New Prius Decision??
Discussion in 'Gen 3 Prius Main Forum' started by Mustangcobrajc, Dec 12, 2017.
  1. 2007
    0 vote(s)
    0.0%
  2. 2009
    11.1%
  3. 2011
    88.9%
  1. Mustangcobrajc
    Mustangcobrajc New Member
    Maryland
    Hello all, I am going to be buying my first ever prius since I will have to start driving 200 miles a day to work in DC. As much as I am going to miss my Ford 7.3 Diesel lol. So I have found 3 in the area and wanted to get your opinion on them as I do not know as much as you all might. I would like to stay under at about 10k.
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Your attachment didn't open. Maybe wasn't properly done, or something?
    Well, you've got to consider lots of stuffs before buying a used Prius.
    You've got lots of threads on buying a used Prius on this forum.
    I'm sure if you search for used Prius purchases, you'd get lots of them there.
    Decipher those, and you have what info you need.
    Dxta
    49,455
    welcome!
    that's a lot of miles to put on a used prius. do your due diligence before purchasing. if you are in a hurry, just buy a low mile gasser that gets 30-40 on the highway.
    Dxta likes this.
  4. Mustangcobrajc
    Maryland
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Knowing nothing more about these vehicles than what you provided...buy the newest one.
  6. ATHiker
    ATHiker Senior Member
    642
    560
    Massachusetts
    Four Touring
    Lots of Prius have tow hitches — for bike racks — but not so many have harnesses.
    Towing can be hard on any car, and possibly more so on a Prius that does not recommend it.
    Begs some important questions ....
  7. ETC(SS)
    6,554
    My opinion?
    Buy the 09.
    Investigate the vehicle history @ Toyota and have a NON TOYOTA mechanic do a thorough inspection.
    Make the dealer give you the usual vehicle history report.
    If they didn't do one?
    They're either liars or idiots.......walk.
    If the owner of the '11 can provide full maintenance records I wouldn't have any problem getting that one either, but the G3 (2010-2015) has been more prone to using oil and fouling cats.
    This is not a problem if you live on free soil and a VET is an expensive way to scare the heck out of a pet, instead of a state mandated emissions maintenance system.
    Your call.
    I would NOT use a used hybrid for hypercommuting unless I were me, which is to say that no dealership ever touches my cars and I only have mechanics intervene for advanced maintenance.
    In other words......I'm able to do all routine maintenance and many of the repairs that I am likely to encounter on this car.
    If you're not willing to do things like plugs, EGR cleaning, etc.....then you might want to snap the chalk line a little higher than $10K and do some deep reading on Prius maintenance issues.
    The advice on getting a 30-40 MPG non-hybrid is very sound at the $8,000 price point...
    If you get a Prius, get a highlighter and highlight the section in the manual where it says to check the oil every month or 1,000 miles.
    The tow hitch is no factor unless there's a boat or an RV in the yard.
    Good Luck!
  8. mjoo
    mjoo Senior Member
    1,119
    1,314
    Michigan
    I bought a 2010 with 73k miles last year and it came with a tow hitch. If the owner didn't have detailed service records showing that the transmission fluid was changed at least once - I would have walked. In fact, the owner admitted to towing a small airplane at low speeds and I was Ok with it b/c the said oil was changed twice and analyzed.
    I also personally wouldn't touch an older gen 3 with over 80k miles. A plugged EGR system results in up to an 800*F increase in combustion temperatures. This can damage head gaskets and warp heads/cylinder blocks. There are reports here of a few bad head gaskets @ < 100k. Most failed head gaskets are around 150k-200k but why risk it?
    m.wynn and Grit like this.
  9. bisco
    49,455
    @50k/year, how long do you hope to keep it?
  10. Mustangcobrajc
    Maryland
    I am hoping that whatever car I get will last as long as possible. I dont mind doing all the maint as I dont take my vehicle anywhere to get fixed since I usually can. the drive is basically 90% highway so hoping that helps a little with the life span.
  11. frodoz737
    4,297
    2,348
    33
    Assuming you keep up the maintenance as you say...especially the oil/filter...90% highway driving does make for a longer more stable lifespan...even with a Prius. Reduces cycles on the batteries as well.
    mjoo likes this.
  12. ETC(SS)
    6,554
    If you can immediately clean the EGR and if there's some indication that the orig owner changed the oil semi-occasionally AND if service records are available I might have to change my mind and advise that you get the G3 (2011.)
    I failed to notice the Mustang Cobra moniker before (if you roll a Ford then you're familiar with wrenching on a car :) ) and the G3 is a better highway car that the G2, and if you're capable of doing your own maintenance then the G3 will be the better car in the long run for you.
