New Prius Owner
Discussion in 'Newbie Forum' started by SonnyNorCal, Nov 2, 2013.
  1. SonnyNorCal
    SonnyNorCal Junior Member
    Northern California
    Hello everyone. Figured I would check in here, as I just purchased a new (to me) 2010 Prius II Hatchback today. Been an owner of almost every kind of car, from Volvo to Saab, to a Mustang GT, to the most recent, a 2010 Ford F-150. (and a lot in between all of those)
    If someone would have told me a couple years ago that I would buy a Prius, I would have scoffed at the idea. However I recently incurred a longer commute (45 miles each way), and the F-150 was literally robbing my wallet. Being in Nor Cal, you see a Prius on every corner, and I started to investigate them, researching, etc. for about a month before I made my decision.
    I didn't buy the Prius to save the world, live green, or anything like that. Although you do feel a lot less guilty driving one than an F-150. I simply bought it to save money on gas, and the technology really impressed me.
    Initially I was intimidated by the size of the car. I am 6'3" and I thought I simply wouldn't fit. I have more leg room in this Prius, than many other cars I've owned. Its amazingly spacious inside.
    I drove a Toyota Hilux in Afghanistan a long time ago (military) and was amazed by its durability, so I am looking forward to many great years with this car. Also look forward to any advice you all may give a newb.
    Thanks
    spiderman and JMD like this.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Congrats on the new car. Definitely saving money on gasoline is a huge benefit. I only owned a Prius one year. My only advice is follow the maintenance schedule. Since the transmission which Toyota calls a Transaxle does most of the breaking to regenerate the battery I suggest you have the dealer change the transaxle fluid at 30,000 miles and every 60,000 miles thereafter. If it has not been done best to do it. The cost is $100. Transaxle failure can cost thousands so the fluid change is cheap insurance. Toyota recommends 100,000 miles but many will disagree. Other than that enjoy the car
    SonnyNorCal likes this.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard and enjoy the ride! Pretty much the same story here.
  4. Jae Sea
    Jae Sea Junior Member
    I just bought a used 06 with 88k miles. Mine "shifts" hard between the gas engine and electric engine, especially when I have the heat on. I can't seem to find an answer for that on this site. Any ideas what I need to do? Seems to be getting worse, too. I was going to change the spark plugs. What are the best plugs for this car?
    Thanks
  5. SonnyNorCal
    Northern California
    JMD, Thank you for the advice. I purchased my Prius with around 27,000 on the ODO, so I will definitely look into the transaxle fluid change soon. (I am not sure if the dealer I purchased it from did that service) I did buy it from a Toyota dealership, and the car fax showed faithful service up until I bought it.
    Sonny
    JMD likes this.
  6. bisco
    49,500
    all the best!(y)
