new recall Safety Recall H0U: 2016 Prius; Inverter Assembly Replacement
Discussion in 'Gen 4 Prius Main Forum' started by waheed, Oct 18, 2017.
Tags:
  1. waheed
    waheed Junior Member
    17
    jordan
    anyone with TIS Subscription can post PDF here for this recall please:
    Dealer Letter:
    i have links to TIS(but i don't have a valid subscribition to TIS) but can't post here because i am new member.
    Thanks
    Elektroingenieur and RCO like this.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    @Elektroingenieur may be able to enlighten us.
    RCO likes this.
    49,488
    i wonder if this is non u.s. only?
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Which battery do you have?
    RCO and Prodigyplace like this.
  5. waheed
    17
    jordan
    i got the document but i can find that only six vehicle covered by this recall.
    document attached
    • h0u.pdf
      File size:
      285.9 KB
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
    You are in Jordan and it is a Toyota North America recall for 6 (?) vehicles improperly assembled.
    i would have expected them to list the VINs affected.
  7. waheed
    17
    jordan
    To let you now about 70% of all Prius here in Jordan imported from us of course used one.
    Before finding the document I though it will be big recall !
  8. Prodigyplace
    11,696
    11,318
    Central Virginia
    Perhaps they meant six trim levels.
  9. waheed
    17
    jordan
    I don't know did you read the document Iattached?
  10. Prodigyplace
    11,696
    11,318
    Central Virginia
    It said six vehicles. It is strange that it is not listed on toyota.com/recalls.
  11. waheed
    17
    jordan
    You need to insert VIN for one of that six vhicles . And I think more details will be in another document
  12. Elektroingenieur
    2,515
    3,259
    Three Touring
    The recall @waheed kindly reports here is similar to one announced a few days ago on Toyota’s website in Japan: Report Number 4128, “Recall of Prius, C-HR,” October 18, 2017 (page in Japanese).
    The recall in Japan affects a similarly low number of vehicles: only nineteen Prius cars, of all three models (DAA-ZVW50, DAA-ZVW51, and DAA-ZVW55), and one C-HR. The report and its accompanying drawing (also in Japanese) give a few more details about the problem. Very loosely translated:
    In some voltage converters (inverters), there are capacitors that are not bolted to the main body of the voltage converter and are supported only by terminals, due to incorrect processing during assembly. Running vibrations can cause the terminals to break, and a warning light would come on. In the worst case, the car might not be drivable.​
    As with the recall in the U.S., the remedy is to replace the entire inverter assembly. I don’t know if any vehicles sold in Europe or other countries are also affected.
    I expect the recall will eventually be added to MLIT’s recall list (in Japanese) and to the Recalls and Foreign Campaigns sections of the NHTSA website. I assume the lack of publicity is due to the small number of affected vehicles and Toyota’s plans to contact each owner or lessee individually—though last year, Toyota did issue a press release for a recall involving only twelve cars.
    RCO likes this.
  13. Prodigyplace
    11,696
    11,318
    Central Virginia
    I searched NHTSA foreign campaigns and this one seems to allude to some US vehicles affected. Perhaps the op's recall.
    https://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM569302/FRCL-17F191-9935.pdf
    7. Reason the similar vehicles sold in the U.S. are not involved in this safety recall / other safety campaign: Toyota filed a Part 573 Report with NHTSA on October 18, 2017 concerning this same issue and is conducting a safety recall on certain 2016MY Prius vehicles covered by that report. This recall involves only Prius vehicles which are equipped with specific inverters which records show may contain a capacitor that was improperly installed to the inverter housing. Other substantially similar vehicles sold in the U.S. are not equipped with those inverters.
    RCO likes this.
  14. Elektroingenieur
    2,515
    3,259
    Three Touring
    It’s hardly worth comment, since so few vehicles are affected, but NHTSA has now posted Toyota’s Defect Information Report, Dealer Letter, and Remedy Instructions for Safety Recall H0U. According to the Defect Information Report, these are the VINs for the six affected vehicles sold in the United States:
    • JTDKARFU1G3501072
    • JTDKARFU6G3507661
    • JTDKARFU8G3523733
    • JTDKBRFU2G3512983
    • JTDKBRFU5G3502769
    • JTDKBRFU7G3501607
    The Defect Information Report also explains how Toyota was able to identify the affected inverters, which all had an “improper rework operation at the inverter assembly plant”:
    Toyota began investigating the cause of the missing bolts by reviewing the production history data and the capacitor installation process. It was found that the inverter was reworked in the capacitor installation process, and the bolts were not installed during the rework process. Toyota also confirmed that some other inverters were reworked and the bolts may not have been installed. The capacitor installation process was improved to prevent incorrect rework operation, which could cause the bolts to not be installed.​
  15. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
