New Prius IV -- Way to disable some of the beeping?
Discussion in 'Gen 3 Prius Main Forum' started by kilton, Feb 27, 2010.
  1. kilton
    kilton New Member
    CA
    I'm loving my new IV, but two things are a bit annoying: the double-beep when locking or unlocking the doors, and the beeping while in reverse. Is there a way to disable these?
  2. Wiserone
    Wiserone Member
    111
    B R O O K L Y N
    1) I don't know, maybe.
    2) Yes. You need to do it with a scanguage OR ask your dealer. The dealer might even do it for free. Search the forum.
  3. Anthony2816
    Anthony2816 New Member
    37
    I just had the rear beep disabled at my dealer a couple of days ago (a week after buying the car), and they did it for free.
    But before you go, look at all the other options beginning on page 587 of your manual. There may be other things you'd like to change; might as well get them all done at the same time.
  4. IrishPrius
    IrishPrius New Member
    24
    Ireland
    Ya. Dealer just removed reverse beep for free. Beeps once only when first put into reverse.
    He did it by request when doing the brake software update.
  5. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Others have already mentioned the dealer can change the reverse beep to one single beep, but I'll add that they can also remove the beep codes for lock/unlock (see 'customizable features' section of the owner's manual, starting at page 587).
  6. Anthony2816
    37
    You can also choose whether the doors automatically lock when you put it in gear (the default), or not until you actually start driving.
    There's quite a few things that can be changed, but that stupid beeping was the only thing I chose to alter.
  7. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Actually, I'm having trouble figuring out how to disable the locking settings for when you put it in gear. I follow the manual's steps, but nothing changes! Any hints?:confused:
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I had the same issue--the owners manual instructions did not work for me, so I took it to the dealer.
    There's a thread on this, and my recollection is somebody posted instructions that worked for them.
  9. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
    Search for a thread that I had going. You actually have to turn off the one feature, and turn the other on (such as locking when in gear to off AND locking at 12mph on). They don't just switch back and forth for the lock setting. That's what threw me off as well.
