New Prius Owner, 116k, recommended initial maintenance
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by linuxgod, Dec 9, 2024.
  1. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    New guy on this forum, though I spend a LOT of time on ih8mud talking Land Cruisers. I have a feeling I may become a regular here too now though…
    My daughter just bought a used 2013 Prius v with 116k miles. As best we can tell there’s only been oil changes and tires. My local dealer who I normally kinda trust came up with a pretty extensive list of services. I’m wondering the group wisdom for these and/or anything else, as for instance I didn’t see the front diff fluid listed as a service (is it part of the transmission?). Also $205 seems insane for a PCV valve as I replaced mine in my land cruiser for $10 plus about 7 minutes of effort, but I’m guessing it’s a lot more labor to get access on these?
    Hybrid battery filter service...Every 30k or 3 years or as needed...183.00
    Engine coolant drain and fill....Every 50k or 5 years....168.00
    Hybrid coolant drain and fill....Every 50k or 5 years....247.00
    Spark plugs.....Every 120k or 10 years....345.00
    PCV valve....Every 50k miles.....205.00
    Trans service.....Every 60k miles or 5 years.....295.00
    Brake Flush.....Every 25k or 3 years....188.00
    Throttle Body cleaning....Every 25k or 3 years.....90.00
    Engine decarbon service....Every 25k or 3 years.....330.00 with oil change
  2. BiomedO1
    BiomedO1 Senior Member
    4,352
    2,282
    Left Coast
    Welcome
    ALL those rates are excessive, IMHO!!!
    Yes, part of the ATF.
    Engine coolant drain and fill....Every 50k or 5 years....168.00; Do it yourself or find an independent shop, many DIY videos on YouTube
    Hybrid coolant drain and fill....Every 50k or 5 years....247.00; Ditto
    Spark plugs.....Every 120k or 10 years....345.00; Ditto
    PCV valve....Every 50k miles.....205.00 - Not needed - The entire PCV system should to be de-carbonized and cleaned out, get more info.
    Trans service.....Every 60k miles or 5 years.....295.00, OK, but a bit on the high side - may be safely pushed to every 100K IMHO.
    Brake Flush.....Every 25k or 3 years....188.00; a bit on the high side and excessive - dip a brake fluid tester in the reservoir. Should be done every 3-5 years, depending on test results. I know of cars with over 300K and 20+ years old, with original brake fluid - but these brake by wire systems isn't going to take that kind of abuse.
    Throttle Body cleaning....Every 25k or 3 years.....90.00; Do it yourself or find an independent shop - excessive, every 100k miles is fine. @1/2 hour labor - they're probably just spraying some Berrysmen carb. clean down the throttle body.
    Engine decarbon service....Every 25k or 3 years.....330.00 with oil change, Get more details, what's actually being done? Chemical treatment? Most likely don''t need it; If your using full synthetic oil on all the oil changes - definitely not needed.
    The Carfax maintenance record should drive your decision. If the car was maintained as stated above, you've got a winner. Just a FYI: These 3nd gens are know to blow head gaskets and malfunctioning brake by wire systems; both costly repairs ($3k+ each)
    Hope this helps.....
    #2 BiomedO1, Dec 9, 2024
  3. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    The labor rates at the dealer here are something like $150/hr. Yea they’re excessive, but I’ve had a lot of trouble finding an honest shop on the north side of Chicago so I tend to use them and suck it up.
    I probably can do all the maintenance listed myself, but it’s about to get down to 14F here shortly and I’m starting a new job in January so DIY is really a limited option, save for the “hybrid battery service” which I think is vacuuming out the air filters.
    #3 linuxgod, Dec 9, 2024
    52,536
    run, run away as fast as you can.
    job #1, clean the egr circuit before the head gasket blows.
    watch
    Tim Jones likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,674
    6,698
    Texas Hill Country
    -There is no filter... off to a bad start. First the intake is under the passenger rear seat and only has a plastic strainer to keep socks out. Second, if the car had animals shedding in it, the blower squirrel cage may be dusty. Usually fine and has no official schedule.
    -Yes but its one of the easiest drain and fills ever. No fancy bleeding or flushing needed.
    -Yes after the first at 150k. Also pretty easy.
    -Yes. Somewhat difficult as it requires complete removal of the wipers, housing (cowl) and wiper motor. Many go 150k with oem plugs. Maybe 4 of 10 for difficulty.
    -PCV valve....Every 50k miles.....205.00
    It is hard to get to, generally requires removal of intake manifold and various hoses and pipes.
    -Transaxle service maybe a 3 of 10 drain and fill.
    -Every 75k-100k would be fine. To do it right on a brake by wire system requires Techstream.
    -50k to 100k would do it. About a 2 of 10.
    -A complete waste of money the way they do it. Most never do it.
    -A key item missing is oil burning preventative maintenance. These cars have many flaws and oil burning can run you out of oil in 5k miles. 5k oil changes like your wallet depends on it as a priority over any of the above.
    Many of us would have recommended against this generation of Prius bought on the used market.
    #5 rjparker, Dec 9, 2024
  6. Mendel Leisk
    42,049
    Just cherry picking from the worst offenders:
    I DIY’d both of those about 4 years back, and the hybrid coolant drain/fill is easier of the two, and less coolant needed as well.
