New Prius: 3 miles left on 3/36K warranty - common problems?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prmp945, Oct 10, 2014.
  1. prmp945
    prmp945 Member
    79
    59
    Hi all,
    I just purchased a 2011 Prius III with Nav. It has just 3 miles left on the 3 year/36K bumper-to-bumper warranty! What common problems should I be looking for so that I can get them fixed under warranty while the gettin' is good?
    Thanks all!
  2. JC91006
    16,674
    8,519
    Can you get to the dealer in less than 3 miles?
    Still good on years?
    The Electric Me likes this.
  3. prmp945
    prmp945 Member
    79
    59
    Yes, the local dealer is almost exactly 3 miles from me. Also, the warranty has another 4 months to go.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Yeah, if you can carefully flat bed it into the dealership, and then get volunteers to help you dolly it into the service bay you're good to go.
    I would say, with a 3 year old Prius there are no real "common problems". But with ANY used vehicle you'd want it all checked out as fully as possible.
    You're cutting it close with that warranty. Good Luck with that.
  5. JC91006
    16,674
    8,519
    I also don't think there would be anything wrong with a 3 year old Prius. But you can check the following to make sure all is ok.
    1. Radio and dash display functions work properly
    2. All speakers work without any distortion
    3. No mystery rattles in the car
    4. No interior or exterior parts coming apart
    5. All the shocks/struts are good and not leaking
    6. No fluid leaks in the engine compartment
    7. All windows roll down properly, door locks all work.
    8. Look over the entire car to make sure you don't have any visible defects
    #5 JC91006, Oct 10, 2014
  6. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    A dealership will just fudge a few miles on the paperwork a bit to get you covered under warranty. They aren't going to fight over 5 miles.
  7. prmp945
    prmp945 Member
    79
    59
    Thanks! This is just the type of advice I was hoping for. Some of these things I thought of on my own, but your list is more complete than what I was able to think up.
  8. bisco
    51,155
    welcome to priuschat! i would have them do a thorough inspection, much like they do to certify a used car. wheel hubs, brakes, suspension, undercarriage panels, brake lines, shocks/struts, axles, transaxle, water pump, air conditioning, 12 volt battery and etc. all the best!(y)
  9. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Give us your state of residence we can say something about the longer hybrid warranty...there's not much failure at the 36000 level maybe some rattles as per JC
  10. prmp945
    prmp945 Member
    79
    59
    I used JC's advice to take a close look at the car and did not find anything amiss. Then I promptly drove another 3 miles and went over the warranty limit. Wish me luck, and thanks for the advice!
  11. bisco
    51,155
