New Prius road noises is this common?
Discussion in 'Gen 2 Prius Main Forum' started by FishHawk, Jun 27, 2006.
  1. FishHawk
    FishHawk New Member
    176
    Picked up my new Prius today and noticed a scraping sound and road noise. Could it be the cheap Goodyear tires or the new brakes? Has anyone experienced this ? Thanks FishHawk
  2. Tideland Prius
    16,445
    umm... we'll need more information.
    When does the sound occur? where do you think it's coming from? under what conditions? etc
    As for road noise, it's not exactly a Lexus.
  3. daniel
    14,487
    1,519
    Spokane, WA
    Your perception of road noise will depend on your previous car.
    The brakes in a Prius are used only below 8 mph, or if you press very hard on the brake pedal, calling for an emergency stop. Otherwise motor-generator 2 (MG2) slows the car by converting its kinetic energy into electrical energy to recharge the battery.
    There should not be any scraping sound. Perhaps you should have it looked at.
    I had a rattle when my Prius was new. Turned out to be my garage-door opener, which I found it convenient to put in the cup holder. Closing the top of the cup holder over the opener solved it.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I noticed road noise when I started driving our Prius, but only because the engine noise was so low. A lot of the perception of noise will depend on what type of car you are used to. That said, there shouldn't be any scraping sound.
    Tom
  5. I have noticed road noise, as well as engine noise and the MG charging noise.
    im not sure if its because i now listen for it, or the car is actually getting louder. but a scraping noise, sounds like you should have you car looked at.
    i am a little dishearten by road noise, so i am in the process of deadening the floor one day...
  6. Rogust
    Rogust New Member
    28
    <div class='quotetop'>QUOTE(TheParadox @ Jun 27 2006, 09:51 PM) [snapback]277768[/snapback]</div>
    Just wondering how the "deadening" is going? Doing the doors after the floor?
    [email protected]
  7. FishHawk
    FishHawk New Member
    176
    <div class='quotetop'>QUOTE(Rogust @ Jun 28 2006, 06:32 AM) [snapback]277950[/snapback]</div>
    The noise is not that consistent. I occurs when I'm turning slightly. I'll give it more time and if it continues I'll have them look at it. Could be a little rust on the disk brakes, we've had a lot of rain up here in Ma.
  8. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(TheParadox @ Jun 27 2006, 06:51 PM) [snapback]277768[/snapback]</div>
    Start by getting some decent tires. They don't have to be Comfortreds, but that's what I put on about two weeks after buying my car. Immense improvement in road noise as well as all other aspects of handling and cornering.
  9. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    The first thing I noticed whrn I picked mine up was the tire noise! POOO on the dealer for not cooperating about my tire upgrade.
    Couldn't wait to get my michelin hydroedges ! !
  10. jamarimutt
    jamarimutt New Member
    985
    <div class='quotetop'>QUOTE(jbarnhart @ Jun 28 2006, 03:36 PM) [snapback]278179[/snapback]</div>
    Immense improvement also in mpgs? <_<
  11. jbarnhart
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(jamarimutt @ Jun 28 2006, 07:28 PM) [snapback]278403[/snapback]</div>
    I detected no discernable difference. I keep mine at 40/38.
  12. theorist
    theorist Member
    365
    Lexington, MA
    Since installing very quiet Continental ContiProContact tires, I'm hearing all sorts of sounds I didn't notice before. It's sort of nice to be able to hear the HSD at work.
  13. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Try the clean-off-the-rotors trick -- do a slowdown in neutral,
    letting the physical brakes take all the load, and then see if
    that changes anything..
    _H*
