New Solar Panels for Hybrid Cars Improve MPG
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Kiloran, Dec 7, 2005.
  1. Kiloran
    Kiloran New Member
    1,225
    Press Release Source: Solatec LLC
    Wednesday December 7, 8:00 am ET
    WELLS, Nev., Dec. 7 /PRNewswire/ -- Solatec LLC™ is pleased to introduce flexible, rooftop-mounted Solar Panels for Hybrid Vehicles, starting with a kit for the 2004-2006 Toyota Prius. The $2,195 kits will be available nationwide through dealer franchises.
    ADVERTISEMENT
    A prototype (pictured) has been operating in the Northeast for several months under mixed driving conditions. With Solatec panels installed on the roof, the prototype SolaPrius® averages 55 MPG city and 62 MPG highway - an overall 10 percent improvement over the pre-installation numbers.* All-season testing is in progress.
    Solatec's photovoltaic kit (patents applied for) adds two flexible, conformal panels that charge the hybrid automobile's auxiliary battery through a proprietary charger/current-limiter system concealed behind interior trim panels. The self-adhesive, rooftop-mounted panels are only 0.6mm thick and cause no change in aerodynamic drag.
    Development of the hybrid vehicle solar panels came about as a side project of Solatec LLC's solar aircraft research, which uses the same high efficiency flexible photovoltaic panels to sustain the aircraft in flight. The same aircraft grade adhesive is used on both systems.
    Kits for other hybrid cars are presently in development and testing.
    * Individual mileage can vary significantly depending on the driver's speed and acceleration technique.
    Installation franchises are currently available in most areas.
    For more information, see www.solatecllc.com.
    Solatec LLC is a Nevada company engaged in alternative energy research, development and manufacturing. Solatec's main areas of research currently include solar, wind power and geothermal energy.
    Source: Solatec LLC
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
  3. ScottY
    ScottY New Member
    1,250
    Long Island, NY
  4. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    From http://www.solatecllc.com/products.htm, I got the following specs,
    Solar Panel Specifications:
    Panel Thickness: 0.6mm
    Flexibility: Conforms to the contour of the vehicle.
    Adhesive Strength and Durability: Rated for aircraft use
    Manufacturer Rated Output Voltage: 18 Volts
    Manufacturer Rated Output Current: 30 watts (2 panels)
    Miles Per Gallon Improvement: Four Season analysis pending
    Benefit is immediately seen on the Prius on-board fuel mileage display.
    The rated output voltage is 18V? Doesn't sound like it charges the HV battery, unless they step that up somehow.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    $2200 to charge the auxillary battery....I don't think so! Make that thing charge the HV battery with no ill effects over 150k miles of testing and I'll think about it. But to charge the 12v?! No way.
    I simply don't believe their alleged mpg improvements are that big either.
  6. Tempus
    1,690
    Washington DC
    If it has a benefit, it's proabably to run the Aux Systems (all the miscellaneous 12V stuff) without drawing down the HV battery.
    I can see a (probably slight) benefit to sitting in traffic with the Aux systems not loading the HV.
    I would assume it would also keep up the 12V charge if you left it at the airport parking lot for a month.
  7. efusco
    19,891
    1,192
    Nixa, MO
    Yea, I understand that, I just don't think that stuff draws enough power to make a huge difference. Maybe I'm wrong about that though.
  8. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    Hmm that's pretty interesting. Wonder how fast the cost will go down on that. On a side note, I really like how it looks like racing stripes.
  9. geologyrox
    geologyrox New Member
    513
    well, i think its a good first step, really. For someone who spends a lot of time in say, houston traffic, I can imagine it actually helping. it looks nice, and has a fairly low cost - i can't really see it working for me, but it's a good step in the right direction.
    I bet we'll see similarly priced (I like the 10% of the car cost price point a lot) options for the HV battery in the future. I hope people who CAN make use of this unit support them, and provide valuable feedback for perfecting it for the rest of us.
  10. ONwi03
    ONwi03 New Member
    40
    I was thinking the same thing. You could even put a pair on the hood.