    That’s absurd, shouldn’t be more than $100. It’s different-but-similar to an oil change.
    yeah I would back away from that place, get the Toyota schedule. If you do business with them, tell THEM what you want done.
    I would look into EGR cleaning, soon. More info in my signature (on a phone turn it landscape to see signatures).
  7. BiomedO1
    4,352
    2,282
    Left Coast
    If your going to pay that kinda rates, try this guy: TCCN Automotive; don't know how far he is from you - but seems to be no fuss, honest. Beware, I haven't dealt with him personally, but he puts out pretty accurate and honest videos (the car care nut).
    Good Luck....
    $150/hr is on par with a large city; I believe SF is closer to $200/hr. What I don't like it the questionable services and value, they are recommending! ($90 to point a can of carburetor cleaner down the throttle body)
    #7 BiomedO1, Dec 10, 2024
  8. Leadfoot J. McCoalroller
    8,172
    7,679
    Pennsylvania
    2018 Prius c
    Maybe don't do any of that until you're sure you're going to keep it.
    Lots of stories of new owners of that model over-spending on vaguely preventative stuff only to be faced with a real wallet-buster 2 months later.
    They really were great when new but they haven't aged well.
  9. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    Thanks. If I can find a place around that is familiar and will do the EGR cleaning that would be ideal. I've called several shops (including the dealer) and all anyone around here will do is replace it.
    TCCN is about 90 minutes southwest of me (roughly 50 miles). I can't believe there's not an honest shop somewhere on the north side of the city that isn't exorbitant, but I've yet to find it. I may send them a message to see about service... it just means a very expensive Uber back or a car rental for a day or two.
    Understood. Unfortunately the condition of 2nd Gen vehicles around Chicago seemed to be really poor (much higher mileage, more general issues/repairs needed, lots of body damage). On the plus side my daughter will probably drive 5k miles/year around the city and we paid $8400 for this particular vehicle so even if I had to replace the head gasket at some point or rebuild/swap the engine we're still in good shape.
  10. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    BTW I don’t know if there’s a consensus about whether reading the EGR intake pressure is a good indicator of EGR condition but OBD Fusion reads 3.0675psi, which converts to >21kpa. That’s after maybe 200 miles of mostly city driving but with a brief ~15 mile highway jaunt at 70mph. It seemed like those who have cleaned theirs were seeing values around the range. I’ll have to monitor for the next couple days until my daughter gets home from college and commandeers her car back to see if this changes.
    Brian1954 likes this.
  11. rjparker
    10,674
    6,698
    Texas Hill Country
    It is a good indicator of egr flow and is calculated per drive in most cases. The system will code on poor flow OR excessive flow when the egr has been commanded closed - such as at low rpm or wide open throttle.
    Which is the reason almost no one outside of Priuschat cleans them including TCCN Automotive. It is true these engines often burn oil which can clog egr passages and reduce catalytic efficiency. For those reasons I monitor both several times a year.
    I replaced the egr cooler at 150k and swapped for a cleaned cooler around 300k miles. I also have the revised egr valve and the latest US ecm software.
    #11 rjparker, Dec 10, 2024
    Tim Jones and Brian1954 like this.
  12. Mendel Leisk
    42,049
    If you’re saying the only reason EGR system is clogging is those pistons rings, I would disagree. I’ve yet to see any dipstick drop between changes, but getting the usual EGR carbon build-up.
    thoughts about EGR flow monitoring:
    1. even with “sufficient” flow, the carbon on the cooler fins may be reducing its cooling efficacy.
    2. even with “sufficient” flow, the EGR capillary passages in intake manifold (one per port) tend to carbon-clog sequentially, with cylinder one end fully clogged ahead of the rest.
  13. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    I'm sure it's a good PM to clean the entire intake and EGR system regularly (whether that's every 50k, 100k, etc). But the couple readings I got (3.0675 and 3.011 psi) put us in the 20-21+ range, which seems pretty good. This car came from Jacksonville and St Augustine Florida, so maybe the perpetually warm temps and lots of suburban or highway driving there have helped limit build-up. The Carfax history shows oil change intervals anywhere from 2k to 10k miles so who the heck knows. So I may wait to clean the EGR system for now since it's 25F this morning and dropping, but when the weather permits (probably in the spring) I'll pull the pipe since it's 4 bolts and use that to assess whether I need to dig into it further.
    Unrelated but since I think it was mentioned earlier... Carfax says the brake booster was repaired/replaced at 68k miles in Jan 2023 (which also means the last owner put 50k miles on the car in 2 years)
  14. CharlieS
    CharlieS Junior Member
    1st I would like to apologize, I do not know how to post a private message to Mendel Leisk. Maybe this will be helpful for others idk.
    Mr. Leisk a few years ago you had posted an Excel spreadsheet regarding maintenance for the Prius. My question is once you surpass the mileage on the spreadsheet (185K) do you return to 85k and follow the maintenance schedule from that point moving forward?
    Thank you
  15. Mendel Leisk
    42,049
    I extended the Toyota USA schedule for 3rd gen Prius (should be applicable to Prius v as well) to 240k miles, in the attached spreadsheet, so at 185k you'd still be within that table. It's pretty straightforward, if you wanted to extend it further; once a service has repeated, you can extend the table as far as needed, just maintaining the same intervals.
