to the 6.5ah capacity hopefully. so from what I can tell these are around $40 - $60 for the charger on ebay, and using one charger, could take me forever, but do the trick. I think it could do 4 cells at a time.
    the next trick would be figuring out how to calculate the internal resistance. light bulb or something, and not sure maybe using the current setting of a multimeter to figure it out.
  3. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    This technology is all new to me and I commend your efforts to keep a car on the road. I do and maintain all of my vehicles and have done for years but what you are dealing with I am reading in hopes of NEVER having to deal with it....well soon anyway. Hopefully you get that battery issue figured out and have a solid car for years.
    TomK
  4. bwilson4web
    16,353
    Your right, #33 is toast. In failed mode, it would have run hot and probably weakened the modules on either side. But you'll find out if you survey the modules for capacity.
    We call them modules because they consist of six cells inside each module.
    I've not used that charger but if you've read the manual, go for it. I'm partial to the Superbrain 989 but that was the one available five or six years ago when I bought mine.
    I've not had much luck trying to charge/discharge more than four modules at a time. The reason is the dV/dt occurs on each module at a different time. Unless you start with four balanced modules, the charger won't be able to detect when the peak charge occurs.
    The charger will do a good job of measuring the module capacity. But to get them all at the same level, you might consider putting them all in parallel and putting a small charge on them together. This will at least ensure their voltages are as close as possible.
    BTW, the older messages have a lot of good tips and examples.
    GOOD LUCK!
  5. SEaton
    29
    2002 Prius
    Its not all as bad as you think. Worst case you buy a battery that someone else has done this work for you. I am just trying to not be wasteful and get the most out of the cells before going to the next gen cells, and save a little money and economy on the side. Great threads on here, a wealth of info.
  6. SEaton
    29
    2002 Prius
    Wilson thanks so much for the reply. I was debating replacing one cell next to the bad one, I didn't think of the heat, maybe I will have to do two of them. I liked the look of the DC6 cause it looked I could plug it in, clip on some clips and be up and running. It was also one of the main chargers I was following in one of the threads.
    The MRC looks like a little bit of a project in itself getting setup to use it, but I like the fact that I could link it to a computer, me being a computer nerd and all.
    Thanks so much for your help.
  7. bwilson4web
    16,353
    Conservatively, you'll need three modules: (1) failed, and (2) both sides. <wink>
    You'll also notice all the other modules are showing ~8.2V. Although a little overcharged, they're still good. I prefer to limit my modules to about 8.0V. A little higher is not 'death' but it really stresses the modules.
    What happens is a small amount of the electrolyte, the water, is hydrolyzed during a charge. This increases the internal pressure significantly and puts one heck of a stress on the terminal "O" rings. Add heat and they can literally melt which leaks out the H{2} and O{2} gas. This in effect dehydrates the electrolyte so it no longer fully 'wets' the plastic separator inside each cell. The current gets concentrated in a smaller and smaller spot and one day, it melts, making a permanent short. That cell of the six is unrecoverable and bad.
    Once you get 'er back on the road, we can go over how to drive 'battery safe.'
    BTW, did anyone mention you really should have a Prius-aware scanner? This means one that can read out the 19 module pair voltages as well as other critical temperatures. Check the archives to see what folks have found that works.
    Are you under any time constraints on getting this car back on the road? The reason I ask is: GOOD, FAST, CHEAP . . . pick two.
  8. SEaton
    29
    2002 Prius
    Wilson thanks, yeah I will order at least 4 modules and see where I stand after some cycles.
    prius aware scanner makes a lot of sense. I do have one of those USB-OSDBII cables, I was thinking of trying out the techscanlite. I will read through as you suggest and see what there is on that.
    yeah I am probably a good 3 weeks away before driving :) but yeah battery safe driving sounds like a good idea.
    Yeah I am thinking the Good and Cheap option.
