New Prius Battery already out of balance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Berch1943, Mar 16, 2021.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    I bought a new battery from NewPriusBatteries just short under a year ago. But on the Dr. Prius app its already showing cell 6 is going off balance with a 0.10-0.20 volt difference. Is that normal? I did not even drive the car as much since I got it (less than 200 miles). Screenshot_20210316-113340.jpeg Screenshot_20210316-113319.jpeg Screenshot_20210316-113306.jpeg
    kenoarto likes this.
  2. ChapmanF
    15,569
    How is the battery being maintained while you're not driving it?
    49,446
    Prodigyplace likes this.
  4. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    I don't think the voltage differences you are showing (.13V, .12V, and .11V) is any cause for concern, and the sample size is too small to conclude that Block #6 is becoming weak (since according to the time stamp at the top of the screen shots, they were all taken within seconds of one another). If you were to report the statistic that shows the percentage of time that Block #6 has the lowest voltage, that might be a little more conclusive. Our Gen 4 was purchased new, and Dr. Prius has always shown some variability in the voltages of the various blocks. I believe it is unrealistic to expect that all the blocks' voltages will always be perfectly aligned, even on a new battery.
    Raytheeagle likes this.
  5. Berch1943
    Berch1943 Member
    146
    Arizona
    Since I don't drive that much, I just drive it about once per week under 10 miles.
  6. Berch1943
    Berch1943 Member
    146
    Arizona
    Yes and he suggested that one of the jumper bolts may not be tightened properly. Because I used a racquet wrench instead of a torque wrench. So that I should take apart the whole thing again just to check.
  7. bisco
    49,446
    yeah, that's not recommended, and can lead to a fire
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    The voltage difference you're looking at is insignificant. Sure, you can verify the torques on the fasteners, but this voltage difference should be at the very bottom of your list of things to worry about. Regardless of what other things you have going on in your life, this should not be anywhere in your list of high priorities.
    davecook89t likes this.
  9. donbright
    donbright Active Member
    241
    150
    33
    oklahoma
    here's some data from my New Prius Batteries on my 2007. Your variation range is 0.1 in your screenshots which seems normal to me. Here mine goes over 2.5 for some moments. It depends on what the car is doing (accelerating, braking with regen, etc)
  10. Albert Barbuto
    102
    95
    Northeast USA
    Log the data during a full acceleration, from a dead stop. You will be drawing 150 amps from that pack. Repost.... :)
  11. Berch1943
    Berch1943 Member
    146
    Arizona
    How did you generate that graph?
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Drive the car. 10 miles a week is nothing and is hard on both battery's. In the morning before starting the car get a voltmeter and check the 12 volt battery at the front jump point. You wont like that either. A healthy happy 12 volt battery in a Prius lives at 12.6 volts.
    At least that's what the 3 battery s I have put in my G2 measured over the last 14 years.
    Take the car for a long drive on the highway.
  13. Berch1943
    Berch1943 Member
    146
    Arizona
    I figured I'm just gonna take the whole thing apart again just to check those bolts. It's possible the vibration can loosen it over time. I ordered an inch/pound torque wrench from amazon so I should be able to verify. better safe than sorry.
  14. Berch1943
    Berch1943 Member
    146
    Arizona
    I found the time to dismantle the thing again. Used my torque wrench and tightened all the jumper bolts to 48inch/pounds. Double checked them all. But module 6 is still showing the weakest. When i examined the batteries, I also noticed these tiny little "bumps" on the plastic endcaps, not sure if it was there before. But i wanted to know what that was and if it's normal.
  15. TMR-JWAP
    6,225
    5,909
    Columbia, SC
    The 'bumps' are just casting flash which is pretty much present on most plastic things that are vacuum cast. Think of when you were a kid and built one of those plastic model airplanes or cars and had to break a small plastic part off that big sheet that had like 20 pieces all connected together. It always left a small tit of plastic sticking out.
    Like this
    Berch1943 and davecook89t like this.
  16. davecook89t
    1,057
    789
    Four Touring
    The main problem I see with those Dr. Prius screen shots is that they are not drawn to the proper scale. This is how the first one should really look:
  17. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    One of things I don't like about Dr Prius app is the auto scaling on the voltage bar graph. It makes block 6 LOOK horrible but really anything under 0.3V is nothing to worry about.
    #17 mr_guy_mann, Mar 28, 2021
    dolj and davecook89t like this.
  18. Berch1943
    Berch1943 Member
    146
    Arizona
    Do you know any apps that output a graph to scale like that? I also have Torque pro, Hybrid Assistant, Car scanner.
  19. davecook89t
    1,057
    789
    Four Touring
    I just used the graphing function in Excel to create that, after copying the Voltage values I saw in your first screen shot.
    In Torque Pro, once you have specified the data set that you want to monitor (the HV Block Voltage for Blocks 1 - 14, for instance), you can touch the gear icon on the bottom left of your Torque screen, and it will bring up a menu that includes "Start Logging". Choosing that will create a .csv file that contains the values you have specified, recorded at 1 second intervals, until you hit the gear icon again and tell it to "Stop Logging". This log is very useful for determining how each block performs under both charging and discharging conditions. One example of its usefulness would be to allow you to calculate what percentage of time each block is at the minimum voltage of all the blocks and what percentage of time it is at the maximum voltage, as I alluded to in Post #4. If you find images easier to work with than raw numbers, that .csv file can be imported into Excel and using Excel's graphing function, you can create line graphs like the one @donbright showed you in Post #9. (I believe I've seen that same ability in Hybrid Assistant, but I haven't used that app as much as I have Torque Pro).
  20. Berch1943
    Berch1943 Member
    146
    Arizona
    I've used the Torque graphing function but I couldn't figure out how to export it to a csv. Is there anything else I should do before I assemble the battery again?
