new Prius smells like something's burning
Discussion in 'Gen 2 Prius Main Forum' started by wowser, Dec 20, 2007.
  1. wowser
    wowser New Member
    31
    I got a 2008 Package 2 Prius a few weeks ago. It has about 800 miles on it. On the way down the mountains in Palm Springs, the cabin filled with the most awful smell of burnt plastic; so much so that we had to open all the windows. There was no smoke however. There was no indication that anything else was wrong. When we were off the mountain, there was no more smell. Should I be concerned or is this just new car stuff "burning off."
    Also, I am sure this has been asked before but I can't find an answer. WHen I have the car on Auto Climate, the AC button is lit, no matter what the temp. My question: is the AC always running or only when the ambient temperature is higher than the temperature you set?
    btw, Love, Love, Love the car! My wife and I fight over who gets to drive it and the kids say it's more comfortable than our RX300!
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    The "B" on the gear joy stick is to use in such situation. It will use the gas engine to brake to relief all the work from the pads.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Never experienced that smell...doesn't sound as if anything is bad wrong though heavy use of the HV battery/Inverter has been known to create an electrical burn smell by some. If you were using that system heavily in the mountains that 'might' account for it...but I'd still call it abnormal.
    AC does not me "cooling"...it should better be called "CC" for climate control. Yes, it's supposed to be lit when you're using the auto setting and it will heat the car when it's cold and cool when it's hot.
  4. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    By any chance, did you have the steering wheel turned into one direction for a very long time?
    I remember in the manual about the electric steering that it could overheat if you hold it in one direction for a long time. Considering you were going down along a path, I doubt that is the issue.
  5. adamwmcanally
    adamwmcanally New Member
    67
    mobile, al
    Don't know about the burning.
    But when the climate control is in auto it defaults with the AC on (no matter what temp. you have set) While the climate control is in Auto, you can go to the climate screen and touch the A/C button to turn the Air Conditioner off but still maintain automatic climate control.
  6. djelsewhere
    djelsewhere New Member
    Valencia, CA
    I was also wondering about that AC light. In most cars, it means the AC compressor is running, which would be a waste if you're running the heater. I suspect (hope) the system is smart enough to shut that down when not needed even though the indicator remains lit.
    As for the burning smell, I experienced that as well on the second day I had the car. I was on the freeway on level terrain. The smell was very brief and hasn't returned since. Nothing seemed amiss, so until I saw this post, I had concluded that perhaps it was coming from the car ahead of me. It could have been some sort of factory coating burning off something, as you said. I'm not too worried.
  7. wowser
    wowser New Member
    31
    Thanks everyone. No I didn't have the steering wheel turned hard one way. Yes, I did use "B" going down the mountain. The smell was really bad but cleared up when down the mountain. It is possible I did suck up bad air from cars ahead. When at the top of the mountain I did notice the parking lot stunk of overheated cars!
    One more thing. The car has had knocked a bit when the ICE shut off. Nothing really bad, just not a smooth shut down. Is this normal?
  8. siouxnami
    siouxnami New Member
    16
    Rochester
    Actually I had this happen as well, I just got my Prius. I think the smell was the tires. Mine went away after less than 100 miles though. I'm pretty sure it is the tires because confidentially I also just had new tires put on an older vehicle and I got the same smell. Call it tire burn in...
  9. edselpdx
    edselpdx Member
    191
    Portland, OR
    I, too, suspect brake pads even if you used "B". This happened to me when descending a big slow dirt road downhill (~25 minutes downhill at 10-20 MPH, battery way on green after less than 5 minutes even with "B") while visiting friends in CA last summer. I really wouldn't worry unless it recurs in different situation. Once the battery's completely charged, you use those brake pads MUCH more than you would normally.
  10. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    First: the A/C compressor is electric. It is run off the HV system and only runs when the ECU decides it needs to. Therefore, setting the temp to the highest comfortable temp will result in the best fuel economy.
