New Prius owner
Discussion in 'Newbie Forum' started by Tevin, Mar 7, 2018.
  1. Tevin
    Tevin New Member
    Lynchburg, VA
    Hey guys! I was given a 2005 prius with over 235,000 miles on it back in October. I drove it from St Louis back to Lynchburg Va and it did amazing! It now has about 254,100 miles and is still running strong. I want to keep her alive as long as I can. The most I’ve spent in gas to fill up was about 15 bucks and I average around 45 mpg. What are some suggestions for maintenance since this has so many miles?
  2. hill
    8,167
    Welcome! Do you have the manual? In it you will find the regular & important stuff. Mostly, oil changes. Some of the Prius will go over 300K on the original traction packs before they need to be rebuilt. Even then, you would primarily notice a drop in MPG.
    RCO likes this.
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Welcome!
    I work in Lynchburg and live just south in Evington!
    @Raytheeagle and @danlatu are a couple of the experts here. In addition to what they would recommend for the mechanicals,
    I think a Prolong battery conditioning system from Hybrid Automotive is useful to extend the life of the large traction battery. @jeff652 is a trusted user here. If you are a college student, that may be too much to consider right now.
    RCO likes this.
  4. Tevin
    Tevin New Member
    Lynchburg, VA
    I’m a recent grad, started my job in may but I may consider that to keep her going. The battery was apparently changed out in 2013 at 116,000 miles
    Prodigyplace likes this.
  5. Tevin
    Tevin New Member
    Lynchburg, VA
    Thanks for the welcome! Yes I have a manual and I’ve been thumbing through it. The only thing I need to look into is changing out the spark plugs. I got a code for multiple random misfires which usually only happen when it’s freezing and I let the heat run in the morning before going to work, other than the headache of having to get my right taillight replace, everything has been smooth sailing
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
  7. Prodigyplace
    11,696
    11,318
    Central Virginia
    I almost forgot. The local dealer, Oak Ridge Toyota is not good for sales or service. I only go there for recall work or to look at a car before buying elsewhere.
    My preferred dealer is in Manassas near DC. My preferred salesman still drives a 2002 Prius. The price savings and better experience are worth the 150 mile trip.
    RCO likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    As others have said, confirm it is a new Toyota battery and if it is, you’re good for a fair bit of time:).
    Random misfires could be spark plugged or COPS, when was the last spark plug change out?
    Keep us posted (y).
    RCO and Prodigyplace like this.