  11. efusco
    19,891
    1,192
    Nixa, MO
    I'd take that bet. I don't think we'll see anything of the sort. The HV battery charging is very complex and will require much more than just a few wires and solar panels. I think the cost will be prohibitive and the real problem could be reduced life of the HV battery if the SoC cycling isn't carefully regulated. Probably a whole new ECU or someone figuring out how to reprogram the current ECU would be required. We might see something in a very expensive Prius+ type project where solar panels charge additional batteries and thus passively charge the OEM HV battery, but that additional battery cost alone will be very high not to mention the relatively large and/or expensive solar panels required.
  12. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    efusco, what kind of diseases do you specialize in?
  13. KMO
    KMO Senior Member
    1,541
    425
    Finland
    2023 Prius Prime
    The concept makes sense. There's lots of equipment running off 12V - the power for that is coming from the inverter. If you can supply power to those circuits from solar panels, then less power will come from the inverter.
    However, 30 watts really isn't that much power, compared to what the car itself uses. Guessing the Prius' efficiency to be something around 200Wh/km (probably correct within a factor of 2, given its size), then cruising at say 50km/h, you're consuming something like 10000W average. 30W is not going to make much of a dent. But on the other hand, it IS continuous - power will keep flowing when you're stationery, and presumably parked.
    But will it help much when parked? There's presumably not much scope to store extra energy in the 12V battery for later use - it'll normally be "full" anyway, after driving for a bit, surely? I suppose it'll keep it topped up, so it doesn't need any recharging when you start, at least.
    Now, if this could charge the main battery while parked, it would potentially make much more of a difference.
  14. Jaguar88
    Jaguar88 Member
    172
    La Crescenta, CA
    It would have to look pretty cool. My back of the envelope calculation Indicates gas would have to be about $7.33/gallon to justify the cost.
    150,000 miles @ 50 mpg = 3000 gallons of gas
    Less 10% and you save 300 gallons.
    $2200 price for kit is abot $7.33.
    It may be able to charge the high voltage battery if the battery can be partitioned into banks for charging. I guess the danger would be asymetric charging which could possibly lead to an overcharge of some of the banks, which could damage them.
    Still its good to see people are working on extending the milage for the car.
  15. 2Hybrids
    2Hybrids New Member
    565
    Eustis, Florida
    I would pay the expense if there was say, a 20 mpg improvement - and it assisted the regen aspect in such a way that, coupled with an EV switch, you could "almost" minimize ICE use.
    or would that be way off base to the intention?
    In any case, I can see this technology heading in the right direction.
  16. efusco
    19,891
    1,192
    Nixa, MO
    Now that's pretty OT!
    I practice Emergency Medicine.
  17. maggieddd
    2,090
    Boston
    thanks!
  18. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Lithium? No. Unless you have the EnergyCS kit.
    Please see http://www.robintree.com/prius/startup.html for support
    of the idea that the 12V system has to supply between 300 and 400
    watts, depending on how much lighting and accessories are in use.
    An ideal 8-hour day of 30 watts harnessed from sunlight gives you
    enough energy to run the computers and coolant pumps and such for
    maybe 45 minutes. Or to push the car about a mile under ideal
    conditions, if the energy went to the HV battery instead.
    The correct place to collect enough solar to make a difference is
    outboard of the car, with wiring to connect it up. But the car
    really isn't able to *store* enough energy to do it justice without
    extra traction batteries.
    _H*
  19. Darwood
    Darwood Senior Member
    5,259
    268
    I agree that the HV needs the charge and that an EV switch would be needed to get the full benefit.
    IE, on your way to work, you go EV the last portion so that you run down the battery. Then by the time you leave, the HV is charged again!
    That could allow a pretty good jump in MPG. Unless its bitterly cold as it is now in MN!
    One other thought: What if the HV gets fully charged, where would the energy go then? Could you program it so that the excess was used to heat or cool the car while your away?
  20. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I had photovoltaic panels on my 1991 Toyota 4Runner that kept the 12V battery topped off ($39 per panel). The PV panels were hard-wired to the 12V battery. This current effort falls severely short of what is needed.
    The hood, roof and rear deck should be full PV. All side windows should be of the type that are photovoltaic panels, but you can see through them. With noncrystalline PV, and volume production, the cost should come w-a-y down. These should be standard on every vehicle, not just hybrids and electrics.