    By the time it becomes an issue for you, the traction battery replacement will be <$1,000 for the G3 and it's a DIY item for many people with more than $100 worth of tools in their garage.
    Since opinions vary, Drive both types.
    You're going to be spending a lot of time in the car!
    I'd also try to find a Madza 3 that some kid hasn't already tried to pimp out.
    I think that I heard whispering in the pine trees that they're re-jiggering the rules on the HOV lanes in your area......like actually making them HOV lanes....so you'll want to pin that down if that's influencing your decision.
    I've got nearly 140,000 miles in a work car that's a G3, and they're good beaters....if you can swing wrenches, and they would still be on my short list for a commuter car.......but there are facets of Prius ownership that should be......ah.....(*) fully explored before you plunk down $10k and adopt one.
    Good Luck!
    Let us know how it shakes out.
    frodoz737 and mjoo like this.
  13. Mustangcobrajc
    Maryland
    Lol yea I have quite the tool collection from the years of ford and chevy maintenace. The 2009 actually got sold the other day so now it is just the 07 and 11. I have also been looking around at other cars around 3000$ with around 100k miles instead, but a hybrid would be great for when I do have to sit in stop and go traffic. I am trying to decide weither 7800$ is a good price for the Gen 3. I found a 13 Jetta Hybrid for 10,000$ with 90k miles. A lot of options to try and pick from if I want something cheap with ok mpg or something double the price with excellent mpg and upgraded interior.
  14. Tideland Prius
    16,151
    Dang it. I was gonna say go for the '09 as well. The Gen 2 is solid and the '09 will guarantee at least the safety stuff like side airbags. (Maybe they were made standard in 2007... can't remember now).
    The Gen 3 will have newer safety requirements built into the body as long as you're ok with the interior.
    If the 7" LCD MFD goes in the Gen 2, it's about $2,000 refurbished and $4,000 brand new. (might be why Toyota went back to the standard radio head unit in the Gen 3 as you see in the 2011 with the 7" LCD as optional equipment). It's not a common problem on the Gen 2 but just something to keep in mind. But mechanically, the Gen 2 is pretty frickin' reliable.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I know people want the advice and opinion, but so often it just is impossible to determine a clear "better" deal with the information given over the internet about "similar" mileage and priced vehicles.
    All the advice about getting as much information as possible, and having it checked out at thoroughly as possible is by default...good.
    But also if I was considering those 3 vehicles, and really wanted to come to decision, looking at, and test driving would be imperative.
    2 of them appear to be at the same dealership, so a test drive and hands on look would be a 2 for 1 trip experience.
    There are a lot of factors, but some not particularly quantifiable. Sometimes with older vehicles, with similar mileage history, you can get a good gut feel, from just looking at them and driving them.
    How worn is the interior? How "tight" does it feel? In general does it have the look and feel of a vehicle that has been well maintained or the tired look and feel of a vehicle that hasn't been? Even a great detailing job, can't entirely hide wear from a vehicle that hasn't been maintained well.
    Sometimes once you actually see the vehicle in person, the decision can become a lot clearer. It can be as subtle as creaks, rattles, and/or just an unkept look.
    But if you're asking which of those 3 is the best deal?
    I certainly can't tell just from those ad's.
    Good Luck.
  16. Mendel Leisk
    38,711
  17. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Personally, I'd go for a well maintained Gen-2. My problem with both of the Gen-2s above is that you're paying a premium for the ultra low miles (given the year). To me that's not a positive selling point.
  18. Johnny Cakes
    Johnny Cakes Senior Member
    1,017
    765
    Virginia, USA
    Good luck with the Maryland / DC commute. It's horrific most days, then it snows/rains and it gets worse. Sometimes 15 miles takes two hours. You are going to be hating life.
    Odd that your location is Maryland but are looking at used cars in South Dakota.......
  19. Paul Schenck
    Paul Schenck Active Member
    522
    306
    Fresno, California
    Listen, I’ve read this thread.... get the Prius you love. From 05 to 09 I’ve got 440,000 on mine now and I’ll have 500,000 on it in 6 months, I’ve replaced the battery twice and the engine and transmission once at 398,000 I did it in my garage and it was easy compared to the 72Jaguar/ V8 Chevrolet conversion, The 2002 BMW Rebuild, The 72 Lincoln Cougar 411 V8 rebuild the Sunbeam Alpine, The VW Buss. This car is an engineering marvel and if you commit to it you will save thousands of $$$
    iPhone ?
    mjoo and Tande like this.
