New Prius - braking
Discussion in 'Gen 2 Prius Main Forum' started by jimfnc, May 26, 2007.
  1. jimfnc
    jimfnc New Member
    New 2007 - 2 days on it.
    When I brake, to me it has a very slight shudder holding the steering wheel.
    Is this normal (like part of the charging system) ??
    Have not driven a car this small in years.
    Love it so far.
    2nd question - anything that can be put on display screen to take out the glare?
    Cannot see during noon, afternoon driving.
  2. Tideland Prius
    16,151
    not it's not normal. You shouldn't feel a shudder through the steering wheel when braking.
    You can buy a hood that helps shade the screen from ebay. I believe the seller is robin? (search Prius Hoods at ebay).
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    You shouldn't feel a shudder. Friction braking starts around 7 mph. Above that it's regenerative braking, unless it's an emergency stop.
    On the other hand, since the brakes see so little use, the front rotors will sometimes rust a bit, so when you slow below 7 mph you hear a crunchy sound and the braking isn't smooth. Take a look at the front disks through your wheels. If they are rusty, don't worry, a little stop-and-go traffic will have them polished smooth in no time.
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I sometimes feel a slight and very quick pull on the steering wheel when I first start regen braking. I think it's because the braking force originates upstream of the axle differential instead of at each wheel like the frictions brakes. It doesn't bother me at all.
  5. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    <div class='quotetop'>QUOTE(tanglefoot @ May 28 2007, 11:10 AM) [snapback]450984[/snapback]</div>
    I agree with tanglefoot, sometimes when applying the brakes there will be a slight pull. usually to the left, not every time, just once in a while. I just ignore it.
