New Prius owner - my first question - High beams not much better than low beams
Discussion in 'Gen 2 Prius Main Forum' started by Jaichim24, Nov 13, 2009.
  1. Jaichim24
    Jaichim24 Junior Member
    New England
    So I'm in my second week of driving my "new to me" 2005 Prius. I'm enjoying it so far. I'm trying to put together a few issues to bring back to the dealer to look at. I thought I would post here to see if they are a problem, or just something I need to get used to with the Prius.
    I am not happy with the illumination of my high beams. When I switch from my lows to the high ones, there is very little if any additional illumination outside the area that the low beams already shine in. The high beams simple fill in the "gaps" where the low beam do not fully illuminate. Perhaps the "shift up" in the lights is under a foot. No new area is illuminated, just the existing area is more brightly illuminated.
    I am used to high beams making both lanes of a road visible, perhaps even the edges of the road. When I am coming home from work, I need this visibility because deer frequent my road. As it stands now, I'll either have to crawl down my road or risk smashing into a deer.
    Does my description of the high beams sound normal for a Prius? Could they need some sort of adjustment? Any suggestions, comments, ideas would be greatly appreciated. Does this sound like something I should have the dealer look at and try to fix?
    Thanks in advance for the assistance.
    Jai
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Your profile does not list the package. Do you have HID headlamps or halogen?
    Tom
  3. Jaichim24
    New England
    Any quick way to determine this via the VIN # or something? I know the dealer printed out the original sheet of options selected and gave it to me. The person at the time mentioned something about the package but I can't remember. I'll see if I can find this piece of paper.
    Otherwise I have all the owners manuals etc, but I don't know if they were specific to the package number.
  4. Patrick Wong
    18,200
    6,493
    If your car has foglamps, then it has HID headlamps.
  5. Jaichim24
    New England
    Ok, I found the vehicle inquiry report the dealer gave me. On the second page it says the car had package # 6. This included the Headlamps w/Auto Leveling Feature.
    It also has the front fog lamps.
    Just googling the HID Prius head lights brings up a bunch of things, such as $1k fixes for the replacement of the system.
    So, what should I be looking for to determine if something is defective?
    I have a 2004 Lexus RX330 which I believe has the auto leveling feature. I see the head lights shift slightly each time I brake. I do not notice this in the Prius.
    Thanks again for the assistance.
    Jai
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Your Lexus uses an active leveling system... It adjust under turns, acceleration, and braking.
    Your prius does not adjust like that. It adjust when stopped... And that's about it. Maybe your rear leveling spring is rusted up. (there are post on it)
    I love my HIDs. They don't have the super high beams that a Lexus has because the Lexus uses halogen bright... Your prius doubles up the HIDs for low and high beams.
    They don't really illuminate the side as much as adding "taller" light in front of you... Not to the sides too much. Your RX has what I would call "train lights" (incredibly bright spots that illuminate everything... Up, left, and right.)
  7. Patrick Wong
    18,200
    6,493
    Hi Jai,
    Now that we know you have the HID lights, I would say that there's nothing wrong with them, and no adjustment will help the particular issue that you've described.
    A number of Prius owners have reported sharing the same space at the same time as a deer, so I hope that you will drive at a speed that is suitable for your conditions.
    Auto leveling means that in theory, as you add weight to the back of the car, the headlights will point downwards to avoid blinding on-coming traffic.
  8. Jaichim24
    New England
    Thanks for the explaination on what the auto leveling is.
    And yes, it does appear, and make more sense now that I understand how the HID lights work, that I will have to be very careful coming down my road.
    Any Prius owners found some sort of alternative?
  9. qbee42
    18,058
    3,076
    Northern Michigan
    Check the auto leveling to make sure it works. Turn on the lights and walk around to the back of the car. Note where the lights hit - it helps if they are pointed at your garage or something like that. Now climb up on the rear bumper. Your weight should raise the aiming point. In about two seconds the lights will automatically adjust down. Climb off and in about two seconds they will aim back up.
    If they don't auto level, it could be that your lights are locked into the down position. When this happens it's very hard to see down the road.
    Give it a test and let us know what happens.
    Tom