    Second: unfortunately, smooth shutdown of the ICE is not always accomplished, I believe it is due to a slight dieseling effect of the engine still trying to run even though the ECU has shut off the fuel, possibly MG2 not quite disengaging quickly enough or maybe the engine stops at a point where the cylinders have enough compression left to cause the crankshaft to move a half a revolution or so. It's just an opinion and a best educated guess. However, it is common and is not dangerous.
    Third: the burning smell may very well have been from other cars, or it may have been trash/foreign object on the catalytic convertor. I see a LOT of that. Plastic bags stuck on the cat and melted into a rock solid blob which must be chipped off and the residue allowed to burn off.
  11. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    It's not a waste if you're running the heater; ok maybe the heater, but not with the defroster and heater. You'll find the defroster works better because the air is still being dehumidified when the compressor runs.
    Bear68 has a good point - dieseling of the engine will occasionally occur. I just noticed it happened once to my car a couple days ago in perfect conditions. But I have a funny feeling you were riding the brakes all the way down that hill, causing the nasty smell. What are the two nasty automotive smells that seem to cook up more frequently on slopes? Clutch and brake. And with no clutch, per se, it has to be brakes.
    ~ dan ~
  12. weoner
    weoner New Member
    yesterday, after six days of driving the car i finally gave it the foot fr a block or two and the smell showed up, good thing was that aftee that it ran much more efficient
  13. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Quite true with a conventional car but not a Prius. The mechanical brake pads do not touch the rotors unless you are under 9 MPH or in a panic stop situation. Riding brakes on a downslope just adds to regen. This will lead to the so called "dieseling effect" when the ICE is being turned to lower the SOC of the HV battery after heavy regen.
  14. Mawcawfee
    Mawcawfee Prius-less (for now)
    98
    The Free State
    Was this the first time you drove the car that long and far? It sounds to me like the shipping coating finally burned off the exhaust manifold. I have had the same thing happen on other Japan-built cars I bought new. After several hundred miles, the coating finally gives up the ghost and quickly burns off with a strong chemical odor. Perfectly normal.
  15. fruzzetti
    377
    You're gonna have to prove that to me using documentation. I refuse to believe there is no mechanical link between the brake pedal and the hydraulic brakes. Why else would they work when the car is off?
    ~ dan ~
  16. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Take a look at the lost front brakes completely thread. Post 24 by Jayman contains two attachments which diagram how the Prius brakes system works. My understanding is that a fail safe mode assures that a solenoid valve in the brake actuator opens, when necessary, to secure hydraulic fluid passage between the master cylinder and the wheel cylinder.
  17. seasalsa
    1,278
    Kent, WA
    I believe that when OFF the car is traveling less than 9 MPH. ;)There is plenty of documentation on the Prius Brake System , the search feature will help.
  18. fruzzetti
    377
    Thank you. That explains the process. Even still, you don't think that enough downhill slope will engage the brakes? I mean I can't believe the car wouldn't know better than to let you overheat the inverter fluid...
    The correct way to respond to a request for documentation is to honor it. The minute you demand that others seek out support for *your* argument is the minute you lose all credibility.
    Thanks, IsrAmeri. It seems from this chart that the vehicle diverts pressure to the brakes when the MG* system isn't applying enough braking energy. I would imagine that there are more events than a "panic stop" that would require direct braking energy; but I am not a Prius engineer. At least the schematics shed some light.
    ~ dan ~
  19. thusly
    thusly Junior Member
    Brooklyn, New York
    After about 6000 miles, my 2007 Prius Touring model started smelling as if a plastic bag was melting on the muffler. It seemed to happen when I used the auto climate control to warm the passenger compartment. The smell was also evident from outside. I just opened the hood, found, and removed many leaves. Could this have been the problem?
    Thusly
  20. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    My wife's 2005 Prius did this for a couple of weeks, but my Prius, bougth 6 months earlier, did not. To me, it smelled just like the smell of burning plastic spoons; a smell I remember well from my Boy Scout camping days. It mostly went away after about a week, which was about how long I was going to give it before taking it back to the dealer. It was completely gone after a couple of weeks.
