New Smart Key Watch from Toyota
Discussion in 'Gen 2 Prius Audio and Electronics' started by ceric, Feb 22, 2006.
  1. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    Now this is a cool watch to have if your Prius has the Smart Key option. It's an accessory of Estima (new). I wonder if it works with our Prius. Some key points from the text:
    - powered by light (no battery)
    - made by Citizen
    - About $400 in Japan.
    http://response.jp/issue/2006/0222/article...ges/109035.html
  2. jayway
    jayway New Member
    SF CA
    i want one, anyone know how to get one?
  3. aaf709
    3,862
    2022 Prius Prime
    If it's like the one at http://www.wristdreams.com/ I think it will. There is a potential problem IIRC that's minor. The watch is solar powered, but the Smart Key part is still battery powered. There's a possibility that the battery could die and you wouldn't be able open the door or power up. That is minor if you change the battery on a regular basis.
    Personally I feel that $400 is a little steep to get an analog watch that gives no date and will do exactly what I can do with the fob I already got with the car.
    That being said, if it was $100 I'd get it. :)
  4. naterprius
    naterprius Senior Member
    1,843
    Nobody has brought this to the USA yet, hard to say if the frequencies are the same and whatnot.
    Nate
  5. 925PriusGuy
    925PriusGuy Winter Gray & Blizzard Pearl Pri
    148
    Northern California- SF East Bay
    I checked on this watch back in December, it's not compatable with the Prius (at least that's what I was told :(
  6. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    That's too bad. I'd buy one if they were compatible!
  7. tideland_raj
    tideland_raj New Member
    108
    Sunnyvale, CA
    I'd second that... I wonder if we could setup a site to petition Toyota to release this or resell it to the US? The James Bond style wow-factor here is huge (thinking of saying "wonder what time it is... ah, it's time to go for a spin!" and unlock the car using the buttons visibly).
    Right now, people know I have a key (fun demo is to give THEM the key while I drive... really hits home the usefulness of SKS)... but if they never even see it
  8. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    All:
    If someone located in Japan could make an inquery to Toyota about its compatibility with Prius, it would be great. We could do a group buy if it is compatible with a Prius. Remember that this is a new accessory of Estima that was just annouced.
    About the battery, according to the translation...
    "but even with when the electric battery is cut off, when you bring close to the engine start button, it is designed in such a way that the electric power which is necessary for certification with induction is supplied."
    In other words, even if the battery is out, the watch is still capable of certifying with the car to enable starting the vehicle. It is a nice touch. :)
  9. PsyPrius
    PsyPrius Member
    100
    Wilmette, IL
    Could Toyota devise smart key contact lenses, so by blinking we can lock and unlock doors? It may even beat Honda's Insight for MPG (pun intended). ^_^
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i think it's pretty cool.. i would want one :)
  11. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    I, too, would be very interested in this if we are able to do a group buy. In the event that we find somebody to enquire about the details and compatibility, I would also like to know if there is a smaller and/or "women's" version.
  12. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    but how u open the door with battery out and no mechanical key?
  13. GatorJZ
    GatorJZ Member
    285
    17
    Did anyone ever follow through on this? I know this is an old thread, but it is a great idea.
  14. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    if it can be programmed to the prius sks, ill take one
  15. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    I dont like to wear watches. I like my arms to weigh the same.
  16. Joekc
    Joekc Member
    265
    16
    Easy, wear one on each wrist. ;)
  17. KandyRedCoi
    860
    SoCal/AZ/NV
    no watch FTL, every man needs to have a watch, so any word on the programming for our prius???
  18. GatorJZ
    GatorJZ Member
    285
    17
    I suspect the arm on your dominant side weighs more than the other one. Wear a watch on your non-dominant wrist and you should achieve the balance you are looking for.
